Question about Electrolux Vacuums
Vacuum hose is clogged. Clog is too far down to dislodge with a broom handle. I tried a hanger from the other end and it will not budge. What can I do?
  • 377 Answers
You could probably dislodge it with a hand operated sewer snake used to clean drains if you have one available.
Posted on Sep 04, 2010
Hello My vacuum cleaner is not working
A common issue with vacuum's not sucking is that they are blocked. Make sure that the hoses and air passages are not blocked. Use a coat hanger as a clean out tool. You may have to disassemble your vacuum to clean it out.
Nov 26, 2014 | Panasonic Mc-Ul592 Eco Max - Bagless...
My Dirt Devil Reaction vacuum cleaner has a plugged hose.
Hi! A broom stick or something similar is probably the best tool you can use to remove a clog. Try pushing the broomstick in an up and down motion gently against the clog until it starts to loosen and slide out. If you are unable to remove the clog the hose can be replaced. I have included a link where you may go to purchase a replacement hose if needed. Good luck!
Search
Jun 06, 2014 | Dirt Devil Reaction Twin Cyclone Upright...
No suction when i vacuum. what should i check for?
Check filter and bag. Clean or replace filter if needed.
Check for a blockage in the hose. Disconnect hose at both ends. Hold one end up and drop a coin into it. Raise hose until coin drops through. If it doesn't, there's a clog. Depending on the length of the hose, you may be able to dislodge it with a broom stick.
Check the tube in the power nozzle (above the brush) for clogs. You can use the coin here too. If clogged, it can generally be pushed toward the brush with a wooden spoon handle.
The worst thing is if the fan in the vacuum has broken or worn down enough to not provide sufficient airflow.
Jan 29, 2011 | Vacuums
When I switch it on the plastic compartment which holds the bag starts to be sucked in towards the bag and there is no suction at the end of the hose
Your Hoover U5076 has a clog. Fist unplug the vacuum from the wall socket. Remove the attachement hose from the door on the head, close the door. Remove the screw just below the main bag compartment, with a phillips or flat head screw driver. Be sure not to loose the nut in back. Hold the base down with your foot and pull up on the handle to sperate the two pieces. The lower portion revieled is the exhaust for the dirt from the motor and that is where your clog should be. Use a flat head screw drive to remove what is there so you have a clean path. If there is no clog there check the up portion that you pulled off for a clog, you may need a coat hanger to dislodge the clog. Once the path way is clear you can reassemble the vacuum and it will work fine.
Apr 20, 2010 | Hoover Turbopower Dual U5076 Vacuum
My Miele silver canister vacuum has a clog in its hose. Can I fix it myself?
sure you can. get a broom handle, pound a large finish nail into the end and bend the nail into a hook shape. stick the broom handle in the hose which needs to be straight and use the nail hook to grab and pull out the clog. hope this helps you.
Oct 02, 2009 | Miele S171 Bagged Upright Vacuum
I have a serious clog in the hose on my vacuum. Now that I've found the clog, how do I clear it out? I've tried flexing the hose, which does not work.
If you can remove the hose great. I have had luck slinging it in a circle out in my yard and letting the centrifugal "force" do the work(I had a fence). Coat hangers will work. You may need to twist two together for strength and/or length. Bend the cleaning end at the tip 1/4" to the right to grip the grunge and double up your grip end and wrap with some duct tape for a handle. An easier method my be inserting a garden hose, sealing with tape and cranking the water on slowly, careful for the projectile!
Aug 17, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
There is no suction from the hose on a Kenmore Destiny Plus Vaccuum Cleaner
there is clog in the unit. Either the bottom or in the hose. If you can take hose off, stick hose on end of broom handle and push out clog.
Jul 09, 2009 | Kenmore Canister Vacuum Vacuum
I have a clogged hose. How can I take it apart to get the clog out? or what can i stick up it to get it out?
Most vacuum cleaner hoses can be unplugged at some point. One way to clear a clog is to reverse the hose & let the vacuum **** the clog out the way it went in. If you have to remove the clog manually, a length of coat hanger wire, with a small hook bent on one end, will serve. Most clogs are near the hose ends, so not much wire length is required.
Apr 14, 2009 | Fuller Brush FBPTCAN Bagged Canister...
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Vacuums Logo
49 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
