Question about Yamaha Audio Players & Recorders
Got a replacement for the remote RAV283 it operates my Yamaha receiver. Any idea about how to make it work or synchronize it to the receiver?
  • 3,083 Answers
Check your literature that came with the remote. There are codes for setting them to various components, and you will have to enter the right code for it to work.
This blog discusses this problem, and may be of help to you:
http://www.digitalhome.ca/forum/showthread.php?t=93601
This website might have your solution:
http://www.yamaha.com/yec/generaldetail.html?CNTID=450641&CTID=5010050
Good luck, thanks for using FixYa, and hope this helps.
Posted on Sep 04, 2010
My Yamaha RAV283 all of a sudden will not turn on or off my T.V.; input button will not respond but still controls volume?
if you are confident enough to take the unit apart you can remove the rubber button pad and clean the surface of the circuit board
with q tips and reassemble the unit. They get dirty over time.
Most units have screws at the bottom back or in the battery compartment. Be careful not to tear the rubber contacts(pad)
Oct 01, 2014 | Yamaha Remote Control RAV283 p/n:WN058100
Hi how are you i have the yamaha universal RAV283 I would like the code to set my magnavox tv please help me thank you
Hi their, i found these codes.
Magnavox 0060, 0061, 0063,
0102, 0103, 0150
give them a try and let me know if it works : )
Feb 06, 2011 | Yamaha Televison & Video
Remote does not operate receiver anymore. Changed
You could bring you remote control to have the crystal change inside or replace the remote control.
Spider Guy
Mar 15, 2010 | Yamaha RX-V430 Receiver
Codes to program a yamaha remote rav283
This remote was sold with the HTR-6130 reeciver(among others.) The HTR-6130 manual contains instructions and programming codes. You can download the manual here: http://static.highspeedbackbone.net/pdf/Yamaha-HTR-6130BL-Manual.pdf
Dec 09, 2009 | Yamaha Televison & Video
Need yamaha codes to program into uverse tv ir remote
(I have the RX-V659). Because the Yamaha remote has TWO SEPARATE buttons - power ON and power OFF (standby). This problem can't be fixed. There's a code to choose power ON and another code for power OFF. But one button can't be two buttons. Bad engineering\ design by Yamaha in my opinion
Jan 09, 2009 | Yamaha RX-V800 Receiver
Remote code needed
20839 is the DirecTV & Access HD universal remote code for Mintek, Shinsonic, & US Logic. None of which brands are listed in my Yamaha RAV283 remote code list (uses 4-digit codes).
20717 is also listed for Mintek by DirecTV. Other brands with the same code on DirecTV remote are: Apex, Blaupunkt, GE, Greenhill, Initial, KLH, Nesa, & RCA.
Of those brands, only Apex & RCA are listed in my Yamaha remote's list. I tried all of the codes for those 2 brands under types DVD, DVD Recorder, DVD/VCR, & TV/DVD. None worked. It appears to me that only those 3 brands for 20839 share the same remote code settings. If your remote doesn't support any of those 3, I doubt you will be able to use that particular remote with the Mintek DVD-1600.
I hope my research helps someone with this, as it was unfruitful for myself. Good Luck!
Jun 15, 2008 | Mintek DVD-1600 DVD Player
DirectTV HD-DVR & Yamaha RX-v1500
The types of remotes are as follows
- Single item, or fixed. This unit will only operate the unit it came with
- Multi function, this type can operate the unit it came with and a fixed set of other types. Normally the remote comes with a list of supported device it could work with.
- Learning, the combine both a predefined list with the ability to learn functions by sensing input from the original remote.
- Programable. These are the newest remotes that work like multifunction but the list is maintained by the manufacturer and down loadable from the web.
I would guess that the DVR has a multi function remote.
If you can't find the specific Yamaha in the list, then
try another brand, this could take a while.
Some multi function remotes have an option that allow a semi automatic configuration.
You turn on the item and then using a special key sequence try to turn off the device. once the item turns off you should be able to control it.
If you can't the Yamaha has a learning remote. If you really want an easy solution try looking at a programmable remote. I just got a Logitech, (Harrmony). Life has never been so easy.
Mar 08, 2008 | Yamaha RX-V1500 Receiver
67 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
