Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
My Frigidaire refrigerator water dispenser leaks water inside the door, the water runs down the front of the door from the bottom of the front panel. How do I remove the panel to repair or replace the line? I have been all over the web and cannot find a breakdown of this repair. Thank you J. Lindsey
  • 5 more comments
  • VinnieB May 29, 2008
    same problem as me. model # PLRS267ZAB8
    The water leaks from the front dispenser unit.
  • rsamos Jun 01, 2008
    I have the same problem, my model # is PLHS269ZCB4
  • jplindsey Jun 01, 2008
    The model number is FRS26DR7DSO
    J. Lindsey
  • jdbusyguy Jul 23, 2008
    My front dispenser panel started leaking water today, not much but just enough to get the floor wet. Is there a do it yourself fix?
  • Anonymous Aug 31, 2008
    Please help, all I want to know is how to get inside the front panel so I can reattach the hose to the water dispenser.
    How do I get the front panel off????????
  • Anonymous May 17, 2009
    I have the same issue for a frigidaire frs6lr5em3, does anyone know how to access inside the door? I have tried pulling out the drip tray and it appears attached.
  • VinnieB May 11, 2010
    Vinnie B here. Model # is PLRS267ZAB8
Lift up & out on the drip tray (it will come out) after removing it you will see 3 screw. unscrew the screws & lift the face plate of the despenser & it will come off. Be careful though. There is a ribbon wire connected to the back of the face plate. make sure to dissconect the ribbon wire from the control board not the back of the face plate (its alot harder to reconnect to the face plate & pretty simle to reconnect to the control board).
Posted on Jan 02, 2009
  • comosaywhat Feb 09, 2011
    That was great. Our water hose got pushed up behind the dispenser. Had to take out all 6 screws eventually but fixed the problem.
I found that I have the same problem this morning. Has anyone found out how to correct it or did you have to call for service? Did they fix it?
Posted on Oct 21, 2008
    Genius:
  • 1,073 Answers
What is the model number of the fridge
Posted on May 11, 2008
Frigidaire refrigerator water filter area leaking
There has to be a loose or disconnected water line. Check the water dispenser inside the door and behind the door and then go from there.
Jul 23, 2012 | Frigidaire GS26HSZDW Side by Side...
Freezer & Refrig does not get cold
without a model number to check out what else might be in that area of the door i'd say a piece of tubing from the water source is leaking, or you are getting ice melt from inside somehow making it out through that panel now. i believe the water for the door comes in through the bottom of the freezer door and works its way up to the dispenser area, the solenoid for the water inlet is behind the fridge near the bottom (you'll see the water tubing).
more likely somethings just not fitted or aligned properly and waters making it out someplace it shouldn't.
best of luck to ya
May 27, 2010 | Frigidaire FRS26H7CS Side by Side...
Water is leaking from the bottom in the front left side of side by side maytag. water line is ok not leaking. can't see where it is coming from.
the water for the dispenser (ice/water dispenser in the freezer door) comes from under the frige then up thru the bottom hinge of the freezer door .. it then goes inside the door up to the dispenser .. its a plastic hose and it has to twist near the hinge each time the door is opened .. thats where it usually breaks or develops a pin hole leak .. you can replace the whole hose or just the damaged section if that easier ... since the bottom freezer.hinge where that hose comes up thru, is at the position of your leak then i suspect thats your trouble ... ..also check the condensate pan to make sure its not full .. thats a flat pan under the fridge ..you can usually get acess to it by removing the front kick panel at the bottom of the frige .. if thats full then look for a door seal leak (damaged rubber seal) ... a broken seal or open door will allow moisture to condense inside the machine ..that runs down into the condensate pan where it normally evaporates .. but a problem (like open door) will fill it up to overflow in time ....
Aug 05, 2009 | Maytag Refrigerators
Water leaking from inside door
the water line for the water disp runs in a chase that goes up thru the bottom hinge of the refrig door. SO DONT PULL YOUR DOOR APART! you can order a new water line thru frigidaire and replace the part by removing the water dispenser housing on the door and pulling the line thru the door then inst the new line in reverse. if it looks like too big a job then get a reputable company to inst it for you.
Jan 21, 2009 | Frigidaire GLRT188WD Top Freezer...
Jenn air side by side leaking water
to allow your fridge/freezer to be ice free a timed defrost phase apxx every 7 to 10 hrs occurres whe the ice is drefrosted the water shoud go via a collection tray to the top af the compressor to keep it cool the tray is situated at the bottom of the freezer side behind the panel youll find is probally blocked and the water is overflowing to the front instead of going the correct way if you tecn minded unplugh the appliance remuve the pabel and unblock the drain tray the panel is inside the freezer torward the bottom
Nov 13, 2008 | Jenn-Air JCD2389G Side by Side...
Leak running down front
Take the recess cup out and seal the area around it right where the front stainless steel panel meets the recess (right at the front of the recess) with clear silicone to prevent water from getting inside the door, then running out of the plastic frame area around the dispenser and running down the freezer door or out the bottom of the door. After the silicone has set, replace drip cup.
Nov 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
2,673 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
