Question about Canon PC1061 Copier
I replaced the cartridge and now it wont copy anything
  • marathon915 Sep 04, 2010
    i did that and it wont copy on either the old or new cartridge do i finally need to buy a new one its been a good copier for at least ten years. if so can i still buy the same kind new or is there another make or model i should get
  • 1,110 Answers
If you mean blank copies then you either have installed a bad cartridge or perhaps you did not pull out the toner seal tape from the new cartridge before you installed it. If not then just remove the new cartridge and check one of the 2 ends of the cartridge for a small tape sticking out. Pull that out of the cartridge which will release the toner supply to the developer roller. Then re-install.
If you did this already then test for a bad cartridge by shaking the old toner cartridge back and forth a few times and put it back into the machine. It should work well enough to at least test for blank copies.
Good Luck and Thank You for using Fixya.
Posted on Sep 04, 2010
  • Edwin Martens
    Edwin Martens Sep 04, 2010
    If you need a basic copier I would recommend the Canon D320 at Office Depot for less than $100.00.
    I have referred a few of my customers to this machine with no complaints. It is laser based so a similar cartridge syystem as your current machine. It can also be used as a PC printer if desired.
    If this has helped please update my helpfulness rating.
    Thanks
Bluish color to copied photos
Replace color cartridge:Reason: Color cartridge carries three color for color combination, in that any one of color empty or dried up color combination wont happen perfectly, result printer get mismatch colors.. In your case it might be magenta color over.. replace color cartridge to get good print outs..
Jan 31, 2012 | HP LaserJet 3050 All-In-One Printer
The printer says so ink cartridge installed on black.
my hp officejet pro 8500 wont make copies, it says replace yellow ink cartridge. can i not take the yellow cartridge out an still make copies?
Oct 01, 2009 | Brother Multi-Function Center MFC-240C...
Wont copy in black because color cartridges are empty
I'm sure you're using the Blue button to make the copy as it should do B/W copies only.
Double-check that black cartridge is not empty.
If the printer was connected to computer then we could have used diagnostics software.
So we start with a workaround.
Check if its display menu has any option of Ink cartridge level reset or something like that. If it has then do the reset.
If there is no such Menu option, the while the printer is On, open the compartment of printer cartridges and take out the 4 cartridges
and put it back.
Does any option in display Menu comes asking if cartridges are replaced? answer yes if it asks.
Now try to do a copy.
Hope this helps.
If it doesn't work then a question, how many days before the printer was last used?
May 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
I just replaced black ink cartridge and snapped all cartridges back in place and recharged the printer now it wont recognize the black ink cartridge even though it was just replaced
Try wiping the copper contacts on the new cartridge with a dustfree cloth dampened with some alcohol. Dry thoroughly before reinstalling.
May 05, 2009 | Office Equipment & Supplies
Copying anything comes out sketchy
I replaced the black ink cartridge....alls well
Mar 22, 2009 | HP PSC 2210xi All-In-One InkJet Printer
Wont print
Ok... Press copy and cancel at the same time.
If that does not work, you'll need to call 1.800.421.6699 to get a printhead.
Mar 09, 2009 | Kodak 5500 ALL-IN-ONE PRINTER
Cannot fax, copy, etc.
Could you tell me the model number please as I had this problem today and I think I might have an answer for you.
Dec 09, 2008 | Brother Office Equipment & Supplies
It just wont work
Move the ink cartridge carriage (the printhead) to the middle of the printer like you're going to change cartridges.  Take out all the ink cartridges.  There should be two black springs on either side of the printhead.  Remove these and the printhead should pop out.  Clean the nozzels (the little parts that squirt out ink) and reassemble.
If this doesn't work, then you'll have to replace the printhead.
Oct 28, 2007 | Brother MFC 3100C All-In-One InkJet...
Cannot receive faxes or do copies
If you still have your old cartridge reinstall it that will tell you if it is the cartridge or not. If you still have the problem,it could be the encoder.
Oct 23, 2007 | Office Equipment & Supplies
Canon PC1061 Copier Logo
126 people viewed this question
old marine
old marine
