Question about Ovens
The oven lights come on but there is no display. The buttons beep when pushed but again, there is no display
  • 3 more comments
  • mg12480 Sep 09, 2010
    Sorry, my first question was not clear enough. I have a Whirlpool GBD307PRS00. The display on the front went out (clock, oven temp, etc.). The buttons on the front will still beep but there is no display. You can still turn on the oven lights by opening the doors or pressing the button on the display. The display came back on once and the time was still correct. After about 12-16 hrs. it went blank again. What needs to be replaced and is it a fix that a handyman can complete. I have repaired my washing machine with the help of this website.
  • mg12480 Sep 15, 2010
  • mg12480 Sep 17, 2010
  • mg12480 Sep 19, 2010
    Thank you for your help. Does the oven have to be pulled out to replace the control panel or does the front display disconnect?
    Thank you for your help. Does the oven have to be pulled out to replace the control panel or does the front display trim disconnect?
  • 1,711 Answers
Most probably the information multi cable on display board is loose and not connecting well. So you need to remove the panel and reach the display board and check the cable connection on it by pressing them.
However there is small chance that the Display board is faulty so you need to replace it unfortunately this is one unit with the Electronic control unit and is an expensive part $200. So have a very good visual check and also check all wires very carefully since if you find a loose connection then this will worth 200$.
In any case here are the details of the Electronic control board
Electronic control - Microcomputer
Part Number: AP3873768 made by WHIRLPOOL
And here is a link where you can buy it and also a diagram for you to help you find it.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164941&diagram_id=1300805#d1300805
Posted on Sep 17, 2010
  • espressonist
    espressonist Sep 19, 2010
    Yes first you must pull the oven out in order to be able to remove the display rim more easily
  • 2,299 Answers
The display is nothing more than a light bulb. If you look really close you might be able to see the display change. They have a really small light bulb behind the display, but sometimes they go out. But you still have to replace the whole display.
Posted on Sep 04, 2010
  • 1 more comment
  • Rodney Clark
    Rodney Clark Sep 15, 2010
    OK! It sounds like instead of the light bulb that I talked about going out, just isn't getting a good connection. If you bump the side of the oven by the display does it blink or come on?
    There is still no display. I don't believe that it's a light bulb issue. I think it's a control panel issue of some sort.
  • Rodney Clark
    I agree 100% it is a control panel issue. This display has a small light bulb that is suppose to shine all the time. The digital display has small windows that open, an 8 all of the windows are open for example, and for a 6 all of the windows except for the top right window is closed. But the light behind the windows is not lit. That is why it is holding the correct time. The light bulb is very small. If the control panel was completely bad then it would not keep the right time.
Why is display blank?
You may need new capacitors on your display board, if it is expensive you can have it rebuilt
Feb 29, 2016 | Whirlpool GBD307PR Electric Double Oven
Thermador CM301U Microwave cook smart, self clean and proof buttons all make the display light up as normal, but probe, convection, bake, broil and roast do not. I can hear the beep but nothing on the...
there are two boards in the oven and i would think that it is the one on the left called the secondary . if you remove the display panel you will find the tech sheet and this should help diag the problem . thermador does use fault code's and if any have displayed / in the tech sheet you will be able to tell whats going on or in this case what isn't .. mm hope this helps .. feed back pls .
Nov 29, 2010 | Thermador CM301U Electric Single Oven
Oven display went blank. Has Power.
Hello, The first thing I'd look at is your owner's manual to insure the timer hasn't been set to "Sabbath" mode accidently. If that is the case you could experience a "no display" scenario. The manual will also explain how to enter/exit the "Sabbath" mode. In the event the timer itself is at fault ( i.e. the display transformer gone bad ) it will have to be replaced or (if an available option exist's for your timer) have your timer rebuilt. Hope that help's and please take a second and rate the info provided by me here at fixya. Thank you and good luck. macmarkus :)
Dec 07, 2009 | Whirlpool Ovens
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
GBD RBD Whirlpool Oven Problems Causes and Solutions
Hello Edward!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
May 13, 2017 | Whirlpool RBD305PD Electric Double Oven
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
Whirlpool Double Oven RBD305 Display doesn't show, oven wont work
Most definitely a bad control board and/or soldered components. (The part about cutting power to the oven was a dead giveaway)
There are low and high temperature solders, but usually solder melts at 370° F. If the oven is improperly insulated or ventilated you will have continued heat stress to the control board.
Mar 31, 2017 | Whirlpool RBD305PD Electric Double Oven
No display, No beeps, No heat
I was able to fix my problem by pushing the setup button and holding for about 10 sec.No where in the manual is this described. I call Jenn air and all they could suggest is that I checked the power supply!
Jul 15, 2008 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
141 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
