On spin cycle there is excessive vibration & movement of the machine. I have removed the cover on the rear and have found a brown powder type substance under both the dampers.
  • Washing Mach... Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Posted on Sep 04, 2010
Auto washing machine drum vibrates makes loud noise
When machine is empty use fingers to try and move drum side to side. Is there excessive movement? 2 to 3 mm is ok. If drum moves to much it will be the drum bearings. Easy fix for an engineer or competent diyer. Millions of how to videos on utube.
Oct 04, 2015 | Whirlpool Washing Machines
Wash machine vibrates moving several feet on fast spin cycle
If the suspension is still flexible, any unbalanced load will cause this. If it is accompanied by the tub striking the inside of the stationary tub, one of the suspension points may have failed.
I would remove the lower rear panel and watch the movement (with a good light) of the outer tub while a helper pushes the inner tub to its extremes to see if one of the points is 'unhinged.'
Jan 29, 2010 | Kenmore Washing Machines
Excessive vibration on spin cycle
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 05, 2009 | Washing Machines
Excessive vibration during spin cycle
Chck to see that all (6) suspension springs are still attached. Check the plastic snubber ring below the mechanism and above the base plate for cracks or contamination.
Mar 07, 2009 | Maytag Performa PAV2200
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Vibration during spin cycle
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
My washing machine will not spin, it will wash and then make a buzzing sound during the spin cycle
Dec 12, 2008 | Frigidaire Affinity ATF7000E Front Load...
Brand new front load kenmore wobbles and moves across floor
Dec 09, 2008 | Kenmore 24032\24036 Top Load Washer
Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Nov 08, 2006 | Maytag MAV4755A Top Load Washer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
