Question about Maytag SDG3606A Gas Dryer
Dryer starts and flame lights then shuts off. How do I test the flame sensor or something else?
  • Maytag Master
  • 2,696 Answers
If the flame is lighting and shuts off after a while this is normal,if you hear a click and then another click and it relights again that's normal,if the flame goes out right away you could have bad gas coils located on the top of the gas valve or you need to clean out the dryer,if there's any kind of blockage from lint buildup the air can't move the thermostats don't work correctly and the flame goes out,you need to clean out the duct that the lint filter slides into,vac out the area where the motor is and clean out the gas tube and if the vent line is long remove it from the back of the dryer and blow it out with a leaf blower,make sure the outside vent is clear before you blow it out,also you can try to run the dryer with the vent line off to see if it changes the flame,but if the duct is clogged it might not chnage anything,also on the blower wheel housing,i've found dust and lint stuck on the thermostats,the part that's inside the blower wheel housing and that affects how the thermostats run,and next time send the model number and brand name,let me know what you find
Posted on Sep 04, 2010
  • 1 more comment
  • Sal De Sep 04, 2010
    sorry you sent number,last person didn't and i got you mixed up with them ha,have a nice day
  • dshuster2000 Sep 05, 2010
    Hi Daniel,
    Your answer helped me to figure out that the blower fan was stripped. I guess that the lack of draft for the gas flame caused a protection sensor to shut off the gas.
    Thank you,
    Dale
  • Sal De Sep 05, 2010
    there's no sensors to do that, must of been just bad air flow,usually you'll see the flame getting pulled back into the gas tube,that had to get loud at some point,when i go in and find a damaged blower wheel it's very noisy,
  • 4,323 Answers
If your dryer is not heating, then check if the power cord is plugged into the wall. It may be loose or disconnected. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working. Now, check whether the heating element in your gas dryer is burned out by using an ohm meter to check for continuity. If the continuity is not there then you would need to replace the element. After checking the element, check out the thermal fuse to see if it's burned out. The thermal fuse is attached to the exhaust duct on the back panel of the gas dryer. It's usually surrounded by a black resin material situated in a housing made of white plastic. If the fuse looks like it's blown, then it needs to be replaced.
Now, check the igniter, there is a plastic connector attaching the igniter to the burner. Disconnect this and place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance. If the reading is above 100 ohms then igniter is bad. If the igniter passes the test then you need to test continuity on the flame sensor. You should have continuity between the two contacts. Use a multimeter to check the continuity at the flame sensor. If not, then you need to replace the flame sensor. The sensors are usually located close by the igniter so are easily visible. Post back in case further assistance is required. Hope this helps...
Daniel
What do I do when error code reads E 15 . Dryer runs for a few seconds than shuts down. I've tested micro switch and i'ts fine.
Post some pictures of your pilot assembly. I think this might be one of them spark sensor deals where the pilot lights and then detects flame then relays that back to the control for igniton verification. OR just try and clean up the electrode with steel wool and see if the flames stays lit is what I would try.
Jan 07, 2013 | Wascomat Parts Wascomat 231754 Dryer...
Dryer starts , the gas lights and stays on for about 30 bseconds and turns off the dryer stays running without heat. How can I fix this?
Hi and welcome to FixYa, I am Kelly.
This is usually caused by a failed flame sensor PN 338906. Loss of a flame sensor signal (open) will cause the gas valve to shut off in 30 - 42 seconds
How to test the flame sensor:
  • Remove the front panel
  • Open the top panel
  • Leave the drum & belt the way they are, work around them and be careful NOT to get the belt idler pulley disconnected
  • Disconnect the wires from the flame sensor
  • Set your multimeter to read ohms
  • Take a reading between the 2 terminals on the sensor.The reading should be close to 0 ohms but for sure under 1,600 ohms 3 wire type and 500 - 600 ohms for the 2 wire type.
  • If the reading is infinity, the sensor must be replaced
If you can reach the flame sensor through the gas burner access (if so equipped / depending on model) it is even better because you don't have to open the dryer up.
Just note there are 2 types of flame sensor out there. One has 2 terminals and one has 3 terminals. the links below are for the 2 terminal flame sensor.
Sources to purchase the flame sensor:
http://www.appliancepartspros.com/part_details.aspx?part_id=2910747&pn_=338906
http://www.repairclinic.com/PartDetail/Flame-Sensor/2681
http://www.searspartsdirect.com and enter part number 338906 search top of page
Video on how to replace the flame sensor
Thanks for choosing FixYa,
Kelly
Feb 27, 2011 | Maytag Dryers
Dryer runs, tumbles and is putting out air, but the it won't automatically shut off and is not heating up. Suggestions please????>
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Jan 18, 2010 | Dryers
Why wont my dryer heat up
Check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
If everything above is OK then the thermostat2.gif or the auto sensor is not working correctly.
Nov 26, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer is not putting out heat. Gas is connected and working in other parts of the house near the dryer.
Nov 24, 2009 | Roper RGX4634KQ Gas Dryer
I have a whirlpool dryer.... the blower works fine but will not heat up any suggestions
Nov 12, 2009 | LG DLE0332 Gas Dryer
Dryer Model DE306 has stopped heating
Aug 13, 2009 | Dryers
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
WAN'T START
Not starting can be a door switch problem. Maybe when you removed the cover, something came unplugged. Flame suddenly stopping can be a sooted or dusty flame sensor. They do go bad, too. See if it can be bypassed for a test ONLY.
Nov 26, 2008 | Amana NDG5805AW Gas Dryer
Kenmore elite gas dryer
Does the ignition glow when you start the dryer? if so you have power to gas valve and ignition system. if not you may have an open thermostat or thermalfuse.
If the ignitor just sits there and glows all day, you have other problems, It could be a gas valve, or ignitor sensor.
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag SDG3606A Gas Dryer Logo
179 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
