Question about Toro Garden
One of my neighbors gave me there old lawn tractor he said it sat outside under a lean to its got a great body and axles its a LT832 3speed WORKHORSE by Wheel Horse my question is where do I find a manuel for this tractor I have not seen this tractor in action but really like to What I can see its going to take some parts to ,like gasline ,gas filter ,sparkplug, a starter battery cable ends 1 is ripped off , a tractor key so I guess I would need a parts manuel as well Can you tell me who to contact about this tractor I really like to see it run and use it
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Workhorse has their own website. And many forums. Great robust little tractor good luck with it
Posted on May 02, 2017
SOURCE: Craftsman Lawn Tractor - Electrical
make sure you mower deck is not still engaged. that might make it not start with that safety switch.
Posted on Oct 04, 2008
chad7houston
  • 62 Answers
SOURCE: Toro lawn tractor : tractor will not start
On most riding mowers there are several switches that must be actuated before it will start. First, make sure that blades are disengaged. Also, if there is a handle that engages and disengages the blades, you might try holding it in the dis-engage position in case the switch is out of adjustment. There is probably one under the seat also. This switch kills everything if you are not sitting in the seat for safety reasons. The switch here could be out of adjustment or mis-positioned. Also, make sure the parking brake is set, and the gear is in neutral, and not forward or reverse. Also, even if the parking brake is set, you might try pressing the brake all the way down while starting, as this switch might be out of adjustment. All of the switches should be easy to locate and adjust. Also, you should check the battery. It is possible that you left the key on by mistake and drained it.
Hope some of this helps.
C
Posted on Oct 07, 2008
  • 37 Answers
SOURCE: can not remove axle cover,
Hi, easy fix you have to pry the cover off. you can use a screw driver, or a pry bar.
Posted on Nov 23, 2008
  • 79 Answers
SOURCE: What kind of oil do I use in a Wheel Horse lawn tractor?
Use 10W30 or SAE 30 oil in the motor crankcase, and the hydrostatic transmission use hydraulic oil # 10 weight.
Posted on Jun 24, 2009
outdoorsman5
  • 631 Answers
SOURCE: Lowe's MTD 1997 lawn tractor -sat about 3 years,
Does the engine spin by hand freely? you need to see if you can put a pipe wrench or channel lock pliers on the shaft of the motor and see if it will spin over freely.
Posted on Jul 28, 2009
Front axle stablizer
Every manufacturer calls them different names. i worked on trucks all my life and I would say stabilizer links or anti sway link. It is a Sears mower the model number should be under the hood kinda hidden on the side of the body. Google for a .pdf parts for that model.
Jun 09, 2014 | Craftsman 42" Briggs Stratton 20 hp Gas...
How do you manually push a craftsman lawn tractor? the back tires will not move when it is not running.
If this is a hydrostatic machine there will be a bypass lever somwhere on the tractor to dissengage the axle ( either in the back plate of the tractor, or under the seat )
May 29, 2013 | Craftsman Garden
Blown Tranaxle.
if it is still under warranty and it was from normal wear they will replace it but if not under warranty you'll have to buy a new one,and they can be costly.
Sep 25, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub Cadet LT1046 shutters when under a load, climbing steep hill
i would check the belt for oil or slipping the check rear axle fluid level
Mar 27, 2012 | Garden
I am working on cub cadet lawn tractor lt 1050. how do i remove and replace the rear axel?
Hello.
SOLUTION ON How to Remove Lawn Tractor Wheels.
Owning a lawn tractor to take care of the grass and yardwork is convenient until the tires need repairing. It is inevitable that sooneror later the tires will go flat and need replacing. You can replace the tiresonce you know how to remove the wheels on your lawn tractor. Unlike automotivewheels which have several lug nuts, the lawn tractor tire requires only theremoval of a retaining ring to release the wheel from the axle.Front Wheels
  • 1 Park the lawn tractor on a level surface. It is better to park the lawn tractor on the driveway or solid shop floor rather than the lawn. Place a floor jack under the front frame and jack the mower up until the front tires are six inches off of the ground.
  • 2 Place jack stands under the frame on each side of the jack and lower the jack until the frame is sitting on the jack stands. If the mower is on the lawn, place a piece of plywood under the jack stands to avoid sinking the jack stands into the lawn.
  • 3 Pop the axle cover off of the center of the wheel. You can pry the cover off with a small flathead screwdriver or grab the cover with a pair of pliers and twist the cover off of the axle.
  • 4 Pull the retaining ring from the axle with a pair of needle nose pliers. Grab the ring from the closed side and pull the ring straight from the side of the axle. If necessary, use a flathead screwdriver to aid in spreading the open part of the ring so the ring will slide off of the axle.
  • 5 Slide the two washers off of the axle and then pull the wheel off of the axle.
Toolsneeded to solve the problem below. Floor jack,Pair of jack stands ,Small flathead screwdriver ,Needle nosepliers ,Vice grips
THEN SOLUTION ON How to REPLACE Lawn Tractor Wheels.
Thanks
Sep 15, 2011 | Garden
Steering, The right front axle and tire lean in as if I were turning the steering wheel in the left direction but the left axle and tire remain straight. If I turn sharp to the left the right tire turns...
1) there are also bushings which hold the axle assembly into the front cross member, take a look at those.
2) while you are at it, replace the front wheel bearings on both sides
Aug 07, 2011 | John Deere Garden
The blades are cutting unevenly
I know this will sound a little crazy, but check the air pressure in you tires. My neighbor had the same problem. The tires looked okay until he sat on the mower. One of the rear tires was low which caused the mower to sit lower on one side. Next check the linkages on the deck to make sure they are hooked up and haven't fell off.
Apr 28, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lowe's MTD 1997 lawn tractor -sat about 3 years, replaced battery and starter. Motor does not turn over?
Jul 28, 2009 | Mtd Arnold Oem - 190 - 784 2 Wheel Weights...
I have a OLD Craftsman lawn tractor 36'' Drive belt diagram ?
go to sears.com click on parts and enter your mod#
Apr 19, 2009 | Garden
Garden Logo
26 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
