Question about Microwave Ovens
Why is my microwave exhaust fan not pulling as much air out. It seems very weak.
    Genius:
  • 1,554 Answers
The bearings are press fit and may be loose or binding . or it has a belt and its loose, clean and lube the fan motor.
Posted on May 12, 2008
When turning Fan on (any speed), top vent grille blowing lots of air, but not pulling air underneath
some microwaves vent to the exterior. check outside for a vent. If it is a recirculating model, perhaps the filters are plugged, the vent pathway is blocked (packaging material) or a loose panel at the back so that the exhaust fan air is leaking out somewhere else. I don't know what else it could be unless the fan is loose on the motor shaft and the fan motor is running but the fan blades are not moving air.
Nov 15, 2014 | Microwave Ovens
Vent fan filter??cleaning,etc does not seem to pull air out as it runs
If this is a new installation, or if this ove is new to you, the following may apply: on some ovens the vent fan can be flipped to either exhaust air out of the house, or re-circulate it. Could it be in the wrong position? You would have to take the oven down to determine this.
May 25, 2014 | GE JVM1653 Microwave Oven
GE Spacemaker XL1800 vent fan doesn't pull air from beneath
On the exhaust system (top of unit) there is a small metal 'damper' that is most likely stuck shut. If that is all clear then you have a problem in the duct work of the home.
Feb 23, 2014 | GE XL1800 1100 Watts Microwave Oven
GE JVM1430 over the range microwave/exhaust fan unit. The exhaust fan (not the microwave cooling fan) all of a sudden has its speed slowed down considerably. The unit vents out the back, not top. ...
Sounds like a strip down of the fan and lubricate the bearings with sewing machine or thin cycle oil will do the trick.
Hope that helps.
Jan 20, 2011 | Microwave Ovens
Have whirlpool gold accuwave micro hood combo model# GH51884XPS5
The inspector is correct, air should be coming through the top louvers, although you sometimes will have a little air coming from the sides and back. Drop the microwave and see which way the blower is rotated, towards the louvers or towards the back or top. Some units also have a panel that blocks the venting from going the wrong way. Good Luck, Appliance Specialists
Dec 15, 2009 | Whirlpool GH8155XJ Microwave Oven
Tappan over the range microwave - exhaust fan problems
most microwaves do not blow air out the bottom.They pull air from the bottom and blow it out the top.
Aug 31, 2009 | Frigidaire Over-the-Range Microwave
Exhaust fan doesn't work and blows air from top vent
Some microwaves have a adjustable fan. We have one that you can vent out the back, the back top or through the front top filters. The latter is what it sounds like you have. If you take the small back panel off and lift out the fan motor you'll see that you can place it in the direction you like.\\
KK
Jul 04, 2009 | Kenmore 60654 Microwave Oven
Exaust vent/ fan very weak
In your duplicate post, you mentioned your model, so here you go:
This is due to poor air flow, either to a blockage or a problem with the internal cooling fan or hood vent exhaust fan.
Are the grease filters or charcoal filter clogged?
You may want to check your owner's manual for info on checking the filters. Grease filters can be cleaned, but charcoal filters must be replaced about every 6-12 months.
The installation manual will tel you if there's some error in the installation setup.
You can download Maytag owner's manuals and installation instructions here.
Dec 10, 2008 | Microwave Ovens
Exaust fan has weak suction on maytage mmv4205baw
Dec 10, 2008 | Maytag MMV4205 Microwave Oven
Microwave oven exhaust fan
The Intake is gentle. It is not designed to have a great pull of air from the Cook Top.
TEST: Turn Exhaust Fan ON
Hold a sheet of your printer paper up to the INTAKE GRILLE (bottom). Will the sheet of paper stay? Held up only by the suction? If it does, Air Intake is OK.
Feb 02, 2008 | Frigidaire PLMV169DC Microwave Oven
Microwave Ovens Logo
132 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
