Question about Canon MP560 All-In-One InkJet Printer
Does not feed the paper. Canon mp560 - Canon MP560 All-In-One InkJet Printer
pineworks
  • 4041 Answers
SOURCE: paper won't feed through canon printer. no paper jam apparent -
Hello there gave it a go this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
SOURCE: canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Posted on Nov 10, 2009
SOURCE: Canon MP560 brand new. Don't have booklet
reach behind where scanner hinges on back of printer in middle and gently pull up. Once it's completely pulled up -- about 6 inches, you can let it fall back away from the printer and the top portion folds out. You can feed paper in from the back that way.
Posted on Apr 17, 2010
caroldon
  • 17129 Answers
SOURCE: Canon MP560 paper jams and
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction
Posted on Nov 01, 2010
  • 3278 Answers
SOURCE: black inkjets not connecting with
Hello.
Inkjet printers have the major disadvantage of having often having clogged print head cartridges that can be very annoying in the long run. Though advanced inkjets might possess their automatic print head cleaning process, this might not work every time. The problem might be because a layer of thick ink might have blocked the holes of the printer head.
There are some useful ways to get the printer's head clean without having to buy another cartridge.
Using a syringe and some alcohol to unblock the holes can be a very effective solution.
Step 1: Remove the cartridge from the printer
Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
Step 5: Run some test prints before using the printer normally.
Hope this helps.
Posted on Jul 25, 2011
My canon mp560 won't load paper
Does it even try? If so, likely the rubber rollers need to be cleaned.
Sep 12, 2014 | Canon Eos 50d 15.1 Mp Digital Slr Camera...
I get a "no paper" message from my Canon MP-560 when there is paper in the rear tray. What can I do to fix it?
make sure paper is loaded in right port and paper is inserted all the way. try a few pages at a time, and refer to manual on proper paper path information.
Apr 30, 2014 | Canon 3747B002 - Pixma Mp560 Clr Inkjet...
My canon pixma MP560 is not printing black even though I have a full cartridge
Remove your black cartridge and check that the ink might be over flow or block.... so clean it up with soft paper... thanks
Aug 31, 2011 | Canon MP560 All-In-One InkJet Printer
My canon MP560 thinks that there is no paper loaded when I have the tray full. How do I get it to believe that there is paper?
Theres a cassette underneath and a sheet feed from the back. Make sure you have paper in the cassette tray, when it says cassette tray empty.
Nov 05, 2010 | Canon MP560 All-In-One InkJet Printer
I cannot get the paper to load into the printer
I had an issue with the cassette tray paper feed. I loaded paper in the rear tray, manually used the printer properties button to make it print from the rear tray and printed from there. The next day I manually did the same thing but forced it to print from the cassette (bottom) tray. It worked fine today. It no longer thinks that there is no paper and the rollers are picking up the paper edge for proper feeding of the paper. I did not go through the roller cleaning procedure but I would do that if switching back and forth manually between trays doesn't work.
Sep 20, 2010 | Canon MP560 All-In-One InkJet Printer
Is there anyway to enable the 3650 printer to print on Kodak Premium Photo Paper. Paper weight 66 lb. thickness 8.5 mil. Printer jams each time I try to print
Hi Jerry
This is a budjet printer and ity's not really made for anything ohter than standard weight 'copier' typer paper.
66 lb. paper is equivalent to 240G paper here and that doesn't go though machines easily unless the paper feed is from the back. HP printers traditionally roll the paper around a roller and feed it back on itself. This paper (it's almost card) is too thick to go around the roller.
If you want to print a lot of this paper you are going to have to buy a new printer. I would recomment a Canon MP560.
Aug 09, 2010 | HP DeskJet 3650 InkJet Printer
Canon MP560 brand new. Don't have booklet available. How do I load the paper from the back? Thank you!
Feb 23, 2010 | Canon Office Equipment & Supplies
Starts to feed paper and then stops and says it is jammed, it's not.
We have become aware of an incompatibility between the ZoomAlbum software and the Canon PIXMA printers listed below. This issue applies only when using the ZoomAlbum software to print Photo Album covers with Mac OS X.
Affected Models
PIXMA MP240, MP250, MP480, MP490, MP560, MP620, MP640, MP980, MP990, MX320, MX330, MX860, iP3600, iP4600, iP4700 Printers
Phenomenon
The affected PIXMA printers are designed to feed paper via the rear tray with a center-feed mechanism and two paper guides. However, the ZoomAlbum software was intended to feed paper from the rear tray in printers with a right-feed mechanism and a single paper guide. As a result, when using the ZoomAlbum software with Mac OS X to print Photo Album covers with the affected Canon PIXMA printers, the printed image may shift.
adv_zoomalbum_1.jpg Countermeasure
To remedy this problem, please use the following settings when printing Photo Album covers with Mac OS X:
1. Click System Preferences
2. Click Print & Fax
3. Select your Canon PIXMA printer as the default printer
4. Select DL Envelope for Default Paper Size in Page Setup
Note: Be sure to change the Default Paper Size back to Letter after printing the cover.
Jan 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP560 All-In-One InkJet Printer Logo
1,012 people viewed this question
old marine
old marine
