Question about Canon CLC 1120 Color Copier
Mi coper machis displays, Insert the key. but the key is inserted in to the machine.
  • Canon Expert
  • 1,326 Answers
The copier has a key hole on the right side of the copier. You need the key to allow you to use the copier. I've never had to try to by pass it. It's basicly just a switch... Good Luck with that one????
Posted on Sep 05, 2010
  • vramirezn Sep 05, 2010
    Thanks Cogz, the copier has the key in the key hole, but stills,asking for it,
Display is in 'demo mode'?
Before inserting key hold down stop key then insert key then turn off demo mode
Jun 03, 2015 | HEALTHRIDER S500XI TREADMILL Console
The display is always on when I insert the battery- How do mI turn it off?
I installed a larger 3 volt battery and put a micro switch on the positive side.
Nov 19, 2013 | Starrett D125 Digitape 1Inch x 25...
HP Pavilion dv4-1548dx no bootable device-- insert boot disk and press any key help no disk
en mi laptop hp pavili
como hago si mi laptop hp paviliondv4 sale no bootable divice -- insert boot disk and press any key
Apr 23, 2012 | Computers & Internet
U2-40 error is comming in sharp Ar235, kindly help with details
You must be reset your copier.
press,# -interrupt-c-interrupt.
Press 16 press start key.Then machine is ready.
Jan 22, 2010 | Sharp AR-5320 Black and White Copier
How do i insert symbols while texting ... I can text but cannt insert ?,=? + £
Here's how:
Enter text
When entering text, you can change the text input
mode:
• Press and hold [ ] to switch between T9 and
ABC modes.
• Press [ ] to change case or switch to Number
mode.
• Press and hold [ ] to switch to Symbol mode.
Enter text in one of the following modes:
Mode Function
ABC
Press the appropriate alphanumeric key until
the character you want appears on the
display.
T9
1. Press the appropriate alphanumeric
keys to enter an entire word.
2. When the word displays correctly, press
[ ] to insert a space. If the correct word
does not display, select an alternate
word from the list that appears.
Number Press the appropriate alphanumeric key to
enter a number.
Symbol Press the appropriate alphanumeric key to
select a symbol.
Here is a link for a free online user's manual for your convenience:
http://downloadcenter.samsung.com/content/UM/200904/20090420115654593/CMS_-_Samsung_B2100_UM_EU_Eng_FINAL_Rev.1.1_090326.pdf
Please leave us 4 thumbs up :)
Nov 29, 2009 | Samsung Solid B2100 Cell Phone
Programm the machine to show my comp name and
Press the dataregistration button,when dataregistration is displayed press ok or start.When user settings is displayed press ok/start.Scroll with tha arrows untill unit name is displayed press ok and insert comp name ,press ok.To insert fax number scroll to unit tel and press ok and insert fax number.
Aug 17, 2009 | Canon FAX-L350 Plain Paper Laser
How to open to change ribbon on a Canon mp25dv
Remove the paper tape by pulling it back out of the calculator.
Feel along the back of the calculator right below where you insert the paper tape for a ridge. Gently lift up on this ridge and a plate will lift out of the machine exposing the ribbon.
Make a note to yourself as to how the old ribbon is in the machine before removing the old ribbon. Just gently lift straight up on both of the spools and the ribbon will lift out of the machie.
When you insert the new ribbon make sure that the ribbon is feeding off of the back side of both spools. You can use a small screwdriver or toothpick etc to position he new ribbon to keep the ink off of your fingers. Make sure the new ribbon feeds around the plates on both sides of the machine and it fits behind the roller that has all the numbers on it and that the red portion of the ribbon is on the bottom.
Take the plastic plate that you removed first and insert the tabs in the front underneath edge of the case on the front and gently push the back side of the plate straight down till it smaps into place.
Refeed the paper tape back into the machine and you are finished!
Hope this helps.
Apr 20, 2009 | Canon MP-25DV Calculator
Mi samsung s750 wont transfer mi pics even after software disc
Try pulling out you're sd card and inserting it into the computer.If you have a laptop lool on th side where you insert the USB cords.
Jan 02, 2009 | Cameras
How to repair with Toshiba copier 2060
lan lam... "insert key counter" means that the machine has an external control device. Usually a small box the size of a pack of ciggerettes or smaller) with a mechanical counter that needs to be inserted into a port on the machine in order for it to operate. Companies used this to "control" and/or track machine usage by department or person. It may be that your machine has one but it's not inserted well enough, or you are missing the counter comepletely. If you don't have one of these control devices, you will probably need a certified technician to come out and disable this feature.
Oct 09, 2007 | Kyocera RI-3530 Black and White Copier
Canon CLC 1120 Color Copier Logo
27 people viewed this question
old marine
old marine
