Question about Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL11 Top Loader Washer
Load buzzing noise during rinse and spin cycles. Two weeks ago plugged drain, and repaired(penny caught) now this noise. Any ideas?
  • 868 Answers
Please dont put any more money into this machine,if you wait long enough it will take alot more than a penny.
Posted on May 25, 2008
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Top load washer about 8 years old- Problem 1 = during the finial rinse/spin the tub will not fulling drain and leaves clothes very wet...had a service call replaced the pump, however stills does not drain...
most likely its the electronic board, easy to change. if you can use a second hand one out of a known working machine- see how that goes- it will probably cure the noise problem
Sep 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hello my Fisher Paykel washer will go through the
clean the pump at the bottom of the washer (its the piece with the fan attached); also check the hoses at the pump
Jun 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel GWL11 washer won't rinse
sounds like you have two problems, the burning smell is probably the pump,out of balance is usually due to worn aout suspension rods
Oct 14, 2017 | Fisher and Paykel GWL11 Top Load Washer
Stops before rinse cycle... won't drain or spin.
The REGULAR CYCLE button turns the drain pump on or off. The REGULAR LED will turn
on when the pump is on. This feature can be used to drain the tub. You could get a bucket and lay the hose on the fllor. Gravity will drain it down.
Sep 07, 2009 | Fisher and Paykel GWL11 Top Load Washer
GWL11 fails to drain
I had the same problem. After bailing out the water, I tipped the machine and saw a knee high panty hose caught up in the fan on the bottom. I removed that, checked to make sure the fan could spin freely, and viola! problem solved!
Jun 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
481 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
