Question about Coleman Powermate Premium Plus 6250W Portable Generator
Manua for hesco generator model 9340-0 - Coleman Powermate Premium Plus 6250W Portable Generator
The lcd screen is not working and the machine will not operate. how do i reset the machine ?
Here is a link to the Internet Support:
http://www.singerco.com/support
Below is a link to the Manual provided by Singer.
Type in 9340 in the space provided and click on the red Search bar.
Instruction Manuals
Apr 04, 2015 | Singer Signature 9340 Electronic
Tip
2007 Jeep Grand Cherokee Fuel Pump Removal Procedure
<b>INSTALLATION</b> <b>CAUTION: Whenever the fuel pump module is serviced, the rubber seal (gasket) must be replaced. </b><br /><a><br /><br /> 1. Using a new seal (gasket), position fuel pump module into opening in fuel tank. <br />2. Position lockring (5) over top of fuel pump module. <br />3. Rotate module until embossed alignment arrow points to center alignment mark. This step must be performed to prevent float from contacting side of fuel tank. Also be sure fuel fitting on top of pump module is pointed to drivers side of vehicle. <br />4. Install Lockring Remover/Installer 9340 (3) to lockring. <br />5. Install 1/2 inch drive breaker (1) into Lockring Remover/Installer 9340 (3). <br />6. Tighten lockring (clockwise) until all seven notches have engaged. <br />7. Install fuel tank.<img src="ledsled378_2.jpg" /></a>
on Jan 08, 2011 | Jeep Grand Cherokee Cars & Trucks
Hesco generator problems
Check the Spark plugs. Pull them out and see what they look like. Replace the ones that looks bad. Use a Spark Plug Gap Finder and make sure it is set to the specs of the generator.
Could be the Fuel itself. When was the last time you ran it out of gas and refill it? If the spark plugs are fine Empty the tank and place some fresh fuel. Clean or replace the Air filter. Do the general maintenance.
Nov 07, 2013 | Vacuums
We can't seem to get the right parts fo our 550 bottom freezer door hinges.
you can call my parts guy and he can fed ex it to you.it's in stoneham mass.HESCO APPLIANCE
781-438-3800.open the fridge door,look up near the top hinge,write down the model and serial number,call hesco and give him the model and serial and tell him what you're looking for and he will take care of you.good luck
Jan 27, 2011 | Sub-Zero 650 / O Bottom Freezer...
Where is my fuel pump?
The fuel pump is located in the gas tank. These are a bit of a pain. If you are planning on changing it yourself here are the steps you should take:
  • Determine which fuel pump your Dodge Durango will need. This depends not only on the make and model, but also the engine size and type. Models made from 1998 to 2003 have a 4.7 L PowerTech, 5.2 L Magnum, or 5.9 L Magnum. Models manufactured after 2004 will have a 3.7 L Power Tech, 4.7 L Power Tech or 5.7 L Hemi.
  • Step 2 Prepare your vehicle for fuel pump servicing. Drain and remove the fuel tank. Note the position of the indexing arrow on top of the fuel pump before removing it.
  • Step 3 Remove the lock ring on the fuel pump using tool 9340 with a ½-inch drive breaker bar to rotate the lock ring counter-clockwise. The fuel pump should rise up slightly when you remove the lock ring. Remove the fuel pump using care not to bend the float arm.
  • Step 4 Install the new fuel pump using the items included in the kit, especially the rubber gasket for the fuel tank. Rotate the fuel pump until the alignment arrow points toward the alignment mark. Be sure the fitting on top of the fuel pump faces towards the driver's side.
  • Step 5 Tighten the lock ring with tool 9340 until all seven notches engage. Complete the installation by reversing Steps 2 and 3
  • Jul 18, 2010 | 1999 Dodge Durango
    Looking for clips for the bissell 1631, need the clips that hold top to tank and clips that fit on wand and hold hose to wand. m9egm@hotmail.com
    you can try to order the parts from Hesco. you can google Hesco in the search engine and look up your model number. here are 2 that i have found. some of the parts that you are looking for are no longer avaliable.
    BI-2135512.
    .BI-2135520
    Oct 11, 2009 | Vacuums
    Coleman Powermate Premium Plus 6250W Portable Generator Logo
    253 people viewed this question
    Top Coleman Electrical Supplies Experts
    John Trevino
    Shawn DuRee
    Phil Walker
    Phil Walker
    Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
