Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Wont spin,and the water doesnt drain - Whirlpool LTE5243D Top Load Stacked Washer/Dryer
  • Whirlpool Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 04, 2010
Hi, my lg turbo drum WF8071TTP does not drain and spin, the spin light flash. please advise. thanks.
check pump for blockage or faulty,if water doesnt drain machine wont spin
Nov 01, 2017 | LG Washing Machines
I have FAFW3574k- Fills w/ water. Starts to run cycle but then wont spin. Pump sounds like its running but water doesnt come out. Thanks Jeromy
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Sep 07, 2011 | Frigidaire Washing Machines
It wont drain out the water and it doesnt rinse/spin
heatman101
Mar 01, 2011 | Frigidaire ATF6000ES Front Load Washer
Machine will not agatate when clothes are in the machine
does the machine fill up with water? if you were to put the machine in drain/spin, does it drain/spin? if water comes in and it doesnt drain/spin, then your lid switch is bad. if the machine fills with water, drains but doesnt spin, the your motor coupling is worn.
Feb 03, 2011 | Washing Machines
Will drain but wont spin
Try these
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion......
Jul 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Wont spin and drain
What brand is this? If it a whirlpool or kenmore (or roper, estate) It is you lid switch. A very common problem but is cheap and easy to fix. Get me the model number and i can give you the part number for the switch.
Nov 21, 2008 | Washing Machines
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washine Machine does not drain
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch
Mar 10, 2008 | Washing Machines
Kenmore 2 Way Tumble Action Front Load Washer
no thats two different problems. The rubber piece (boot) forms a seal to prevent the water from leaking out, that should be replaced. Water might have leaked and ruined the pump. At the end of all cycles is there still water in the tub? If so your pump is either clogged or has gone bad, and thats why the washer wont go into extract.
Jul 09, 2007 | Kenmore 44102 Front Load Washer
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
133 people viewed this question
Dan Webster
Dan Webster
Sal De
