Question about Sony RM-VL900 Remote Control
RM-VL900 System Control won't program anymore.
I can no longer program macros. I can use other remotes to "teach" single commands to the System Control buttons—or to other button assigned to a macro. Until now, I’ve also been able to reprogram series of commands.
This has to be my fault. Everything else is working fine. All 12 of my RM-VL900s wouldn’t go bad at the same time.
To test the macro function in its simplest form, I've reset one RM-VL900 to its factory default settings and then tried to program this simple macro: TV "ON," followed by TV "TV/VIDEO. It doesn't matter that I don't have a Sony TV set. I just want to see the TV Component button flash once for "ON" and again for "TV/VIDEO"—as I’ve always been able to get the thing to do.
I bet many people who have used RM-VL900s for more than a few functions have discovered the same thing I did first time I programmed mine. You have to finesse some programming steps. For example, when deleting a single button assigned to a given component, it may not work to follow the prescribed procedure:
1) set all the component buttons flashing and then
2) press the component button while (taking care to hold it pressed) also
3) press the button to be erased.
You may have to press and hold the component button and almost immediately release both buttons—as quickly and simultaneously as possible. Carrying out the same sequence at a normal pace may not work, even if you’re as careful as possible and repeat the procedure numerous times.
I’ve discovered other necessary tricks, variations in timing and sequence that work when the prescribed steps fail. Trying such variations, I was just now able to program a macro for one TV set on one remote. Such variations, sadly, were apparently so subtle that I can’t reproduce them on other remotes for other TVs.
It doesn’t mean I’m not missing something simple just because I’ve learned some work-arounds, almost memorized the manual, and read everything I can find on the Web about programming the RM-VL900. In the past it has been easy to program series of commands, but I need help now.
    President:
  • 2,712 Answers
Hello drumrunner,
Maybe THIS link may provide some assistance..
Cheers!
IrishDruid
Posted on May 11, 2008
What is best remote to buy and how do you program new remote control?
Hi Dusty
You need a programable remote control
that is versatile and easy to use (touch screen)
I've had a Sony Commander RM-AV3100 for a few years
It's been great. There are probably better similar units now.
Sony Commander RM AV3100 YouTube
Mar 14, 2016 | Televison & Video
Codigo para dvd Magnavox
0028,0027,0021,0022. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 15, 2013 | Sony RM-VL900 Remote Control
I have a AVEX URC-R6 Remote controller that was working fine for almost 3 years with a DISH 722 Reciever/DVR. One morning the receiver IR would receive no signals from either the AVEX remote, or the...
trwck
I have provided instructions on how to save setting on the receiver and remote plus instructions for learning mode. I hope this helps.
Ray Calo
DISH Network
Back Up Remote/Receiver Data
  • Receiver: 222k and 722k
    1. Verify that the customer has an unobstructed LOS and is within 10 feet of the receiver. The customer will need to direct the remote toward the receiver for the duration of the System Wizard setup.
    2. Press and hold the number 0 until the pop-up 380 appears on the screen.
    3. Verify that the System Wizard says the remote is configured correctly.
    4. Select Advanced on the screen.
    5. Select "Backup My Settings Now".
    6. Verify that the purple gem is displayed beside the correct selection.
    7. Select Next.
    8. Select the type of backup to be performed:
      • Full system backup
      • Back up receiver settings
      • Back up remote settings
    9. Verify that the purple gem is displayed beside the correct selection.
    10. Select Continue twice to initiate data transfer. Maintain unobstructed LOS while the green progress bar fills.
    11. Select Continue to resume programming.
  • Restore Receiver Data
    4. Select Restore on the screen.
    5. Maintain unobstructed LOS while the green progress bar fills.
    6. Select Continue to resume programming.
  • Teach Learning Commands
  • Receivers: 222k and 722k
    1. Ensure the DISH Network remote control is programmed to the desired remote address to operate the DISH Receiver.
    2. Place both the DISH Network remote and the original equipment's remote control on a flat, stable surface.
    3. On the DISH Network remote, press and hold the mode button for your equipment for about three seconds until all of the mode buttons light up, and then release it. Your selected mode button will blink.
    4. Select the type of learning you wish to perform:
      • Hybrid Mode
        1. Press and release RECALL, then hold the RECORD button for about three seconds until the mode button is lit again. The button remains lit while learning.
        2. Point the front of the original equipment's remote to face the small square (IR window) on the front left-hand side of DISH's remote. Remotes must be within 4 inches of each other.
        3. On the DISH Network remote, press the button you want to teach.
        4. On the original equipment's remote control, press and hold the button you want learned. If the DISH Network remote learns the command, the mode light blinks off and then back on. If the mode light blinks three times or remains lit, the DISH Network remote did not learn the command. You may need to press the button on the original remote several times for the DISH Network remote to learn the command.
        5. After a button has learned a command successfully, repeat steps 3 and 4 until all commands you want have been learned.
        6. To end the learning sequence:
          • Press one of the mode buttons on the DISH Network remote. This saves all of the commands for that mode and exits learning to return to normal remote control operation.
      • Normal Mode
        1. Press and hold the RECORD button for about three seconds until the mode button is lit. The button remains lit while learning.
  • Mar 25, 2011 | DISH Network ViP722 DTV Receiver /...
    WE BOUGHT SOME USED TVS FOR OUR MOTEL AND NOW WE CAN'T PROGRAM THEM WITH OUR UNIVERSAL REMOTES...DO WE NEED TO PURCHASE THE eUR501371 REMOTE CONTROLS.
    you can buy any branded universal remotes
    like panasonic EUR501371,Philips Magnavox Universal Remote PM335,PH310s,sony RM-VL700,RM-VL900 etc.. they work better than local brands..
    hope they will solve your problem
    regard,
    cseian
    Jun 09, 2010 | Panasonic EUR501371 Remote Control
    Hi we moved and lost the manual I need help geting a copy of the manual and codes for a Sony RM-VL900 Remote Russ
    Use this LINK and will take you to the codes for your remote.
    Good Luck and please rate this solution...
    If you need a refresher on the steps to program the codes click here....
    Jan 08, 2010 | Sony Televison & Video
    Logitech Harmony One remote is controlling 2 TiVOs at once.
    Please try learning the some commands from one of the original remotes for thr tivo. If this fixes the problem, i suggest that you learn all commands from that remote.
    Launch the Logitech Harmony Remote software and login to your account
    1. Click on the Devices tab
    2. Click on the Learn IR button for the device you want to learn command(s) to.
    **NOTE: When learning new commands, there are three different options available:
    -You want the Harmony Remote to learn a single command that is already listed in the software
    -You want the Harmony Remote to learn more than one command at a time
    -You want the Harmony Remote to learn a new command, which is not listed in the software
    a. Click on the Learn button next to the command you want to learn - Proceed to Step 5
    a. select one or more commands by clicking on the check box next to the command(s) you want to learn and then
    b. click on the Learn Selected Commands button
    c. Proceed to Step 5
    You want the Harmony Remote to learn a new command, which is not listed in the software:
    a. Scroll down to the button of the page
    b. In the Learn a New Command box click on the text MyNewCommand
    c. enter the name of the command you would like to teach.
    d. Click on the (Learn New Command) button
    e. Proceed to Step 5
    5. Follow the onscreen directions for learning commands, plugging in your Harmony remote when asked and lining up your original remote to the Harmony as illustrated on the screen.
    6. When a command is successfully learned, a check mark will appear next to it. If learning more than one command, the software will then prompt you to learn the next command.
    7. The commands that were learned should now be identified as from "Your original remote" and highlighted in turquoise.
    8. When you have finished teaching the commands, click Done button to save your changes
    9. Click on the Update Remote button to update your remote
    If this does not work, try :
    To teach commands for your Device that did not work properly in normal mode:
    1. Click the Devices button on your home page.
    2. Select the Device you wish to learn commands to.
    3. Select Learn Infrared Commands.
    4. Click Custom. The page will reload.
    5. Select the boxes for commands you would like to teach, and click Learn Selected as Raw.
    NOTE: When teaching each command, press the button on the original remote for as long as required to control the device. The commands will be learned with the exact format that is sent by the original remote.
    If you have any trouble teaching the commands in RAW, complete the following steps:
    1. Verify you are pointing the original remote at bottom end of your remote, and are holding the remotes 2-4 inches apart.
    2. Minimize the amount of light that could interfere with the learning process by covering the distance between the remotes. Block out sunlight, or turn off the lights.
    3. Check that you have installed new batteries in the original remote you are trying to use to learn commands. If the batteries are low, the signal coming from your original remote may be too weak for the remote to detect.
    4. Be sure to hold down the button on the original remote for at least 1-2 seconds, otherwise the signal may be too short for the remote to process.
    5. If you continue to have trouble teaching the commands, start with the remotes 2 inches apart. Then try again with, slightly increasing the distance each time (2.5 inches, 3 inches, etc).
    6. Vary the angle at which the original remote is pointing at the bottom of the remote.
    7. Ensure the device's original remote is sending infrared (IR) commands.
    NOTE: The original remote is sending RF or UHF commands from the original remote if it will control the device from another room, through a wall).
    Oct 04, 2009 | Logitech Harmony One Advanced Universal...
    Code no.?
    This information is to search for any code using the SONY RM-VL990T Universal remote:
    Using the code search function: Press [S]. All Component Select buttons will flash. Press the button you want to configure. Press [CH+] or [CH-] and [POWER] in turn until the component turns on or off, then press [ENT] to save.
    May 09, 2009 | Sony RM-VL900 Remote Control
    Unable to program Universal Remote. provided codes do not work.
    Problem solved. I decided to use the learning function of my remote to learn the wanted commands of the original remote. The remote I used was a Sony RM-VL610 which could learn the original remotes functions easy and quickly. This is a very good remote for only $30 purchased at Target. The Macro commands were also entered rather easily. I did not try this method originally,because I thought it would be too time consuming and difficult.
    pcwg
    Jan 09, 2009 | Samsung BD-P1200 Blu-Ray Disc Player
    "AMP" button on Sony RM-VL 900T stopped responding
    To reset all functions for a Component: Press and hold [S] until the green indicator lights. All Component Select buttons will flash. While holding [STOP], press the desired Component Select button.
    Dec 27, 2008 | Sony RM-VL900 Remote Control
    Sony remote commander RM-V310
    You can get the manual and the codes at Retrevo.com
    Feb 12, 2008 | Sony RM-V310 Remote Control
    Sony RM-VL900 Remote Control Logo
    127 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
