Question about Dryers
The dryer motor dosn't come on but the heating element comes on even if the door is open
  • Dryers Master
  • 2,180 Answers
First off what is the model number?if it's an older dryer check the door switch,move the paddle in and out,if it doesn't click then you need to change out the switch,also if that's ok the heater could be grounded to the frame,is this happening when you push the start button or is the heater on all the time?
Posted on Sep 04, 2010
  • 3 more comments
  • seime Sep 07, 2010
    The Dryer is a Kitchen Aid and the model # is KEYS750GQO Thanks The heater does come on all the time even if the door is open
  • Sal DeAngelo Sep 07, 2010
    you need to change out the heating element part number 279838 and it's around 55 bucks.one of the coils on the element is touching the casing which is connected to the frame and shorting it out and by doing this it has power to it all the time until the timer is in the off position.pull out the dryer,,take off the vent line,unplug the dryer and remove the back wall of the dryer,on the right hand side you'll see the heater box,i forget if there's one or two 1/4 inch screws holding that in,take out the screws,remove the wires and pull out the heating element and slide the new one in,and put it back together,but while you have it open on the left side you'll see the duct that the lint filter slides into,that should be cleaned out once every two years,take out the lint filter and the two phillips screws that are in front of the filter on top,then take out the four screws usually they're 5/16 inch but some are 1/4 inch screws,some of the ducts pull out and can be removed and some can't,if you can't remove it slide it over to one side and vac it out,if you have a shop vac blow it out and then vac it again and blow out the blower wheel,also if the vent line is a long run from the back to the outside vent i use a leaf blower to blow out the line,just make sure the outside vent is clear.now you can put the back together,when it's back together just don't put the two top screws in yet,with a screw driver pop the top panel up,tyhere are two clips one on each side around two inches from each side,just put the screws driver in the seam and pop it up,then unplug the door switch harness,i stick a thin screw driver in the plastic and separate it and then pull it apart,now take out the two 5/16 inch screws one on each side around four inches down from the top,then grab the front panel and pull on the left side and then the right side,there are two clips in the bottom that the front panel hooks onto and remove the panel and vac out the inside of the cabinet.you can put the shop vac on blow and blow all the lint on the motor and that's in the back forwards so you don't have to pull the drum and belt but it's easier if you remove them but some people have trouble getting the belt back on.if you do this every two years your clothes will dry on time,you'll almost never have any problems with the dryer because it won't be running hotter than normal and you won't have a dryer fire.let me know how you make out
  • seime Sep 09, 2010
    Would the heating element make the dryer not run also? Because it heats all the time whether the door is open or close will stop heating if you turn the timer off. I put a new motor, fan and belt on and it still doesnt run.......or do you think my problem is a motor relay or a timer?
  • Sal DeAngelo Sep 09, 2010
    the dryer has 240 volts going to it,did you check your house fuses or braker box?i looked up your dryer and i didn't see any motor relay in it,you need to check with a meter to see if power is going down to the motor,a broken door switch would make the motor not run and if the heater is grounded it would stay on even if the door switch was broken.also did you check the high limit thermostat on the heater box,the part number is 279816 and it comes as a kit with the two t-stats together that you change out,pull at least one of the wires off and with the dryer unpluged check the t-stats and change out the heating element,or you could have a shorted wire somewhere and that's why the heater is staying on and the motor isn't running but you need to check this out with a meter to find out,so you could have a short somewhere,you could have a grounded out element and a cooked t-stat mostly if the dryer is clogged with lint,you could have a bad house fuse or a cooked wire in the back where the plug connects to the dryer,also check the door switch,do you live near boston or around the area?i'm in cambridge,you need to get someone in there or sheck it with a meter yourself,you changed out most of the parts already and if you used a meter you wouldn't of had to do that.i don't think it's the timer i think you have a short somewhere,let me know what you find,if you're near me i'll come take a look
    also check the thermal fuse in the back of the dryer it's white and the part number is 3392519,pull one of the wires off and read it out with a meter,also when you put the dryer back together did you plug in the door switch harness?let me know what you find
Mde3500 Electric Dryer will not heat
it sounds like the door switch itself is good but has a poor connection after the switch. That would explain why the momentary light flashes. The heating element will not start unless the door switch is sending a constant closed signal. Check your wiring & control board.
May 02, 2014 | Maytag Dryers
Heat element cycles when it should be off even with door open
First question, when you open the door does the drum continue to turn? If so then the door switch is bad and the machine thinks the door is closed and operation continues. If the drum stops and the element comes on anyway you need to unplug the machine, and more than likely you have a major short, probably in the motor area which is where the element gets power as well, and either call a proffesional or get a new dryer. Tracking down that sort of thing is a time consuming pain and shouldnt be done by anyone except a well qualified tech.
May 27, 2012 | Kenmore Dryers
The dryer is turned off and the door is open and there is still heat. I have to uplug the dryer in order for the heat to stop. We noticed this one morning, walking into our laundry room. (This was on...
I assume it is an electric dryer with 240 volt plug ? My guess is that it is the contacts in the motor start/relay switch that have welded themselves together and when the motor stops, the heat does not. This switch is located on the motor and it only allows the heat element to operate if the motor is running and creating the air flow. It is worth replacing. Goodluck, Macgivor
Jan 31, 2010 | Dryers
My maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
Oct 20, 2009 | Maytag PYE2300AY Electric Dryer
Heating element heats up, but dryer will not spin.
Since you stated that the heating element is heating up I believe it rules out the thermal switches.
When you push the start button does it make the motor make any noise? Maybe hear the motor humming? Two things to check for are Broken Belt or Bad Motor:
This requires common sense and since you are going to be bypassing the safety features you need be CAREFUL.
First, with door open, manually press in door switch to by-pass door safety, then press "start", try to manually start the dryer by spinning the drum by hand, If you hear the motor humming but it does not start spinning on it's own; most likely it is a broken belt which can be changed without much difficulty for less than $15 bucks. NOW if it then continues to spin on it's own GET YOUR HAND OUT OF THERE and close the door; you have a bad motor and even though it started it needs to be replaced. A motor for that is available for just under $100 bucks and is not to bad to replace, I would recommend replacing the belt at the same time since you will be in there. Good Luck!
Apr 29, 2009 | Whirlpool LEQ7030KQ Electric Dryer
Kenmore electric dryer model#96260100
tim, check to see if your motor switch is stuck. it allows the other power leg to be sent to the heater. comes on when the motor starts turning and releases upon the stopping of the motor. other power leg comes through timer, hope this helps.
Aug 27, 2008 | Dryers
Whirlpool dryer won't run
This sounds like something may be mis-wired...or there may be a defective switch contact in the timer or one of the other controls. If the heater element comes on with the blower motor not running, it should quickly overheat and trip one of the thermal shutoff switches.
Feb 01, 2008 | Whirlpool LER5636P Electric Dryer
Electric Clothes Dryer Problem
if the dryer worked fine before with the element not staying on when you open the door, etc, then what you have done is a very common mistake to make, you must have dislodged a wire off, or maybe placed one back in the wrong place, its a very easy error to make, which is why when removing parts for repair on any appliance you must make very detailed notes, better still take digital photographs with a digital camera double check any wires etc, don't worry i am a retired appliance engineer and even we can make this mistake
Sep 29, 2007 | Dryers
Dryers Logo
52 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
