The backlight on my laptop went out and i want to know how to go about fixing it, or how much it might cost to have it fixed?
    Problem Solver:
  • 19 Answers
If you don't mind spending under $20 and have a couple of small screwdrivers and 2 hours to kill, it's not too complicated.
To replace the backlight, you'll need to disassemble the entire lid (often you can't get the lid of the laptop off without removing some covers and the keyboard on the main body). Keep those screws separate and labeled (I use an egg carton when I'm working on a new laptop, and often take a few pictures with a digital camera if I have one handy, especially if it has a macros feature for zooming in close).
Once you have the whole screen assembly (the entire lid and screen) off the main body, you'll need to disassemble it, then REMOVE the LCD completely.
NOTE --BEFORE you disassemble the entire LCD (or even somtimes remove if from the frame) to get to the backlight, unplug the current inverter (that long thin circut board with usually a plug at each end) and plug the new backlight into the inverter. Power on the laptop- bulb comes on? Great- you got the right part- it IS the backlight that burnt out!--
So pull the LCD out, then pull the tape and any tiny screws, saving both, and check the bottom area -usually the backlight is under a silver metal "tray" piece on the bottom of the LCD. It's a tiny long flourescent light bulb, with wires at each end.
Pull that out, and replace with the new one.
BEFORE you reassemble, plug the inverter in again (the little circut board you found in the LCD lid) and power the laptop on for a moment- after a few seconds you SHOULD see the bulb light up! Keep checking briefly as you assemble the laptop again- making sure you have everything plugged in correctly BEFORE you get all those screws back and tightened down!
Usually to have a shop do it can cost as much as a new LCD on Ebay -at least $60~120 USD. A backlight is about $15 and a new inverter maybe a bit less on ebay.
:D
Posted on Sep 04, 2010
Black screen
everything is fixable when this happened to us the cost to repair was close to the cost of buying new. we paid 598 for our tv and was 475 to fix ,,,,,we opted to buy new and get an extended warranty on the tv for 5 yrs ended up being the more practical solution
Oct 23, 2013 | Samsung LN46C600 LCD TV
My vpceb32fm i have display but no light how can i fix
If you can see a "ghost Image"on the laptop monitor in a bright light, the backlighting isn't on, the backlighting is switched on/off by a tiny switch near the hinges of a lartop. Sometimes will stick closed due to damage, dirt, dust, loose hinge ,etc. Also, due to a drop, bump, jar, etc. the ribbon cable on the back of the monitor may be loose. OR the wire is damaged/pinched the supplies power to the backlighting. OR the CCL/LED/ whatever backlighting your laptop has is out.
Nov 25, 2012 | Sony vaio vpceb32fm/w Notebook
My laptop screen went very dark, I can barely make out whats on the screen but I know its working. What can I do to fix this situation on my gateway p-6860fx pc notebook?
Hi josue fernan...
You need to see if your laptop lcd screen is faulty and/or the lcd inverer is faulty.
1....Test the lcd screen:
Hook your laptop to an outside monitor and then start your laptop normally...if the picture on the external monitor is good, then your lcd screen is bad.
2....Backlight Faulty: If the monitor is still as dark like your lcd screen on the laptop then it could be the backlight that is faulty.
Please take time to rate me thumbs up
LCD Backlight and Screen Replacements:
http://www.laptopsman.info/0-Gateway-lcd-1.html
LCD Screen replacement:
http://www.screentekinc.com/Gateway_P-6860FX--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Sep 11, 2011 | Gateway P-6860FX Notebook
42 inch flat screen shows black screen with sound only no picture
That sounds like the backlight system or its powersupply has failed. If you can see an ghost like image when close and at an angle near the dge (depends on the light) then this confirms the backlight being the problem.
Repair cost should be about $100. You should be able to get this fixed under warrenty if you have any. If not get repair estimates before doing anything. It should be worth fixing but it never hurts to know if it is getting close to what a new replacment tv is worth.
Apr 23, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Backlight went out where do i find the backlight?
Its probably not the backlight but the LCD inverter. Just replaced one on my Acer and all is well. Bought it off of E-bay for under $10. Its a cheap and easy fix if it is actually the problem. Good luck, Todd
Dec 22, 2009 | Dell Inspiron 1521 Notebook
Acer Aspire 5610 LCD backlight problem
If it is less than 1 year old, go to http://www.acerwarranty.co.uk for UK or http://support.acer.com/ for US.
I did this last year for my girlfriends laptop backlight problem and it was a free courier both ways and was repaired within 2 weeks (new part required). No cost to you.
Otherwise, sorry I dont know how to fix it.
Nov 05, 2009 | Acer Aspire 3680 Laptop
Can't see the screen!!!!
Either the backlight on the LCD has failed, or the video inverter which provides power to the backlight have failed. Either way, the computer is under warranty; contact HP and have them fix it; it could get costly to do it yourself.
Apr 27, 2009 | HP Pavilion dv5-1132us Notebook
Display lost brightness
forthe cost of the unit vs. the cost of having it serviced , ive decided to work on it myself. I have it narrowed down to the flourescent backlight or the backlight power curcuit.
Sep 16, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
Cracked LCD
Usually, yes, the LCD is covered under the warranty. If not, it could cost around $400 to fix.
Jul 12, 2008 | Gateway MX6931 Notebook
My compaq presario m2000 screen is very dark
You will need to replace the LCD screen. The cheapest way to go is ebay. Here is one.
Thanks and please take a moment to rate as fixya.
Jul 06, 2008 | Compaq Presario R3000 Notebook
Computers & Internet Logo
248 people viewed this question
David Payne
David Payne
