Question about Fisher and Paykel GWL11 Top Load Washer
Water leaking from bottom of machine however I cannot find a leak when inspecting from the bottom with the machine tilted back. Fisher & Paykel model GWL11. I have not been able to determine when ( operating or static ) the leak is active
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now have you checked for the leak where the drain hose comes out of the case of the machine? It is located at the back top left of the machine.Have you checked the inlet hoses at the tap end and the machine end?Rub the inlet hoses with your hand from the tap to the machine on both hoses to feel if there is any water on them.Check the nozzle under the lid where the water comes into the machine to see if it is not loose or broken.Please reply and let me know how you got on and If you need further help.Looking forward to your reply.
Posted on Sep 04, 2010
  • w_schuh Sep 04, 2010
    Hi, I have metal braided hot
  • luisa_sgro Sep 05, 2010
    Hi just read your last posting.Sorry to ask you these questions again but have you checked the drain hose near the frame and the inlet hoses and the nozzle under the lid?Please reply with additional information on the questions and I am sure I can help you rectify the problem.
Replaced drain pump, still leaks water
Is the door seal the issue here, it is a common source of leaking water.
Jun 09, 2016 | Fisher and Paykel Washing Machines
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Leaking fisher & paykel smart drive 501
Check your hot and cold hoses at the back for leaks,
these are just crimped on plastic ends and can crack and leak..
Jan 13, 2013 | Fisher and Paykel Washing Machines
Fisher & paykel fault "F1" is displayed on the top
hello
F1 means the flood sensor senses water at base of machine at PC board.
You need to take out bottom drawer and check for water puddle under where the drawer was.If there is water you can get the machine going again by comletely drying it out(F1WILL CLEAR),but it still means you have a leak.With bottom drawer out you can really see whats going on.Once F1 is clear you can actually run upper drawer and see if it leaks.Most likely culprit are the lid actuators.Replace all 4 . It'll run like new.Don't overload drawer .That can cause lid leak too.Also the PC board may be damaged and may start to go crazy giving fake F1 codes.$80 easy fix.
good luck
Jul 27, 2011 | Fisher and Paykel 23 in. DD603H SS...
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
I have an Aquasmart W80T65C. After each load there is a small amount of water under the machine. The water is dripping off a black rubber elbow at right rear of the machine.
Hi - if you could try this - fill the machine with water and leave it overnite to see if there is any water on the floor.
Yes - then just tilt the machine on its back & find the leak.
No - then there is a small hole on the drain hose, this will be due to the movement of the bowl - rubs against something and over time springs a leak.
My washer has one on it now - just located the pin hole & wrapped duct tape around it - works fine for us.
Jun 22, 2011 | Fisher and Paykel Washing Machines
I've got a Fisher and Paykel MW051-U washing machine. Everything seems to work fine, but after each wash cycle i notice that it is leaking water, i've tilted it and confirmed that the water is coming from...
access through the back panel to have a look at the drain pump which is likely your fault. Run a cycle and watch it when it drains you will likely see water leaking from the pump (about $25 and easy to change)
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
GWL11 Washer. Leaking from bottom. Doesn't appear to leak during wash cycle.
Have you checked the pump on the bottom of the washer? You may have to empty the water out of the unit by hand. Then tilt the machine backward. The pump is on the bottom and no tools are needed to remove it. If the pump is wet or rusted then that should be your problem. Another way to check the pump is to remove the 2 screw ib the back of the machine on the top, and remove the electronic controlls. inside the machine is instructions to turn the pump on.
Jun 18, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel Washer Leaking
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
May 31, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GWL11 Top Load Washer Logo
188 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
