Question about Dishwashers
Today when I went to turn on my dishwasher it made a few weird clicking sounds and then didn't start up. Now it seems "dead" and I can't even get any of the lights on the panel to light up no matter what button I push.
  • 12,061 Answers
Hi well i see this type of thing quite frequently, IF as you say there are NO LED's Lit at all. Then perhaps the circuit breaker or Fuse has, tripped, blown? Please check this, while at the Breaker box, recycle the Breaker, remove replace any Fuse.
See if this makes any difference? If it doesn't then unfortunately it appears that the main Board must have gone faulty, most likely in the Power Supply, if nothing is active at all.
If you wish to DIY, then you will have to obtain a service manual, simply Google, the exact name and model of your unit, and the words service manual after them, this should give you a link to a manual, sometimes, one must buy them. follow the troubleshooting steps in there, and then order the part and replace.
However if you do not wish to DIY, then my advise is to contact your local service agent and arrange for a service call, ask for a "Quote" before allowing any work to start.
Posted on Sep 04, 2010
Battery is new, engine won't turn over.
The voltmeter should only go as high as 14-15 volts when the engine is running. I would check for a poor connection between the battery and starter.
Oct 10, 2017 | Jeep Grand Cherokee Cars & Trucks
Today I went to turn on my car and it didn't crank
make sure the starter is tight and your battery cables are clean and tight if automatic try putting it in neutral if it starts you may have a bad neutral safety switch if it is a stick try push starting if it starts you may have a bad clutch switch also check for a starter relay if u have one try swaping with horn relay and see if it starts
Mar 25, 2012 | 1993 Ford Probe
My 1999 jeep grand cherokee won't start. Yesterday the battery was almost dead, the solinoid was clicking, and I tried jump starting it, and the engine was turning over, but not starting. I charged the...
It sounds like a loose wire to the starter, check the wiring going to the starter for any corrosion, breaks and make sure all the bolts and nuts are tight.
Jan 25, 2011 | 1999 Jeep Grand Cherokee
Eight days ago 2005 Suburban would not start. Made a clicking sound when I tried to start it. Jumped the battery seemed fine. Today same thing. Made clicking sound, jumped, started up. Went and bought...
Even a new battery will go dead if the car is running on the battery instead of the alternator.
Check alternator output.
First charge the battery up.
Then check voltage with a meter from Harbor Freight ($3).
Should be 12.5.
The start engine and rev it up.
Should go over 14.
But also clean and grease battery terminals, alternator terminals, and check engine ground strap.
Sep 21, 2010 | 2005 Chevrolet Suburban
Started to get a clicking noise from the electic panel of my Frigidare PLDB998 dishwasher for a few loads and then it went dead. Its only a few years old
Did you ever find a solution? I have what sounds like the same problem. The time keeps ticking down but it flashes between CL and the time while the clicking sound is going, and it sometimes make a clunking sound while this is happening as well.
Sep 15, 2009 | Electrolux Frigidaire Professional Series...
New battery car wont start
may just be a loose terminal. I had mine replaced and it took a few hours before it ran right again. something about the electronic modules take a little time to recharge.
Apr 04, 2009 | 2003 GMC Yukon Denali
I have a 2001 GMC Yukon. It was running fine until two days ago. I went to start it on Saturday and it would only make a clicking noise. I was able to start it with jumper cables. I drove for an hour...
i had the same exact problem with my chevy s-10, but once i replaced the battery it ran fine no problem, u may have fried some circuits and relays while jumping the car, and alot of times that clicking noise is your relay burning out, did your car start doing weird things too? like ejecting cd's, flashing lights really fast and weird noises?
Jul 21, 2008 | 2002 GMC Denali
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
