Question about Logitech Z-640 Computer Speakers
How to connect the wires of a logitech z-640 to my tv
I have a logitech Z-640 speaker system connected to a Panasonic Plasma TV and the sub woffer has no volume coming from the large speaker.All the other speakers are OK It seems there is no power going
Hi Ray,
if there is no power going thru than,might probably be your fuse in the subwoofer that's blown.What you have to do is remove the wire mesh from the front using a terminal flat screw driver. You will notice that there are screws around the speakers,remove them inorder to take the speakers out.Once you've done that take out the speakers gently so that you dont disconnect any wires inside.Turn the peakers over and you will see a fuse attached to the speaker.Try replacing the fuse with the asme ratings.
Please refer to the image below on what the back of the peaker looks like.
All the best and Good Luck.
G..
Nov 10, 2011 | Logitech Z-640 Computer Speakers
How to connect a Logitech x-540 speaker system to sharp aquos LC-40e77un tv vIA A bELL 9241 hd RECEIVER
Yes, this is normal, but it should be just for the speakers, not for the receiver.
Nov 01, 2011 | Logitech X-540 Computer Speakers
How do i get z-640 manuels
Here is a link that i recommend for finding any replacement manuals of any sort.
http://audio.manualsonline.com/manuals/mfg/logitech/640.html
Hope this helps.
May 02, 2011 | Audio Players & Recorders
No sound from speakers, loose connection in green jack wire.
Yeah man I have the same problem!
I guess I will just buy a new jack!
May 27, 2009 | Logitech Z-640 5.1 6-Piece Home Theater...
I need a circuit diagram for My Logitech Z-640 Computer Speakers
You may have to call Logitech support or email to find out what the pin out is. that would be my only solution if there is one.
Mar 26, 2009 | Logitech Z-640 Computer Speakers
Logitech Z-640 installation disk, I had to bring my computer back to factory settings and I cannot find my installation disk for my logitech Z-640 surround sound. Is there a place i can download the...
The Logitech website under the support section. All you need to do is look up your model # and then download the software/drivers for the operating system you are using. Hope this helps.
Jan 10, 2009 | Logitech Z-640 Computer Speakers
My Logitech Z-640 Computer Speakers emit no sound
you have to reload the machine and if it continues like that,you have to buy a sound blaster
Dec 23, 2008 | Logitech Z-640 Computer Speakers
Logitech Z-640 Parts
what piece are you seeking? the amplifier or module to convert to your TV? to make this work, you'll need to inform us of the computer make/model and o/s, and the TV that you're looking to plug into.
Mar 30, 2008 | Computers & Internet
Logitech Z-640 Computer Speakers Logo
212 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
