Question about Bosch Ovens
I have a bosch oven, HBN22.B AU.The inside glass of the door has come loose from the door frame, it looks like 2 sided tape has given way. Where can I get this adhesive from or can I use a eurathane adhesive & where can I get it from ?
  • Bosch Expert
  • 414 Answers
You can use a silicone adhesive as long as it's heat resistant.
I'm in the uk, but I have added a link for an au product as an example, all the best.
http://www2.blackwoods.com.au/infoBANKProduct.aspx?SG=2000165&S=4084745&G=2004222&P=7741858
Posted on Sep 05, 2010
Testimonial: "thanks for your reply, very helpful."
I need to know how to clean between the inside glass of the oven door
Open the door and you will see screws at the inside edges of door.Remove screws and inner door frame will separate to access the glass.Take picture of assembled door before you start.This will assist you in putting back also if screws are not the same note where each belongs
Feb 02, 2018 | Ovens
Need to reattach glass panel on oven door
You may have to contact Bosch directly to obtain a diagram and/or instructions.
Aug 27, 2017 | Bosch Ovens
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
Where can I get a heat resistance double sided tape to affix the external glass of the oven to the SS frame on my slide in GE stove .
Most of the time that GE attaches any type glass to hot metal these days they use silicone seal. It is uses to attach glass cooktops into the metal frame of the cooktop. Get a tube of GE clear silicone seal and glue the glass around the complete edge getting a good seal and contact at the glass edge and metal panel. Let it dry 24 hrs before reassemble. The silicone seal turns to rubber when dry and is quite heat resistant. It won't stand up to direct flame but should hold your glass well.
Apr 27, 2015 | GE Ovens
How do i replace kitchenaid superba microwave torsion spring
This is tricky if not done in correct order real easy to break the plastic door frame I will try an explain best I can there is a vent cover between MW door and oven door remove on the MW bottom frame there is a tab on each side with a small screw remove screws you can now pull MW forward won't move very far now the plastic piece that connects to door look up at bottom remove these 2 screws it will be at an angle I use a small speed wrench with a phillips bit okay all this is loose now open the MW door towards top there are 2 holes inside each is a phillips screw use a skinny screw driver hold the door tight it is spring load the frame part with glass will try to slam forward door should now be free usually only one spring is broken change both they are not the same different part numbers take a picture first before trying to remove you will eventually figure out that you have to put in hole at one end and thread thru to the other end then twist in place to lock now be careful if you slip real easy to break inner glass once you figure all this out put the door back in the exact opposite order starting with the door screws first you will now find out the door has a high spring load i usually mate the door to the frame and secure with tape after door is on then do the 2 screws on bottom of plastic frame do the sequence backwards you will break this piece, best i can do yes a lot work but remember I do this about 3 times a week I suggest you think about paying an appliance repair company to do this reason being that plastic piece i keep harping on is roughly 100.00 to replace which negates most savings by doing it your self hopes this helps good luck
Feb 16, 2015 | Ovens
Need to glue outer cold glass door to the door frame.. in cadco convection oven
not sure which to use but id go to a window auto glass shop and inquire
Dec 12, 2012 | Cadco Ovens
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
How to clean the inside of the glass door of Electrolux Wall Oven
I scoured the internet trying to find how to clean inside the glass of my Electolux Icon double wall ovens. Short of "The Big Q-tip" method (which only made a smeared mess) I didn't find anything. So I went ahead and started taking the doors apart. I'm happy to report I just finished with fantastic results. So I'm going to do a step by step, I know I would have appreciated reading instructions for it. It's very easy but time consuming. You'll need a large work area because there are actually 4 sheets of glass, a Philips screwdriver, and a straight razor with handle.
Refer to your manual on how to take the doors off - but it's very easy. Simply open the door, flip the locks toward you and pull up and out at the same time. Be careful...the door is very heavy.
Lay door on blanket or towel, especially if it's stainless steel. There are 4 screws along each side of the door. The 2 screws that hold the hinge at the bottom are smaller than the 2 closer to the top.
On the very bottom there are two more screws to hold the bottom outer frame. Under that piece are 2 more screws that hold the inner bottom frame. That's it. Slide out the hinges and you're ready to go.
Remove those 2 frame pieces and keep in mind how they fit back together. Remove the top piece of glass and put on another towel. Now I'm not sure if it matters but I was mindful of the side of each piece of glass as I remove and cleaned them to make sure they went back exactly as they came out.
The first piece is going to be the most time consuming to clean. One took me over an hour. The grease is hard to get off because it just spreads around. I found a straight razor really sped this along, just make sure you always use the razor on wet glass or you'll scratch the glass. It's fiddly...just keep at it. I also used mineral spirits to help degrease. When done I laid this on the dining table.
The next 2 pieces of glass are in a frame that comes out together. The frame is only on the sides so be careful it doesn't come apart on you when carrying it. Inside the frame piece is a rubber gasket to separate the 2 pieces of glass. Watch how the frame comes off, there is a wide and a narrow side. It's easier to take off the frame piece and simply lift of the first piece of glass. The bottom piece of glass sits in a channel of the rubber gasket.
Pretty simple. Lots of elbow grease if you cook a lot. Reverse the order to reassemble. One thing to note - on the door sides near the top, you'll see a silver metal piece inside the black frame. Make sure the screw holes are visible thru the black frame. I have very small fingers so it was easy to do it with my fingers but I would imagine someone with large hands will have some difficulty. Also, when screwing the hinge in place I had to twist the hinge so the screw hold was up against the black frame. The screws are so short that they'll just spin without catching if you don't.
Happy cleaning!
Mar 21, 2009 | Electrolux EW30EW65SS Stainless Steel...
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Broken inside glass of oven door
Most units use Torx screws to hold the door together from the inside. Open the door, use tape to restrain the inside of the door or get help. Remove the 4 screws and the then remove the panel. Should be easy from there.
Dec 06, 2007 | GE Profile JT952 Electric Double Oven
Ovens Logo
860 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
