Question about Frigidaire Affinity ATF6000F Front Load Washer
We have an Affinity ATF6000F washing machine that makes s horrible noise during the spin cycle and shuts off with water still in the basin. When we hit Start and Cancel at the same time we get code E23.
    President:
  • 1,932 Answers
The error E23 denotes the drain **** relay on control board is failed.
Check whether there is some lose connections in the wires if nothing lose connection is there then you need to replace the control board.
Thank You
Posted on Sep 04, 2010
  • guthrie7001 Aug 21, 2011
    Where does the error code come up? on the LED? How do I get it to display?
Mywashermakesahummingnosieandwontspin
Good Afternoon Friend,
I understand that your Frigidaire Affinity washer, model# ATF6000F, is making a humming noise and will not spin. If your load is too small, this can cause your washer to not spin. Add a couple of similar items to help balance the load. On the other side, your washer could be overloaded. Try taking out some items and restarting the cycle. If neither of these is effective, try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. When power is restored, run any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Affinity ATF6000F Front Load...
When doing a load of laundry the washer will stop at the rinse cycle and not drain or spin out the excess water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 03, 2011 | Frigidaire Affinity ATF6000F Front Load...
Washing machine makes a horrible noise in spin cycle and turns itself off. When we hold the Start and Cancel button together we get code E23.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 04, 2010 | Frigidaire Affinity ATF6000F Front Load...
Hi, our washing machine started making very loud banging and whining noise in the final spin cycle and the machine was shaking. We have taken off the back. The springs look ok. any suggestions?
Loud banging is usually an unbalanced load. whining noise is some times debris trapped in drain pump causing it to squeal like a fan belt on a car. Strings, threads and hoses tend to get wrapped under agitator and cause noise, too.
Jul 24, 2009 | Frigidaire Affinity ATF6000F Front Load...
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Frigidaire affinity not draining
The problem is that on the infeed side of the pump there is a catch/filter in the Hose/boot that will catch lint and coins (LOTS OF COINS) and will not allow the water to flow through to the pump. This will stop the cycle and prevent the tub from spinning and the basin will not drain.
to fix this turn your washer over and access the pump from the bottom. the boot can be disconnected from the wash basin with a phillips screwdriver, reach in the boot and pull out the plastic catch and empty the debri, reinstall the the catch after cleaning it and put the boot back on. Set your machine back upright and conncet all the hoses and plug it in. It should work. This is a easy job but it will take an hour or so.
Sep 20, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity ATF6000F Front Load Washer Logo
376 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
