Question about Acer Aspire 1640Z Notebook
Broken key one of my key tops has come off. I have three pieces, none appear broken. the smallest part is still attached to the keytop, but the other square is loose. My laptop is an Aspire 1640. Thanks
  • pat1309 May 11, 2008
    Thank you very much IrishDruid - it has taken me all this time to work out which way the bits went, but my 'y' key is back where it belongs........thanks for your speedy response.
    Pat
  • Anonymous Feb 21, 2009
    top of esc/standby button on dell inspiron 6000 has come off
    President:
  • 2,712 Answers
Try this link..it shoiuld help:
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/
Please dont froget a fixya rating, if it helped in any way!
Posted on May 11, 2008
  • Swilin Sampson
    Swilin Sampson May 11, 2008
    Most welcome...glad it worked out!
Ax-20
Remove keytop and see if anything is under. Some have a soring under keytop, others use a "bubble" under the keytop. Keyboard can come apart and cleaned if you know how, covers have to come off and keyboard removed, also try just blowing out with canned air.With keytop removed see if you can pull the key up and down, if you can then the problem is with the contact on the board under the keytop...
Apr 08, 2014 | Office Equipment & Supplies
I need the letter key M/m for the Swintec 1146 CM model can you help me replace it?
If you are saying that the "M" key dosen't enter you can try this. Gently Pry the keytop off, Make a small paper spit ball, push it down the hole below the keytop, reinsert the keytop.
If one dosen't do it try two. If this doden't work you will have to replace the contact pad inside the keyboard.
DickyO
Dec 05, 2010 | Swintec Office Equipment & Supplies
Hobart a200 will run just fine without anything in the bowl, once I pour my ingredients into the bowl, it wouldn't even mix the ingredients. Try all 3 gears.
Short answer: something is worn/broken inside the mixer's transmission.
Longer answer:
Since none of the three gears operate, the problem is most likely on either the worm gear shaft (probably the brass worm gear itself) or the "transmission shaft" (ironic name as all three shafts could be called transmission shafts). If you're up to the task of disassembling the transmission, which is a very messy task, you'd probably find the problem on one of the two smaller shafts inside the transmission. You'll most likely find either a broken key or worn brass worm gear. Both of these items may have enough holding strength to operate under very light loads (such as an empty bowl) but slip once a load is presented.
Also check the planetary key. Remove the planetary by removing two nuts on the underside of the transmission, where the attachments attach (careful, as the whole thing will drop once the second, thin nut is removed). You will find a long key on the shaft (or in the planetary gear, whichever one it sticks to). Make sure it's not broken, and re-attach the planetary.
Aug 12, 2010 | Hobart A200 Stand Mixer
Model 110.24902200 will not agitate and will not spind
If the washer fills and and empties and you can hear the motor, then the most likely fault is a broken coupler. The water pump is mounted directly on the rear of the motor and the motor/pump assy is attached to the transmission using a three piece coupler (part # 285753, $18.50). One of the two identical pieces of the coupler is attached to the motor output shaft and the second is mounted on the transmission input shaft. The third piece is a rubber part that allows the coupler to break in certain situations to protect motor. When this coupler fails the motor will still drive the water pump but the agitator will not move. A broken coupler can be identified simply by looking at it. Flip the machine and look for it between the motor and transmission.
Jan 07, 2010 | Kenmore 15864/15862 Top Load Washer
My baby pulled the caps lock key off the lap top can i fix this at home
These require VERY careful technique to re-install the keytops.
USUALLY they sit on top of a little "scissor" arrangement that have tiny plastic parts. Getting the little pivots back in place can be tricky and it can be easy to break the parts. You should be able to find somebody that can do it for you.
Sep 04, 2009 | Compaq Computers & Internet
The H, I, O and L keytop markings are worn away
i can give you a sensible suggestion; on a little piece of paper write out the name of the alphabet on it and stick it on the right key on your keyboard, till you finish assigning a key for the faded keys. Good luck
Aug 12, 2009 | Microsoft Natural Ergonomic 4000
Left shift key wont go back on
Given that replacement keyboards are not all that horrendously expensive you could actually replace the keyboard if it comes to it eventually.
However, what we did in the old days when replacing keys with worn out lettering was hold a soldering iron on the metal finger the keytop attaches to until the metal of the finger is very hot. Hot enough to push the keytop back on. While you push the keytop down onto the metal finger hold and press firmly for about 1 minute and then release. That should meld the two together if its going to happen at all. Leave it untouched for at least 30 minutes to ensure a firm bond.
This doesn't mean this will be an end all solution to your problem.
Because you mention the broken plastic piece, this mean this keytop may come loose or off again at some time in the future.
If you have tried and used super glue already be prepared for a smoke stench that will come off while you hold the soldering iron on the key finger. Burning super glue is how CSI techs reveal finger prints. That doesn't mean its very safe to breath. So, take some ventilation precautions while you do this. Essentially, do not breath the smoke directly, it will rise quicly on its own until its burned off.
Best of luck,
Worldvet
Jan 05, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 1640Z Notebook Logo
179 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
