Question about Vacuums
I have a Whirlpool Power Spa (Pollenex) Model 1900B that sounds like it is pumping but no water is dispersed. I followed all directions including making sure the bath tub water level was above the line. Thank you
3 Suggested Answers
  • 29 Answers
SOURCE: I have a Bissell pro heat water will not disperse from
If the red spray pieces are not clogged but the Bissell still will not dispense water, then I would say the next most likely causes of your issue was either no soap in the tank, or a burnt out water pump. But since you can get water through the tools, I don't see how that's possible. I think it's still the sprayers. When you say you stuck a needle in the eye holes of the two red spray pieces, did you actually take the two red spray pieces off the hoses to do this? And then after pushing through a needle, did you try blowing through the red spray pieces? If you can't blow air through them, they're still clogged and water won't go through, either. Here's how to get the red spray pieces off the Bissell: Unplug the Bissell. Remove the water tank pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your roller brushes when you press the water-and-soap trigger at the top of the Bissell's handle, and tend to clog with mineral deposits. Only work on one sprayer at a time so you can see how it goes back together. As you squeeze the red plastic sides of one red water sprayer, push up on the underside of the sprayer from underneath the bottom unit of the Bissell to release the sprayer from its mount in the base. Clean any lint or debris out of the mount area. Clean any gunk you can off the red water sprayer with an old toothbrush. Now you need to remove one water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip up the hose so it compresses the spring and is no longer on the red plastic water sprayer. (See GOTCHA about the spring, below.) With the clip released, now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care. When you've removed a red water sprayer from the hose, put the end of the red water sprayer that was inside the hose in your mouth and seal your lips around it, and try blowing through it. If you can't blow air through it, it's clogged. Open up a paper clip and push it back-and-forth through the small hole in the hose end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Click the red water sprayer back into position in the base of the Bissell. Now do the same for the other red water sprayer. The GOTCHA: Once when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. It?s best to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, fix this by removing the six screws on top of the Bissell base (this is the surface the water tank mounts on top of), and pry it up. Pull out the hose, reattach the red water sprayers on the hose, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base. You might want to prime the pumps. Sometimes an air pocket inside the machine (even a new one) keeps water from flowing, until you reprime the Bissell's internal pumps. To prime the pumps the easy way, turn it on, then press, hold, and release the water-and-soap trigger a few times, waiting a few seconds each time. Still nothing? Prime it the slightly harder way. Separate the two water tank pieces. Only have the base tank filled and mounted on the Bissell without the piece that sits atop the tank. Turn it on. Kneeling on the floor in front of the Bissell, reach up and press the soap and water trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel just a bit of suction. Lift your hand up and down a few times, a few seconds apart. Release the trigger and repeat a few times. As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Thoroughly rinse out and empty both water tank pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and get all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and needs more pampering than a vacuum cleaner, doesn't it?? Good luck!
Posted on Jun 12, 2009
Absolutely the right answer for me. Couldn't get it to work no matter what troubleshooting Bissell suggested. Took apart the sprayers as above suggested and it works as good as it did the day I bought it. Thanks.
It wont disperse water
You need to post with information. This is to vague of a question so it is a waste to even post. Brand make and model is a must. For all I could tell you may have a turkey baster.
Feb 27, 2015 | Vacuums
Cleaner will not disperse water or solutiion
Hi Frances,
Please see the link below to the Repair Guide for the ProHeat 2X. This will help you diagnosis the problem you're having with solution not dispersing water or solution;
Bissell ProHeat 2X Repair Guide Troubleshooting and Repair Instructions
I hope this was helpful to you. If you have any further questions, or would like some additional help, please just ask, I'm happy to help you further.
Oct 06, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover carpet cleaner won't dispense solution or water. Everything else works.
1.Remove bottom tank and look for pinched hose. 2.Use small screwdriver or toothpick on small holes which disperse solution-remove rotating brush first. These were problems with my steamvac (f5861-900 model).
Mar 16, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
The water won't come out. The carpet is still dry after repeatedly pushing trigger to dispurse water on carpet.
If it will not disperse water then that means that the pump belt needs to be replaced. Here is the belt you need:
Proheat pump belt
May 18, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Powersteamer problems
You need to replace the pump belt. Here is the belt you need and it comes with printed instructions:
Bissell Pump Belt
Feb 03, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
I followed directions no water will come out
When water doesn't disperse that means that the pump belt is worn, stretched or broken. You can get belts and view the manual here:
Bissell ProHeat Belt and Manual
Dec 04, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
The water doesn't come out. I've taken it apart
The reason the water is not dispersing is because the pump belt is probably stretched or worn. You can get belts and view the manual here:
Bissell 1699 ProHeat Belt and Manual
Dec 03, 2009 | Bissell 1699 ProHeat Clear View Upright...
Can you disperse a water and vinegar mixture with the steam buggy, without causing damage to any part of the unit? can you disperse a water and bleach mixture with the steam buggy, without causing damage...
If you do this the vinegar will likely disperse hard water scale as it cleans the inside of the element. While it shouldn't stain anything it will likely cause sputtering as it breaks down the scale. If your goal is to clean and disinfect a surface that is vinegar friendly, I would consider taking the extra step of spraying the surface with a spray bottle with the vinegar. Bleach in steam might puff back at you in a cloud and burn your eyes and skin so be VERY cautious on the bleach.
Sep 16, 2009 | Tristar SB Steam Buggy Vacuum
8806-m power steamer power lifter will not disperse solution
These are really great units, chances are the tank isn't seated properly or the pump has lost it's prime. Check the owners manual for troubleshooting. I have included a link to download the owners manual if you are unable to find yours. Click here to download
Hope this helps.
Please take the time to rate this solution
Jan 31, 2009 | Bissell 8806 Powersteamer Upright Vacuum
Vacuums Logo
99 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
