Question about Cameras
I do not know how to open the slide changer arm. Help. Art Behn
  • 1 more comment
  • ahb61945 Sep 04, 2010
    It is a Minolta Autopak AFT slide projector made in USA in the early 70's. Art Behn
    I have a Minolta Autopak AFT slide projector, made in the USA in the early 70's. I am not able to open the slide holder tray. Help. Art Behn
    I have a Minolta Autopak AFT SLIDE PROJECTOR. I am having trouble opening the slide injector arrm. As a result, I am unable to insert the slide tray. The slide tray is a Sawyer Rototray. Note that this is a slide projector, not a camera. It was made in the USA in the early to mid 70's. Thank you, Art Behn
  • Cameras Master
  • 19,396 Answers
Hi.
Unfortunately the manual for this vintage projector is not available.
Here you can purchase manual book: Minolta Autopak AF/2 & AFT/2 Instruction Manual
See also:Minolta Corporation - Slide Projector - Fair Market Value & Online ...
Posted on Sep 04, 2010
  • Cameras Master
  • 4,924 Answers
Please be more specific..are ya talking about a digital camera view mode?? if so ..it have to have a button that change it from the shooting mode to the view picture mode..than the pictures are changing from the arrows..probably from the left -right ones..
  • 10,594 Answers
I need model number and brand info of your camera and little more details about problem to provide you helpful info.
These info will help me to understand your camera problem.
Thanks.
  • Shahid Electronics
    Shahid Electronics Sep 04, 2010
    OK, slide projector does not fall in my area of expertise, question heading shows its digital camera category question.
    Please re-post your question with correct category selection so related expert can answer that.
    Thanks.
    Thanks
Revere automatic slide projector model P-888 It turns on and blower and bulb work fine but I do not know how to open the shutter on the lens to see the slides... any help would be appreciated.
Watch the slides are they loading?, it will very obvious to the ***** eye. The lens has no cover do that is not the problem. It is a common problem that the plastic slide loading arm breaks.
Jan 27, 2017 | The Office Equipment & Supplies
I get E-01 error of my cd changer
The fault is actually inside the CD changer, when one disc is selected the changer moves the gearing inside to slot from one CD to the other.
While this operation is happening the selection arm jams !!
Then giving an error at the radio display..
To fix the problem, disconnect the CD changer from the trunk of the car,
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again,
grease the moving parts with light lubricant
Good Luck
Feb 24, 2011 | Mercedes-Benz C-Class Cars & Trucks
Jvc xl-f254 cd changer for home. 5 disc changer. Carousel will not slide out. makes humming noise, possibly trying to open.
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
Jan 29, 2010 | JVC XL-F254BK 5-Disc CD Changer
6 CD Changer Stuck (Lexus LX 470)
Open the eject door and at the lower right side of the cartridge their should be a small indent that looks like you could poke it with a medium point pen. That's a reset for the changer. If that does not work, you will need to remove the changer from the car, pull off the top, plug the cable back in and hit eject. look for the arm on the backside of the cartridge and give it a nudge. It may just be stuck. Loading mechanisms usually do not fail before the optics or other!. If you need further help, post a comment with any model #'s on the changer and I'll look for info and help some more. Hope this helps.
Sep 29, 2009 | Car Audio & Video
2001 Lincoln LS: CD Changer wont eject CD's. Keeps saying CD ERROR when I press eject then select any of the 6 CDs. Also, it says slots full when I press load and press any of the 6 CDs. I just bought the...
you really need to take the cd changer out of the dash,and then open the cd changer ,is one of you cds is making the problem,ones is remove it should be working fine,good luck
Sep 17, 2009 | 2001 Lincoln LS
How do you remove the wiper arm on a 94 Dodge Ram 1500? The arm will not fully extend with the hood open or closed but maybe that doesn't matter. Can't get to the wiper motor without removing the arms to...
throw a grenade at it and hopefully the arms will fly off, whatever happened to a nut on a threaded flange to hold wipers on. No wonder imports own the market.
Aug 15, 2009 | Dodge Ram 1500 Cars & Trucks
How do you open c/d changer in trunk?
front of changer has a sliding door,slide open & below cd magazine is a small button,press this&magazine will eject,this will not work if changer is disconnected from the vehicle,
hope this helps
Jul 02, 2009 | Nakamichi Car Audio & Video
My 2001 Jetta 6 disc changer has a cassette but I don't know how to get it out of the changer. Does the car need to be on?
The front of the disc changer has a sliding panel (usualy the left side slides to the right). After you open it completely either on left or right bottom (inside) you will see a little red or yellow push button. This allows to eject the cassette. No, the car doesn't need to be on, but depending if the wiring is standard or not it doesn't harm if the car is on.
Jun 14, 2009 | USA Spec SCD-VW44 6-Disc CD Changer
There is no album art appearing
If it was never associated with the music when you downloaded the music, then there is nothing to show and therefore, wont show.
Feb 07, 2008 | SanDisk Sansa e250 MP3 Player
Cameras Logo
95 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
