Hi I believe my lid switch is broken someone slamed the door down and apparently this is how it happen the part is grey and boxed shaped. As of now the machine will only let me fill the tank up but its not spinning or rincing because this switch is broken. Is this part inexpensive and easy to replace
    President:
  • 1,554 Answers
The lid switch costs about $30 depending on the make and model of the machine. The degree of difficulty also depends on the make and the model.
Please indicate the make and exact model number of the machine for further troubleshooting and repair advice. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions should you need further assistance. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 04, 2010
Panasonic microwave door is misaligned? does not close without slaming it, then sometimes the light still stays on and msg displays that the door needs to be closed. other times, the light goes out but...
could be a bent or broken pin in the door - its a safty issue since microwaves are harmful when the door are not shut - return the microwave to the store you purchased it from or get a new one
Jan 05, 2014 | Sharp R-1480 Microwave Oven
Message code DL F???
Hi, this is a Door Lock Failure Error.
The service manual lists the following causes:
Door Lock Mechanism is broken or removed from door.
Door Switch Unit Lock Failure-Unplug washer and check door switch, wiring connections, and the connection to the CCU (Central Control Unit (You have to remove the lid of the washer for this).
To get at the switch, you have to remove the lower front panel. These are torx, I believe 3 screws. By turning yourself on your head, you can visually inspect the lock, and manually lock/unlock to check for bind (pulling/pushing a black plastic handle about two inches long with a teardrop shaped handle on the end.
Jan 08, 2011 | Kenmore Washing Machines
Clasp to lid console top box broken. How do you
This part is available at your local Infiniti dealer. The plastic part is replaceable.
Feb 09, 2010 | 2008 Infiniti FX35
Maytag washer filled full water then just stoped
it happen to me 1 time and it was the door switch that got broken. if it is top load machine check if the door switch is broken, the lid most of the time fall down and break the switch.
Jan 19, 2010 | Washing Machines
94 toyota camry eletric window problem
Bad connection. Even worse maybe the motor brush is worn. Anyways open it and try to do a wiggle test on the wires to find out which one it is. Also tap the motor if accesable.
Aug 11, 2009 | 1989 Toyota Camry
Clothes are soaking wet because it doesnt spin.
check the door switch for broken or damaged wires. get a jumper wire to go from one wire to the other wire on the switch. If the jumper wire is connected and the washer spins out, then the door switch needs to be replaced
Jul 11, 2008 | Washing Machines
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
