Question about Refrigerators
Hello, I have an Breezaire WKU-1060 cooler for a wine credenza and the motor still works but it pushes out warm air instead of cool air. Might there be a possible low cost fix for this?
  • 27 Answers
SOURCE: wine cooler
cheak the machine main on/off switch, cheak the in$out phase line
Posted on Jun 21, 2008
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
  • 21 Answers
SOURCE: Unit does not cool
It would appear that the unit needs to be regassed and checked for leaks.
Posted on Sep 11, 2009
  • 25 Answers
SOURCE: breezaire wkce 1060 does not cool my wine cabinet
I'm not familiar with your unit, but sounds like condenser problems. Check for a dirty coil on the backside or underneath the unit. Also, if it has a fan for that coil, make sure it's running when the compressor is running and that the blades are clean. Other than that, it could have developed a refrigerant leak.
Posted on Sep 15, 2009
  • 101 Answers
SOURCE: Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Posted on Feb 05, 2010
Breeze air wkl 3000 blinking temperature al
NEW UNITS HAVE A VISUAL ALARM PRE SET TO KICK ON AT 62 DEGREES OR ABOVE, WHE THE WINE COOLING UNIT READS 62 OR ABOVE IT WILL FLASH "AL" AND THE TEMPERATURE NUMBER THAT FORVED IT TO KICK ON, IT IS JUST A VISUAL ALARM IT WILL NOT TURN UNIT OFF OR STOP IT .
THIS FEATURE WILL SHUT OFF ONCE THE UNIT READS ANY TEMPERATURE BELOW 62 DEGREES.
Dec 27, 2013 | Breezaire WKL-2200 Wine Cellar Cooling...
Breezaaire error code
WKC 1060 ARE NON DIGITAL AND CAN NOT DISPLAY CODES,YOUR UNIT PROBABLY IS A WKCE 1060 DIGITAL UNIT IF SO PLEASE CLARIFY WHAT IS THE ERROR CODE ON IT?
Sep 15, 2012 | Breezaire WKC1060 Wine Cellar Cooling Unit
II started up my 1060 two days ago. The fanis working properly but Idon't get any cold asir. A service person rechareged the coolan but still no cold air. I have unplugged it for the time being
The service person shouldn't be recharging the refrigerant unless they have found and repaired a leak. Or do you mean an antifreeze solution that is pumped round the system? If so the service person should have checked the cooling system was working before adding coolant.
Jun 16, 2012 | Breezaire WKC1060 Wine Cellar Cooling Unit
The unit does not cool anymore. The fan works but the temp is in at 80.
IF THE FANS ARE WORKING ON BOTH SIDES HOT AND COLD AND NO COLD AIR IS BEING PRODUCED YOU PROBABLY HAVE A FREON LEAK
Dec 26, 2010 | Breezaire WK2200 (265 cu. ft.) Wine Cooler
What refrigerant is use for BreeZaire wkr 1060 and
A WKR 1060 SHOULD BE AN R-22 REFRIGERANT UNIT AND IT SHOULD STATE SO ON THE UNITS TAG ON BACK OF THE UNIT.
I IT IS IN FACT AN R-22 MODEL 1060 IT USES 9oz OF R-22
IF IT IS AN R-134A IT USES 10 oz
Dec 02, 2010 | Breezaire WKCE 2200 Wine Cooler
Does not cool ?
Hi!
1. Check if there is enough breathing space between the wine cooler and the wall. The cooling radiator must getting hod due to lack of ventilation.
2. Clean the radiator using a vacuum cleaner .
3. The Gas has leaked and you need to refill the gas.
Regards
Berry
Feb 01, 2010 | VinoTemp Credenza 270B Wine Cooler
Breezaire wkce 1060 does not cool my wine cabinet adequately unit worked OK (but not great when new). Now the unit is 4 years old and will not cool the cabinet more than 11 degrees below room...
Sep 14, 2009 | Breezaire Refrigerators
Refrigerators Logo
151 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
