Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Will not open, no light, but learn button flashing.
    President:
  • 3,197 Answers
You need to check the connections on the logic board. Check for loose or burnt connections on the printed circuit.
Posted on Sep 04, 2010
I accidentally programmed the same button for 2 doors and they both open when the button is pushed. How can I fix this?
Is there a battery in it? Remove the battery, count to 10, insert the battery and start again.
Jul 07, 2015 | Chamberlain Klik1u
Where is the "learn" button on the garage door opener? We are trying to install a new remote opener to this 1145lm opener.
It's on the back of the motor. Press the learn then the remote button. You should hear it click and the light bulb should flash.
Feb 15, 2015 | Building Materials
Why Can't I add another remote to a merlin mt60p
If you purchase additional transmitters, the garage door
opener must be programmed to accept the new remote
code.
Program the Receiver to Match Additional Transmitter
Codes:
Using the orange "LEARN" Button:
1. Press and hold down the transmitter button you wish to
program to the opener. The orange LED will flash to
indiciate it is receiving signal from the transmitter.
2. Press and release the "LRN" button.
3. The sourtesy LEDs will flash once.
Ensure the door is clear of obstruction, then test the
transmitter.
Using the Motion Detecting Control Panel
(optional accessory):
1. Press and hold the button on the hand-held remote that
you wish to operate your garage door (1).
2. While holding the remote button, press and hold the
LIGHT button on the Motion Detecting Control Panel (2).
3. Continue holding both buttons while you press the push
bar on the Motion Detecting Control Panel (all three
buttons are held) (3).
4. Release buttons when the opener light flashes. It has
learned the code. If the light bulb is not installed, two
clicks will be heard (4).
Now the opener will operate when the transmitter push
button is pressed. If you release the transmitter push button
before the opener light flashes, the opener has not learned
the code.
To Erase all Transmitter Codes:
To deactivate any unwanted remote, first erase all codes:
Press and hold the orange "learn" button on opener until
the learn indicator light goes out (approximately 6 seconds).
All previous codes are now erased. Reprogram each remote or keyless entry you wish to learn.
http://gomerlin.co.nz/getattachment/2949a1dd-74ab-4576-850d-4f40de28fbe3/mt60p-installation-guide part 27 from installation manual page 15
May 05, 2014 | Building Materials
Merlin Prolift 230T wont clear / delete remotes from memory
Press 'setup' key for 11s not 'learn' key.
Jun 26, 2012 | Cell Phones
I want to program the garage door opener for a 1998 Jeep Grand Cherokee that we just bought. How do I do that?
Depends which kind of garage opener you have. But generally, it goes like this:
In car, press and hold 2 outer buttons on overhead console until indicator lights start flashing.
Hold desired button you want to program garage opener with until lights begin to flash rapidly.
At the garage door receiver in the garage, press the "learn" button. (Mine was located under one of the plastic light covers; it is purple in mine, can be other colors, but should say "learn button" or something similar) If I recall correctly, the light next to the learn button started flashing after I pressed it.
Quickly go back to the car, and press and hold the desired button and the garage should close.
That should be it.
Jul 26, 2011 | 1998 Jeep Grand Cherokee
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
FOR GENIE GARAGE DOOR OPENER ICA SERIES WITH INTELLICODE REMOTE CONTROL SERIES II ELECTRONICS. PROGRAMED REMOTE FOR NEIGHBORS DOOR, WHRN NO LONGER NEEDED THE ACCESS I RE-PROGRAMED TO MY DOOR. NOW BOTH...
First you want to clear both Garage Door Openers. To clear the openers you need to locate the learn code button. This button is (usually) under the white lens cover just push it and hold it in until the red light stops flashing then do the same thing to your other opener. This clears out all remote controls that are programmed to these openers. Try the remote to make sure the units were properly cleared. Neither opener should activate if this was done correctly. After units are properly cleared push the learn code button on the opener that you want this remote to open. The learn code led will flash, then press the button on the remote once (learn code goes solid), press the remote a second time ( learn code goes out). Press the remote a 3rd time and opener should activate.
Nov 22, 2010 | Genie Company Genie Intellicode 1Button...
I am not able to program my Homelink (car) opener using the Learn button on my Liftmaster Formula I. I used the Rolling Code program. I went through all the steps, indicator light flashed rapidly, I...
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxilary, and/or the car door must be shut).
  2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
If this doesn't work your car and homelink may not be compatible.
Nov 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 53684 keyless won't work with my Craftsman 53930DM.
I've never seen the first set of steps you mention. You always need to press the "learn" button first so the opener will be in the mode to capture the new code. As far as I know it is not necessary to hold the Enter button on the keypad (at least I never have). While the "learn" LED is lit on the opener, just key in the new code and press Enter.
Maybe you should try clearing the receiver first by pressing the "learn" button and holding it until the LED either goes out or starts flashing (depends on model). Then try reprogramming. Maybe the little computer is confused.
Nov 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
22 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
