Question about Kenmore Elite Oasis 27052 Top Load Washer
1. screen showed "sf". I know it's motor overload BUT, I left it for three days and still showed "sf"! How do I reset this? 2. Display now shows "ld" which is the lid but no matter how much I lift the lid, shake it or slam it, it won't go off! How do I reset the lid?
You need a  motor new or used that will solve your problem.
                                                    Fitzgeralds applience repair. and we might have a used one for ya if interested all i need is the model # of the washing machine. My e-mail fitzgeraldd16@yahoo.com
Posted on Sep 04, 2010
Reset thermal
I think the question is thermal overload on a three phase motor. If a motor has a thermal overload that must be manually reset then there should be a button on the motor, often red. While the motor is de-energized (power plug removed) , push the reset button by hand.
Jan 04, 2014 | Dryers
ATLAS COPCO GA45+FF. COMPRESSOR SHOWING OVERLOAD MOTOR/FAN MOTOR. HOW CAN WE RESET
Could be the unloader valve did open, Unhook the motor from the compressor and see if you can turn the motor on, then see if the compressor can be turned by hand
Jun 13, 2013 | Air Tools & Compressors
Have a SSR-EP100 air compressor that shows
Try to reset the main motor and fan motor over loads by pushing the reset on the overload it self, Then reset the controller. If the error resets, before starting. put a clamp on amp meter on to L1 or L3 motor lead which is located in the compressor electrical box . Then start and observe amps when unit is making air fully loaded. Once you know how many amps at full load the unit is pulling ,look at the overload setting on main motor overload and see if it is approxmately 10 amps above the max amps being pulled.If not set it about 10 amps above your max load amps.
Nov 26, 2011 | Ingersoll Rand Air Tools & Compressors
Please can you tell me how to change time and date. thank you. Wendy
The current time and date are shown on the display when the machine is on and ready for use (standby mode). The time and date are printed on all faxes you send.
Note: If power to the machine is cut off for over 30 minutes, when power is restored, the machine prompts you to reset the time and date.
1. Press Setup. The display shows the first setup menu; FAX NUMBER/NAME.
2. Press left arrow or right arrow until 'TIME/DATE SETUP' appears, then press
Start/Enter. The display asks you to choose a date format.
3. Press Start/Enter.
4. Press left arrow or right arrow until you find the desired date format, then press
Start/Enter.
If you select USA, the time and date appears in the order of month, day, then year. The EUROPE format will be displayed in the order of day, month, then year.
The display shows the currently set time and date using the selected date format.
5. Enter the correct time and date using the number keypad.
Day = 01~31
Month = 01~12
Year = four digits
Hour = 00~23
Minute = 00~59
You can also use left arrow or right arrow to move the cursor under the digit you want
to correct, then enter a new number.
6. Press Start/Enter when the time and date on the display is correct. If you enter an invalid number, the machine beeps and does not proceed to the next step. If this happens, just reenter the correct number.
The display shows the time and date you have set, then returns to
Standby mode.
06-25-1999 12:30 ('USA' type)
Nov 25, 2010 | Samsung SF-5100 Plain Paper Laser Fax
How do I set the current time on the Woods Digital Timer Model#59203?
78a8604.jpgWoods 59301
Manual for 59301
http://waterheatertimer.org/pdf/Woods-59203.pdf
Plug timer in wall for 1-2 hours so rechargeable battery charges
If display does not show after 1-2 hours, the battery is dead and timer is no good
After 1-2 hours, you can remove timer from wall to program
Press reset (R) with paper clip to clear memory
Select format: Press and hold Clock button until 12 hour or 24 hour shows on display, then release
Press hour button to change display to 12H
press Clock button and display returns to normal
AM shows in upper left corner
Set current time:
Press and HOLD clock button
While holding clock button, press hour button and minute button until display shows current time
Release clock button
Press and HOLD days button until current day shows in display
Release days button
Further instructions to set ON-OFF times are in manual (click link shown above for manual)
If you have problems, re-post additional question.
Oct 17, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Sharp SF 2030 Copier ,need reset operator key code
First you need to know the key operator code, you can display it by pressing [C][INTERUPT] [0/ZERO][INTERUPT][22][START][13][START] then the display will shows you the 5 digits key operator. After you know the key operator code, you can go to User program, this is done by pressing [C][INTERUPT] [C] then input the key operator code, when entry is complete "P" will appear in the quantity display. Input 19 then START, input the new code and press START. To exit user program press CA
Jun 04, 2009 | Sharp SF 2020 Copier
Nortel T7316E need to reset all the password
How to Change a Mailbox Password 1. To access the voice mail system press Feature.
2. Press 9 8 3.
3. When you see Log: enter ~ SETNNA (738662) and press OK
4. Pswd: CONFIG (266344)
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number you wish to reset.
8. Press "Reset".
9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
Apr 16, 2009 | NorStar M7324 Telephone
R51 thinkpad display problem
I think the LCD screen is not working properly. The only solution is to replace it.
You can find replacement LCD screens for IBM R51 here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
May 27, 2008 | Lenovo ThinkPad R51
Kenmore Elite Oasis 27052 Top Load Washer Logo
54 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
