Question about SanDisk Sansa Shaker SDMX9N-512 MP3 Player
SanDisk wont turn on
When you try to turn it on it makes a noise then goes right back off. I have replaced the battery and it still dont work. If you remove the memory card the light flashes until you put it back in
    Genius:
  • 1,224 Answers
This sounds like 3 problems
1 battery power
2 upgrade software back up files
3 corrupted files
Posted on May 20, 2008
My sandisk wont cut off snadisk keeps flashing across the screen. And it says No songs.
Try resetting it:
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
If That does not work try this:
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the SanDisk website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Sep 30, 2009 | SanDisk Sansa e250 MP3 Player
My sansa shaker wont work
Make sure the songs are in the right file format first. I would only download songs that are in mp3 format for starters. If it is still not playing, follow the reset method that the manual suggests. If it is still not working, it may be defective. These "windowless" players are the most difficult to use, because there is no on-screen display to let you know what's going on.
-Tha Mp3 Doctor
Dec 14, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Noisy fan after a few minutes start up
Yeah. i had this problem too. the fan is noisy because it is garbage. it needs to be replaced if you want to get rid of the noice. you moving the laptop wen the noise first started is just coincidence. the heatsink is fine, but the fan itself is poorly made. The ball bearings get loose and so the fan doesnt stay in its vertical plane and it kind of shakes a little, thats why it makes the noise. if you open it up and turn your laptop on, and wait for the noise, you will notice that if you push down lightly on the center of the fan, the noise goes away, because you are creating pressure at it's center of gravity point which makes it stop wobbling. you wont see the wobbling with the naked eye, because its much to slight to see, but its definatly enough to make that annoying fighter jet take-off noise..
as far as the noise, thats the sound it makes when something is wrong with the battery (if you ever drain it all the way down and try to boot it, it will make the noise) kind of messed up noise in my opinion, but its not a big deal, as long as it doesnt repeat.
for the fan, you dont need to replace it if you dont use your laptop a lot, you can try to keep your laptop cooler to keep the fan from turning on also. i suggest one of those USB fan pads that you put under the laptop, or a thermal pad, thermapak makes one for $30 i think, and it drops temps by 6 degrees celcius they claim, i dont know exact numbers but if def helped me. you can also try to put something in the back to keep the back elevated (where all the heat is) and the fan wont spin as much.
i know with desktop fans that get lots of use, noise is the 1st sign of fan failure to come, but ive been using my laptop with that god awful noise for about 4months now, and its still alive and kicking.
good luck!
Aug 24, 2008 | Acer Aspire 5100-5033 Notebook
Does dont....
Try changing the battery. After a year or so of use, any battery goes bad, and needs replacing.
Dec 22, 2007 | SanDisk Sansa c200 MP3 Player
Wont turn on
Make sure you dont have the device locked. There is a switch on the top of the unit
Jul 26, 2007 | SanDisk Sansa e260 MP3 Player
Doesnt do anything but boot to language screen
wen it freezes just hold the power button for about 15 seconds.
Mar 12, 2007 | SanDisk Sansa e250 MP3 Player
I hate blue
goes off because the backlight is on a timer. after 20 seconds or so it turns off if no buttons are pushed. if the player will still play music but nothing shows on the screen, then the display is shot. The screen is not replaceable on these players. sorry, but it's most likely junk now. You could use it as a data storage device still. Best bet is to buy a used player off ebay or amazon.
Feb 11, 2007 | SanDisk Sansa e130 MP3 Player
My sansa M240 WonT turn on all the way
Jan 21, 07 I called and spoke with a Sandisk rep on Jan 16 about the "Sansa m240 startup screen" freeze-up problem that so many are experiencing. He said a bad batch was sent out in early December and on those m240's there is "NO POSSIBLE FIX" for that problem, but no plans for a recall. He said he could not discuss what the problem was, but I guess it would be a hardware issue, since a firmware issue could easily be resolved. He said anyone with this problem is requested to call Sandisk and get a MRA number, then return the m240 to Sandisk for a replacement. If you have one that's frozen on the Sansa m240 startup screen (all other freeze-ups can probably be corrected) take it back to your place of purchase or call Sandisk immediately.
Dec 27, 2006 | SanDisk Sansa m240 MP3 Player
Frozen SanDisk c140 MP3 Player
make a prgram can enter to the mp3 player then make a new program for format all things in it.
Oct 16, 2006 | SanDisk Sansa c140 MP3 Player
Its dead with no special reason
Here is information I used from another user of this product who had this issue
Here is a fix I got from Sandisk support:
Let's try this: take the battery out of the player and wait for a full 5 minutes. While the battery is out, please hold the power-on button for 10 seconds. After that, connect it to your computer1.gif (without the battery). Does it work when it's connected to the computer?
Regardless of that result, disconnect it from the computer, then put a brand new alkaline battery back in, and see if it will turn on.
Now, another thing I found that worked once, was to remove the battery, hold the power button for 5 seconds, then replace battery. The unit powered up after that.
Jan 04, 2006 | SanDisk Sansa e140 MP3 Player
SanDisk Sansa Shaker SDMX9N-512 MP3 Player Logo
48 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
