I need to secure my home wirless network - Computers & Internet
  • 570 Answers
1) Secure your wireless router or access point administration interface
Almost all routers and access points have an administrator password that's needed to log into the device and modify any configuration settings. Most devices use a weak default password like "password" or the manufacturer's name, and some don't have a default password at all. As soon as you set up a new WLAN router or access point, your first step should be to change the default password to something else. You may not use this password very often, so be sure to write it down in a safe place so you can refer to it if needed. Without it, the only way to access the router or access point may be to reset it to factory default settings which will wipe away any configuration changes you've made.
2) Don't broadcast your SSID
Most WLAN access points and routers automatically (and continually) broadcast the network's name, or SSID (Service Set IDentifier). This makes setting up wireless clients extremely convenient since you can locate a WLAN without having to know what it's called, but it will also make your WLAN visible to any wireless systems within range of it. Turning off SSID broadcast for your network makes it invisible to your neighbors and passers-by (though it will still be detectible by WLAN "sniffers").
3)Enable WPA encryption instead of WEP
802.11's WEP (Wired Equivalency Privacy) encryption has well-known weaknesses that make it relatively easy for a determined user with the right equipment to crack the encryption and access the wireless network. A better way to protect your WLAN is with WPA (Wi-Fi Protected Access). WPA provides much better protection and is also easier to use, since your password characters aren't limited to 0-9 and A-F as they are with WEP. WPA support is built into Windows XP (with the latest Service Pack) and virtually all modern wireless hardware and operating systems. A more recent version, WPA2, is found in newer hardware and provides even stronger encryption, but you'll probably need to download an XP patch in order to use it.
4) Reduce your WL-AN transmitter power
You won't find this feature on all wireless routers and access points, but some allow you lower the power of your WL-AN transmitter and thus reduce the range of the signal. Although it's usually impossible to fine-tune a signal so precisely that it won't leak outside your home or business, with some trial-and-error you can often limit how far outside your premises the signal reaches, minimizing the opportunity for outsiders to access your WL-AN.
5) Disable remote administration
Most WL AN routers have the ability to be remotely administered via the Internet. Ideally, you should use this feature only if it lets you define a specific IP address or limited range of addresses that will be able to access the router. Otherwise, almost anyone anywhere could potentially find and access your router. As a rule, unless you absolutely need this capability, it's best to keep remote administration turned off
Thanks
Have great day
Posted on Sep 04, 2010
How do i switch my pc to wirless
There's a switch in the front of your laptop. The light should be blue when it's on. Go the the wireless properties and select your home network and connect to it. You will need to know the security code in most cases.
Dec 28, 2010 | HP Pavilion dv6000z Notebook
Cannot get wirless while at hotel or other home with wireless
It could be your firewall settings or that you don't have the correct security key. In my area I detect 6 available networks but I only access the one I have the proper access key for. If you don't have the proper key you can not access the network.
Jul 22, 2010 | HP Compaq Presario V6120us Notebook
I NEED TO SECURE MY NETWORK/INTERNET.
The first line of defense for your Wi-Fi network is encryption, which encodes the data transmitted between your PC and your wireless router. Unfortunately you have not mentioned make and model number of your wireless router.
Jun 02, 2010 | Linksys Wireless-G WRT54G Router
I was connected to my wireless home network (Cox
I was able to get on to my home wirless network by entering my security code over and over again. Finally (!) it worked--at least for now. I hope this helps other people who face the same problem.
Nov 12, 2009 | Linksys Wireless-G Broadband Router
Wireless adapter doesnt work at my new place
can you see your home wireless network in the avail wireless networks if so can you connect and enter the security key
Jul 20, 2009 | IBM ThinkPad T41 Notebook
When I secure my wirless network xbox live wont connect
If your xbox is also connecting wirelessly, you have to input also the wireless security key on your xbox to be able to connect.
Jun 29, 2009 | NetGear RangeMax WPN824 Wireless Router...
Want to secure wirless network with gateway router model WGB-200
Simply ask your ISP for step by step guidance. They are duty bound to solve your problem regarding this issue. Best if you have a static IP, it will make the issue easy to solve....sodeep
Mar 21, 2009 | Black Box Computers & Internet
I do not know how to secure my wirless network
Go to this link for a tutorial on how to secure your wireless :
http://cache-www.belkin.com/support/dl/securing_your_wireless_network.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 02, 2009 | Belkin Computers & Internet
Need to add a wirless code to laptop so it will geta wirless signal
For wireless connection you need a wireless adaptor in your laptop. Most of the laptop comes with wireless adaptor. If you have one then go to control panel--> network connection--> right click on wireless connection and view available networks in your area.
Please note : If you see a lock sign in front of a network it means that network is secured and you cant access it without password.
Please mail me if you need any other help or if something is not clear in my answer
Please rate my answer and Good luck !!
Sep 28, 2008 | Acer Computers & Internet
Wirless router and apple macbook
Did the router assign an IP to your MacBook? Do you use security/encryption on your MacBook?
Mar 31, 2008 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
