Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
My liftmaster 1265 won't open with the remote, unless I am standing under motor assy. I just purchased a new remote model 375LM. I don't know what I need to check or do to increase the distance I can be from the door. It did open about 25' from the door, then it stpped, so I got a new remote, as that is what the door company said I needed.
  • 28 Answers
No range on your remotes or loss of code all together is a receiver problem not a remote problem, You probably did not need a new remote.
You can try to extend the antenna ( wire hanging from the motor) for more range
Or Unplug the motor from the outlet wait 30 seconds and plug back in ( trying to reset the circut board). Also If you are useing florecent bulbs in the garage ( the little twisted ones) these can affect the range on the remote.
Posted on Oct 08, 2010
Liftmaster Model 1265-67 stopped working with the remote after I repleaced the drive gear. Nothing was changed but now the unitl opens and closes perfectly with the wall switch but I can't get the...
Make sure the light in the wall control isn't blinking. That would be an indication that the lock function is on. To turn it off, press and hold the lock button for 3 seconds.
Oct 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener (liftmaster 1265) buzzes when attempting to open or close the door but the chain doesn't move
Remove the cover from the motor unit and check the drive gear. It is white nylon and is just in front of the motor. Most likely stripped.
Apr 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1265 won't motor more than a foot in the down
Check, The black interruptor cup. See if it has powder from gear on it , Remove particles, And run a Q-Tip between the two little towers on the RPM sensor, Which the interruptor cup rotates into to count rpm cycles.
Dec 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1265 garage door opener, tried to
On the side of the motor unit you will find the 'down limit control'. Using a small screwdriver turn this control in the same direction as the arrow printed on the cover. Some tweaking may be necessary to get it just right.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Only Keyless entry or remotes can be programmed but not both
If you can program your remotes but when you program your keypad the remotes quit working and vice versa you have either the wrong keypad or it has reverted to an earlier technology. Make sure the keypad is for your specific model door opener.
Jun 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1265 - Motor hums but nothing else happens.
I have had same problem. Replacing the motor start capacitor fixed it. Capacitors can go bad in an instant when they get old, particularly if they are perturbed while servicing other parts.
Dec 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Trouble changing passwordon model 940CB wireless keyless entry
easyer then that , you die! Open your garage door, take out the step ladder, a chair or get up on *********** in law's back, (here's your chance to be on her back for a change) press the read button of your unit (motor) a led should light up and on the key pad, key in the new 4 digits code and press enter, the light of the unit should blink javascript:; Post Solution
May 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
482 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
