Whirlpool gold washing machine
Please help........my machine will not fill up with water....it is not getting water into the machine at all
    President:
  • 1,294 Answers
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Refit, check for leaks. Water shd be in good pressure. If this is not the problem change your inlet valve, it is easily done.
Pl. rate if helped
Posted on May 11, 2008
Top loader washing machine model sm8281115 leaking when filling loader whirlpool gold washing machine
The leak could be the filler tube, the soap dish, the water valve. You have to do some detective work to figure out where it is.
Jul 24, 2013 | Washing Machines
Whirlpool gold sm 8281115 manual
When my machine is starting to fill the water comes out unto the floor why
Mar 07, 2013 | Whirlpool Washing Machines
Water filling up when off
May be inlet valve be defective kindly replace the inlet valve even if you find that same problem exist the problem with the motherboard of the washing machine kindly give to expert to do the service
May 03, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My machine fills with water but does not spin
This is a good washing machine and we can help you get it repaired and working properly again.
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST.
We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you get your appliance problems resolved soon.
Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Mar 11, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Dish washer fills and then drians without washing
If you're sure it is heating the water, then it sounds like the wash motor/pump has failed. If you've worked on washing machines and/or dish washers before, this is potentialy a DIY job - the Haynes Dishwasher manual is very good, and parts can be found on the internet.
The reason for cheking it is actually heating the water is that the symptoms sound very similar to those of a failed heater = fill, pause, empty, stop usually accompanied wth an error code. Error code will be presented by a number of flashes of a lamp, or a number on a display panle depending whch machine you've got.
Sep 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpoole gold top loader stop working
Try pushing down on lid switch. common problem for these models.
May 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaking from bottom
Replace water pump. Common problem. Unscrew the control panel ,two screws on each end. Flip control panel over and unsnap gold brackets from base to the back. Lift up housing and disconnect lid switch, remove housing. The water pump is in the front lower that has two hoses , disconnect hoses and unsnap pump. My sister fixed hers in about 25 minutes.
Apr 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
We have a Whirlpool Gold Ultimate Care II Washing Machine. Washer will fill with water, but when it tries to go to another cycle you just hear a loud rumbling noise and the basket will not spin.
Peace jjones16 ,
huuum At your service!
You have a Whirlpool Gold Ultimate Care II Washing Machine. And the washer will fill with water, but when it tries to go to another cycle you just hear a loud rumbling noise and the basket will not spin?
Correct?
So!
Sounds like the coupling connecting the transmission to the agitator is worn out!
If I were there hands on I could be definite.
But it sounds like you need this replaced!
Thank God it's not the transmission.
When a transmission goes out of warranty, it;s not worth putting good money into bad! They are just to expensive a repair!
Only a hands on laundry tech can make the diagnoses.
This time you should call service
Let me know what is the final results.
Please write me back.
How old is the washer??????????????
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You,
huuum
Please give me a good rating before you sign off.
Thank You
Sep 12, 2008 | Whirlpool Washing Machines
Washing Machines Logo
Top Washing Machines Experts
