Question about Flip Video F260G Camcorder
Can't get it to upload.. no trace of it on my computer tho it's plugged into the usb...
Have you uploaded the Flip software to your computer first?
Posted on Oct 19, 2010
What mode should camera be in to upload pictures does it matter if you connect usb cable to ccamera or computer first
It should be in playback mode. It doesn't matter if you plug in camera first or computer first but it does matter that you have to first install the proper drivers for your camera on your computer. The proper drivers is on the CD that came with your camera. Install that first before connecting your camera to your computer. Personally, I don't like to connect camera to computer unless I'm doing an update to the firmware. I would suggest buying a USB memory card reader if your computer/laptop doesn't have one already. Then I upload my pictures by removing the memory card from the camera and plug into the USB card reader. Best of luck.
Feb 28, 2011 | Canon PowerShot SD1000 Digital Camera
I purchased a U-VIDEO USB video camera (The Sharper Image) and took it on vacation. I am attempting to upload the videos. Step 1 is Select Video, plug camera into USB port, Open the YouTube Video...
Keep it simple- download vlc player which plays EVERYTHING. Plug in your camera to usb - start player - direct to usb device and play back.
That file you are looking for should be in your programs directory.
Aug 25, 2017 | Video Cameras
Sony camera says Switch on [MENU] when i upload pic from USB cord
1) Try uninstalling then re-installing your Sony software.
2) When you connect to the PC and switch on, Click on Start - "My Computer". Your hard drives and disk drives should appear in the window.
Have a good look, is there a new drive, it may be called Sony, or USB mass storage device it may just be called drive E or F.
If so double click on that drive, if there's a folder there, double click on there, with luck you should see your pictures, that new drive is really your camera.
You should be able to move pictures by copy and pasting. Once copied you can deleted them from your camera.
3) You can buy a device called a "Memory card reader" Make sure its good for sony memory sticks.
You take you card from you camera and put it in the card reader. Then, once plugged into a USB port its just like another HDD as described in 2.
4) I should have said this first, try another USB port if you can, it my just be dust in the port making life hard............
Good Luck.
May 08, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
Uploading pictures
Try plugging the camera into your usb port of the computer and then open up "My Computer" and you should see the camera listed in there and you can just double click on it and view the pictures and save where you want.
Sep 22, 2009 | Vivitar ViviCam 4345 Digital Camera
I can't upload photos from my nikon coolpix s210...
its easy to upload your photos..first store all the photos in your desktop which makes it a faster process to upload..(upload using picasawebalbums)..coming to your problem did you try to do the same in some other computer..if its working in some other comp, the check your usb in the comp.try to connect it to other usb hubs nd check it out..
May 22, 2009 | Nikon Coolpix S210 Digital Camera
Not uploading pictures
I think I know what the problem is, first off the computer must be able to communicate with the
camera/device irregardless of the drivers. The camera is plug and play and so is the computer
unless you are using an older version of windows like 98 or 98 second edition. If you are 98 etc load
the old drivers. But if you are 2000, millineum, or xp then the drivers are automatic for the usb ports.
The panasonic dmc-fz7 is kind of a freak in that it is not a true plug and play device. Sometimes
you have to declare the new hardware. It may have once worked but for what ever reason the hardware may not jive with what the pc thinks it sees if anything at all.
Solution: Go into the Control panel , add hardware wizard, with the camera hooked up to the usb
port and the camera turned on. In the device manager you should get the appropriate message, "new hardware detected" actually it should say dmc-fz7 etc. From there it should be apparent that things are working normally....Good luck. Probably a power glitch or who knows. Mostly its a problem with panasonic plug and play software which they corrected a year or so later with the newer cameras...
Dec 22, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Uploading pictures
I use a standalone cardreader, that i plug via USB to my computer. This solution works very fine.
Feb 29, 2008 | Canon PowerShot S500 IXUS 500 Digital...
How do i upload photos from my 'phone to my pc using the usb cable?
if u have access to another phone that you know CAN upload to the computer, bluetooth or infrared the photo's to that one and upload via it. there are also USB bluetooth AND infrared receivers that plug into your computers USB and can receive pictures or files from your phone that way.
they're the only ways i know of. Hope i was help.
Dec 11, 2007 | Sony Ericsson V600i Cellular Phone
My camera won't upload
It's an improperly installed driver for you device. Try going to safe mode and reinstall your camera drivers. Then try plugging it in first while the computer boots to see if it recognizes the attached camera...
Dec 10, 2007 | Canon PowerShot A85 Digital Camera
Flip Video F260G Camcorder Logo
37 people viewed this question
Top Flip Video Video Cameras Experts
matt
matt
Are you a Flip Video Video Camera Expert? Answer questions, earn points and help others
