Question about LG DLE2514 Electric Dryer
Black marks on clothes
Dryer tub felt is putting black marks on clothes ...tucked back in but keeps riding out to the edge of the tub both front and back
  • neenee702 Sep 13, 2008
    The felt gasket has completely come out of the back of the dryer. I've stuck it back in several times, but it looks like there is some sort of glue that was intended to hold it in.
    VERY VERY annoying. This was an expensive dryer and we have only had it for about 16 months.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
Your going to have to get service for this one. Chances are the rollers are gone and the black is coming from the rubber onto the felt and then transfering to your clothes.
Sgt 48
Posted on May 31, 2008
Black marks clothes
black marks on cloths usually occurs on older dryer when the felt liner that supports the drum, wears out or is torn, leaving a gap for cloths to get pulled into and between the drum-and drum support.
The replacement part (is not felt anylonger) but made of teflon and has self-sticking backing that goes on the front support after removing the old felt and glue. While you at it, order a new belt, that is most likely been slipping when the closes get jamed between the drum and support. Look up your model number on selectapart.com They aslo have tutorials so you can see how to install these items
Sep 09, 2014 | GE Dryers
Leaves brown marks on clothes marks will wash out but when dried they are back on the clothes otherwise dryer works great
you have to replace the felt piece in the back where the drum rides on,the clothes are going through the gap where the felt has worn out and could be rubbing on the rollers or whatever the clothes are touching as they spin,if there's a felt piece on the front change that out too.
May 11, 2011 | Dryers
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Clothes get tuck on the front edge and discolors
it most probably needs to have the felt cushion on the front of the drum replaced.
Jul 09, 2010 | Kenmore 83042 Electric Dryer
Dryer is leaving brown marks on clothes. it is either a burn mark or they are getting caught between dryer drum and shell, not the door
I had the same problem. Unfortunately, it is caused by a rusting drum edges, if you can believe it. My dryer was only 6 years old when this problem occured. There are felt gaskets on the front and back of the drums where it contacts and rotates on the frame of the dryer. You can take a white cloth and run it around the rim of the front and back of the drum and I suspect you will end up with some discoloration on the cloth. I had these felt gaskets replaced, but that is only a temp solution. When the drum is taken out and the old felt gaskets are removed, you can clean the edges of the drum and get a lot of rust/brown off the drum. New gaskets are only a temp fix. I did it about 1 1/2 yr ago, and I think the problem is starting again. Probably time for a new dryer or time to pull the drum and clean it. New drum probably cost prohibitive if you can get one. What a bunch of **** for a 7 1/2 old dryer. Next dryer will have a stainless steel drum. Hope this explanation helps you with your problem.
Steve
Mar 29, 2010 | Amana ALG331RAW Gas Dryer
I get black streaks like the rest of you.. I
it's not the drum,it's the felt pieces that the drum rides on, there is felt on the back of drum and theres a felt piece on the front bulkhead, they could be worn leaving a space letting the clothing slip through hitting the black rollers or something is falling through the space hitting the clothes next time send the model number so i can look up your dryer,the model number is around the opening where you put the clothes into the dryer,open the door and look around the opening and you'll see a tag with model and serial number
Jan 22, 2010 | Kenmore 73952 Gas Dryer
Torn clothes
there should have been a plastic gaurd on the lint catcher inside to keep this from happening, at anytime when taking your clothes out did you find something you might have though how did that get in there> could have been it, or look under the dryer and see if it made it's way out past the drum to the floor
May 30, 2009 | Frigidaire GLEQ2152ES Electric Dryer
The dryer is leaving what looks like brown burn marks on clothes
you might need to replace the felt on the inside front that the tub rides on
Apr 23, 2009 | Dryers
Frigidaire front load dryer. Been getting
The front tub support needs to be replaced. It is a felt seal the tub rides on and is getting worn, and the sheets are getting between the drum and seal. no the dryer does not need to be replaced.
Mar 08, 2009 | Frigidaire FEQ332E Electric Dryer
Black marks on clothing at completion of drying cycle
Is the residue coming from the back or front of the drum? Most dryers are equipped with 2 drum roller supports in the rear under the drum. You may have a drum roller that is going bad and some of the rubber residue is getting past the drum seal. Some dryers are quipped with an additional pair of drum rollers under the front of the drum as well. I would check all the drum rollers to see if they are all in good shape. A definite symptom of a bad drum roller is finding black residue along the outside of the drum where the rollers ride. You will have to open the dryer cabinet to see the outside of the drum. Also, check the rear drum seal to make sure it is not crimped or folded inwards in the drum. The felt seal in the back should should ride evenly all the way around the drum and should not be that visible inside the drum itself. That is, you may see some of the seal, but you shouldn't see part of it folded inside the drum or bits of it tattered or torn. I hope this makes sense to you. Let me know if this helps.
Jul 06, 2007 | LG DLE2514 Electric Dryer
LG DLE2514 Electric Dryer Logo
292 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
