Question about Huffy BMX 20" Boy's Rock It Bike
I need to know how to take a chain off without breaking it please
    President:
  • 1,514 Answers
Pull the chain out slightly, away from the bicycle frame, at the bottom just behind the front cog wheel (attached to the pedals). While holding it out turn the pedals backwards and the chain will come off.
Posted on Sep 04, 2010
Double chain stitch not working
Please give us a make & model. Also, what is it doing (not doing) that is the problem, ie thread breaking, etc. Can't do much to help without more information.
May 15, 2016 | Sewing Machines
I'm trying to figure out what is bent on my 2000 Chevy Malibu rear end.
your rear axle is out of alinement do to the fact that who ever hooked that chain used one side or the other and disalined the rear end of the vehicle it.could possibly be they used your anti-sway bar to anchor to for the chain.
Jul 15, 2012 | 2000 Ford Taurus
How doe the band on my chain break attach to my chainsaw mine is broken and i do not know how to install it. or how to get the clutch off so i can replace it
It can be a little tricky!
If you are referring to chain break band
Tools you will need:
1/2 Socket (to remove bar nuts)
T25(torq) or you can use a Flathead screw driver but is a little harder.
Remove 2 bar nuts,Clutch cover,bar,chain, 2 screws on black bar handle right behind clutch cover(this is needed because there is a hidden screw there for the chain break) You will need a new chain brake (my guess is that it is part # 530071893 aprox $15) but you will want to verify that with your model number.
You should see the chain break assembly, 3 - T25 screws are visible after the clutch cover is removed(note sometimes you have to clean saw dust to make screw head visible) the other T25 screw is hidden under the black bar handle. Once you remove all 4 screws on the chain brake you will be able to pull it off.
Installing the new one is the tricky part because if it is set(or break is on) you will have a hard time putting it on.One of the easiest ways is to focus on it near the muffler you will see that a metal 3 pronged gear fits into the plastic part of the chain break handle.and if the band is too tight to fit over the clutch drum you will have to carefully reset it by applying pressure onto the area that has the 3 pronged gear and chain break handle make sure that the handle is pushed forward all the way while you apply pressure then slowly pull chain break handle back till you hear a "snap" this resets the chain brake spring and the band should now fit over the clutch drum.Now, proceed with putting back together 4 chain brake assembly screws,2 handle screws,and bar,chain,clutch cover,and 2 bar nuts.
Please note it is important that you apply quite a bit of pressure onto chain break area where metal (3 pronged) gear fits into handle while resetting or when you reset it the metal part can cut into and damage the plastic piece in the chain break handle.
You can see a breakdown here: http://www.searspartsdirect.com/partsdirect/part-model/Poulan-Parts/Chainsaw-Parts/Model-P4018WT/1324/1503220/P0506041/00002?blt=06&prst=0&shdMod=P4018WT
Hope this helps!
Feb 20, 2011 | Poulan 18" Wild Thing Chainsaw
Poulan prochain saw I need the wheel for the chain tensioner
Following is a link to a Poulan Parts Dealer that has the adjusting wheel. I also included a pdf of break down parts list for your model. Please rate the answer on its value of help. Good Luck have a great weekend.
Order Part
Parts List PDF
Apr 04, 2010 | Poulan Pro Chain Saw 46cc 20"
Suzuki DR650RS Camshaft is broken into two parts. what could be the reason for breaking axles
In normal operation, there is no way the chain or valve springs could break a shaft. The only possibility, other than a defective camshaft when the bike was new, is that the cam chain was so loose the slack bound up around the sprocket causing enough pressure to break the shaft. Replace the chain, sprocket and camshaft and check the operation of the cam chain tensioner assembly. Please rate my answer.
Feb 20, 2010 | 1990 Suzuki DR 650 RS
I'm cleaning my MTB chain. I removed it from the front chain guard by taking out a screw. Now, it's all kinked up, and I can 't get them out.
a bicycle chain cannot be removed from the bike without breaking the chain using a special chain break tool or if the chain has a special link called a quick link that snaps apart. However, to clean a chain it does not need to be removed from the bike. Some degreaser, a stiff brush and some water as all that needed to clean the chain, then follow the cleaning with some good bicycle chain lube.
Dec 30, 2009 | kawasaki 73026-9 KDX126FS Dual Suspension...
I need to know how to adjust the chain tension
The only way to adjust the "tension" of the chain is to remove links. You will need a chain breaker tool. Shift the bike into the biggest chain ring and the biggest cog of the cassette, then break the chain, leaving the pin partially in the link but far enough out that the chain separates. Now, pull the chain together so that the rear derailleur's arm is as horizontal as possible and aiming toward the crank. Break the appropriate link to connect the chain so the derailleur stays in that position and reattach the chain using the pin you left partially engaged.
i hope this helps
-matthew
Nov 15, 2009 | Mongoose Tyax Comp Men's Mountain Bike
Gear slippage -drive gear to chain bar grates -chain doesn`t move.
Driver won't slip, your chain brake is probably on, pull break handle backwards to dis-engage the break. Is there chain oil in the oiler ? If saw has been run long enough without chain oil this would cause this to happen as well
Aug 14, 2009 | Garden
When should I replace timing belt
it is recommended that u replace at 60,000 miles
Jan 06, 2009 | 2002 Suzuki Esteem
Mazda 6 2002 model 2000cc camshaft
its a chain but the chain can break just as easy and its a pain to do if you dont know what your doing have it changed
Sep 10, 2008 | 2003 Mazda Mazda6
Huffy BMX 20" Boy's Rock It Bike Logo
88 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
