Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigidaire We just purchased a Frigidaire, # 154427301. What does HO mean when it starts up?
  • 4 Answers
ITS LOOKING FOR HOT WATER. TRY RUN HOT WATER IN YOUR SINK FIRST.
Posted on Jul 10, 2008
What is the serial number for part number 154427301/G
look under the steel plate under the door. it should come off with two screws.
Apr 22, 2016 | Frigidaire Dishwashers
FRIGIDAIRE DISHWASHER KEEPS COMING UP WITH CODE HD. WHAT DOES IT MEAN
It's possible that the code is "HO", not "HD" --
This is the notification that the unit is in a heat delay to allow the water to increase in temperature.
No component to be replaced, but recommend the homeowner check the incoming water temperature and run the faucet before starting the cycle.
Sep 25, 2013 | Frigidaire Washing Machines
Frigidaire fdb1050rec 154427301 Have had this
Good Morning Kate, thank you for your inquiry!
Often when a dishwasher leaks, it is because the unit could possibly be unlevel. If not, water can be leaking over the front lower baffle in the door. Try looking along the cabinet and see if the unit is even with the cabinet. Measure the correct amount of detergent as found in the Owner's Guide. It is recommended to use one teaspoon for every three grains of harness. If regular dishwasher detergent (for sink use) is used in a dishwasher it can also cause excessive sudsing. Lastly, the dishwasher could possibly have a loose water vale or a crack in the tub. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Sep 05, 2013 | Frigidaire PLD4555RFC Dishwasher
Dishwasher is on and running a load. It is flashing HO??
The "HO" means it's trying to heat the water to the appropriate temperature before proceeding in the cycle. It's totallly normal, and can go on for 20 minutes or so... if you run your sink faucet to clear the line of hot water first, it will reduce the time it takes to heat the water
Apr 03, 2010 | Frigidaire Professional Series 24 in....
What does the error message "HO" mean?
it means heating delay if the water going into the dishwasher isnt hot enough it has a feature that delays the wash as it heats up your water
Nov 02, 2009 | Frigidaire Dishwashers
What does Frigidaire dishwasher timer code "Hd"stand for? It's not listed in the manual and I couldn't find it listed online. If it's just a "Hold" code (which is what I suspect) for extra washing time,...
“HO” or “Hd” means the dishwasher’s cycle time is being extended while it is heating water. At certain points in the wash cycle, the dishwasher uses hotter water to ensure a clean load of dishes. If it detects that the water is not hot enough, it will heat it.
If you’re seeing “HO” or “Hd” frequently, check the temperature of the water available to your dishwasher. It’s best to do this at the sink closest to it, allowing the hot water to run until it reaches its maximum temperature before you test it with a thermometer. For best results, water should be not less than 120°F.
Sep 20, 2009 | Frigidaire PLD2855RFC Dishwasher
"HO" flashes on display during washing.
HO, indicates that the dishwasher is using Hot Water. It is completely normal.
Mar 08, 2009 | Frigidaire Professional Series 24 in....
I want to know what HO means on a frigidaire dishwasher?
it means the water is trying to heat up and it is taking longer than normal. Check your hot water heater to make sure it is heating properly. Do not use hot water in other areas at same time ..ie: washer, shower, etc. The HO will disappear once the water is heated to the proper level by the dishwasher.
Dec 31, 2008 | Frigidaire Dishwashers
Error code HO on frigidaire gallery series dishwasher
If your hot water isn’t hot enough it will display “HO” while heating the water to operating temperature
Sep 06, 2008 | Frigidaire Dishwashers
Frididaire dishwasher HO on display screen
If it is coming on during the cycle it means the dishwasher is heating the water. If it is after the cycle or the cyle is stopped it means it did not reach the proper heat temperature. As long as it is running through the whole cycle it is ok.
Jun 13, 2008 | Frigidaire Dishwashers
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
130 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
