Question about Mtd 22" Yard Machine Push Mower
What is the measurement on the float - Mtd 22" Yard Machine Push Mower
What is measurement of a float level on a carter one barel carburetor on a jeep cj5 1977?
1977 now that is a blast from the past.
finding books that old is hard, but are sold in book stores.
but from Carter, and very very old jeep books.
4 engine then
and 2 Carters, i see.
232/258cu-in, with YF carb
here ill paste the words
"To adjust the float drop, hold the air horn in the upright position and measure the distance between the top of the float, at the extreme outer end, and the air horn casting. The measurement should be 11/4 in. (31.75mm) to 1973, 13/8 in. (35mm) 1974-78. Adjust by bending the tab at the rear of the float lever."
Nov 09, 2016 | Jeep Cars & Trucks
I am currently doing a carburetor rebuild on my yamaha and I am trying to adjust the float height, but I am having trouble finding the clearance
this is a rule of thumb for carbies where the float is pivoted from the top cover
with the float in position turn the top upside down and the float will now be in the position it is in when controlling the fuel
the float top should now be close to parallel to the top cover it is attached to
if you manage to get a measurement for that distance it is measured by the specified measurement as a twist drill and it is to move under the float as you roll it along the top cover
not to move it up or miss it but just touch it
adjustment is by bending the small tang that is connected to the needle
now if such a measurement is not available simply ask your service dealer what it is
May 13, 2016 | Yamaha Virago Xv 535 Xv535 Engine Cover...
1965 buick skylark float level ajustment for 4.9l carburetor
The float level and float drop are both measured with the gasket in place. Having said that, here are the following measurements.
Float level is measured between the edge of the float seam and the formerly mentioned gasket. This measurement is 1/2" on a 2 bbl. and 1 21/64" on a 4 bbl. for the primary and 1 3/8" on the secondary.
The float drop is measured from the bottom edge of the float as it's hanging from the pivot, to the gasket.
The 2 bbl. is 1 29/32" and the 4 bbl. is 1 19/32" on the primary and 1 3/16" on the secondary.
These measurements and instructions come from a 1965 Chilton Auto Repair Manual as that's the only reference I have.
Hope this helps.
May 31, 2015 | Buick Skylark Cars & Trucks
Float adjustment
If you can't find the measurement, just turn it upside down and adjust the float parallel with the surface where the bowl fits.
Aug 10, 2014 | 1986 Suzuki GV 1400 Cavalcade LX
Adjust mikuni carb float
Pull the float bowl and float bowl gasket off the carburetor.
Place the carburetor upside down and let the float rest against the float needle.
Measure the distance between the gasket surface located on the bottom of the carburetor to the edge of the float. On a 24 mm Mikuni card, the distance between the gasket surface and the float should be 1 inch. On a 20 mm Mikuni carburetor it should be 7/8-inch.
Bend the metal tab on the float that rests against the float needle. Bend it towards the float needle if the measurement is shallow and away from the needle if the measurement is too much.
Use a pair of needle-nose pliers, making very small adjustments to the metal tab and then recheck the measurement.
Nov 20, 2013 | 2006 Yamaha Road Star Midnight Silverado
Settings for carb float level and air setting
the air screw gets turn in fully and the turned out 2 turns this will set it right for most bikes you might have to play with it either half a turn either way
When setting the float level be aware that the spring loaded bumper on the fuel inlet needle valve may have a tendency to compress under the weight of the float assembly which will skew your measurement. Before you obtain your measurement you'll need to make sure that the float assembly tang just barely makes contact with the spring-loaded bumper. Sometimes it is easier to hold the carb body at a 45-degree angle to avoid compressing the spring in the fuel inlet needle.
If you find that your measurement does not match your float level spec then you can carefully bend the float assembly tang to achieve your desired measurement. Be sure to recheck your work, and if you feel confident that your float level is spot on then you can reinstall your carb
hope this helps
john
Apr 29, 2011 | Honda VT 600 C Shadow Motorcycles
2000 marauder leaks gas out of overflow tube on the carberater only when starting or running
the floats in the bottom of the carb need adjusting the are to low
If you find that your measurement does not match your float level spec then you can carefully bend the float assembly tang to achieve your desired measurement. Be sure to recheck your work, and if you feel confident that your float level is spot on then you can reinstall your carb and get back to riding.
Apr 21, 2011 | 2000 Suzuki VZ 800 Marauder
Float level measurements
there should be a line on the float bowl, if not set the carbs upside down on a work bench get eye level set floats to where you can only see half start there ,if they over flow back off a bit GET A MEASUREMENT IF POSSIBLE oh you'll have to make a aux fuel cell if you dont want to pull on and off seems like some specs are tuff to find so do this hope this helps
May 01, 2010 | 2001 Suzuki DR-Z 400 SE
Its not a problem, I need to know if there is another way to set/measure the float hights without the need of the speacial Kawasaki tool for doing so? I understand the hieght should be set at around 15mm...
Here is the fallback method that has always worked for me: have the float arms (that part of the float which attaches the floats to the hinge) parallel to the float bowl gasket surface just as the float valve contacts the float - without depressing the spring loaded tip on the valve. Frankly, I have used float gauge maybe once in my life - this method is much faster and easier.
Jan 06, 2010 | 1990 kawasaki ZZR 1100
Float setting for BS34ss carb
I have a set my float to 22.0 +- 1.0 for a Mikuni carb.
To set floats, drain the carbs, pull the carbs from the bike invert and remove float bowl.
With the carb inverted, take off the float bowls. Take off the gasket. Use a vernier caliper or an accurate device to measure from the carb body to the top of the float block.
Here is are a couple of good sites about carbs and such.
http://www.allthingsmoto.com/forums/f-15/how-set-your-motorcycle-carburetor-float-level-more-commentary-13608/
http://www.dansmc.com/carbs2.htm
Aug 10, 2009 | 1979 Suzuki GS 400 E
Mtd 22" Yard Machine Push Mower Logo
14 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
