Question about Onkyo TX-SR806 Receiver
When the receiver is turned on for the first time on any given day very loud crackling occurs for several moments after a while the noise goes away and the unit then functions normally. I have a cable box and a Blu Ray player and an HD Dvd machine all of which use HDMI and all work as they are supposed to after the initial noise on start up. I know that left alone this will eventually be a serious problem, any help would be appreciated
  • debarney Sep 04, 2010
    Thanks for your reply
    I have changed a couple of HDMI cables already (an expensive undertaking) with no luck as yet.
    If the amp has been down for 3 - 5 hours it seems to be normal but overnight 7 - 8 hours causes a problem, weird.
    This also makes troubleshooting difficult.
  • debarney Sep 08, 2010
    My work has taken priority for the next few days
    Thanks for your inquiry will give you details as things evolve
  • Onkyo Master
  • 6,993 Answers
how long have you been using this receiver? I believe this receiver is due for servicing.
To service the receiver, get a disconnect other peripherals (DVD, cable box, etc), get a screw driver, and use it to open the receiver cover so that you gain gain access to the receiver's panel board. The panel board should have been dusty, if this is your first time of opening it.
Get a small paint brush, use it to clean off every dust on the panel. Then get some fuel, dip the paint brush into the fuel and also use it to clean the board.
Allow, the board to dry very well, cover the receiver and put it on again. By now, there should be difference.
Lastly, you might need to disconnect, all the wires on the board so that you can clean it deeply/properly. But make sure you connect the wires back to their correct position.
Good luck.
Posted on Sep 08, 2010
  • 5,807 Answers
You are right about that.
Preventive Maintenance is cheaper than repair.
Talking about Preventive Maintenance,
One has to checked if the sound are heard on all
speakers with the same level.
If one channel only , look for the terminal at the
back of the receiver where it is connected and
we will troubleshoot on that channel.
if the sound is heard on all speaker same level on all
then , what you may need to do is removed all
the Input connected ( but have a note on it ).
And turn the unit ON without anything connected on all
the Inputs to identify the cause
( but speakers are all connected ).
and post what you found.
These may take some time , But i am in no hurry
while I await for your reply.
Posted on Sep 04, 2010
  • 1 more comment
  • Rommel Cana
    Rommel Cana Sep 04, 2010
    it might take another night to determine, do not connect
    anything on the inputs,
    if problem still arise , we will start troubleshooting on your
    receiver,
    you did not post , is it on all speakers?
    or just one?, or is it coming from the unit?
    still waiting for your answer
  • Rommel Cana
    receiver,
  • Rommel Cana
    Rommel Cana Sep 11, 2010
    can you try connecting with the basic , like the RCA connector
    like these :
    just for troubleshooting only, so we can determine if problem still persist?
  • 1,472 Answers
Debarney
You are correct this is something that you want to address ASAP because you do not want to damage your receiver and/or other devices.
So most likely the noise is being caused by on of your devices grounding through the receiver inducing an audio siginal that you can hear.
Since the noise goes away the receiver built in filter is hiding the sound so you do not hear it.
To make sure that there is not a problem with the unit unplug all connections from the receiver except your speaker. This includes all HDMI connection too. So the only thing you should have connected is your speakers and the AC connection.
Now power cycle the reciever if you still have the sound then the problem is with the receiver. If not start reconnecting your devices on at a time and power cycling the unit to see if you get the sound back. This will be the device that is the problem.
Note the problem may be with a cable that you are using to connect the device. I have ran in to several cases where the HDMI cable was bad and this causes the problem.
Let me know how things go
Issken
http://www.fixya.com/users/issken
  • 2,973 Answers
This kind of crackling occurs due to dust getting accumulated in the knobs. Pleas use the vacuum cleaner to blow into the knobs and remove this fine dust.
Posted on Sep 09, 2010
When I try to dial out the phone has loud crackling noise.
You have a line problem call your Telcom provider.
Feb 06, 2016 | Lands Phones
Crackling no receive
I have a similar problem.when no one is on then I get this crackling noise but as soon as someone comes on it goes away.Lately thats how its been because of the suns blackspots playing tricks with our atmosphere.
Feb 27, 2014 | Cobra Radio Communications
Crackling
So if you bought enclosures that are premade AND had the speakers installed, you need to see if there is a cross over network installed in them
Apr 27, 2013 | Car Audio & Video
Clunking/ticking noise during acceleration in 3rd and 4th gears
This sounds on the base of it to be pre ignition, if so the moment you take the foot off the gas it goes? The cure is to retard the ignition timing slightly, have you recently changed your octane of fuel? this will also cause this?
The noise is caused by the expansion of the compressed gases expanding before the piston reaches top dead centre causing the piston to \'rattle\' left unchecked will cause permanent damage and engine failure
Jan 16, 2013 | 2008 Volkswagen Rabbit
I have a yaesu ft-736r with no audio
Hi Jermaine,
It transmits, but no receive, are you sure, have you tried playing around with the volume control?
If, so did that make any crackling noise? If so, then this is due to lack of use of the volume control, many radios, including the old transistors with dials, would make crackling sounds when you adjusted the volume, and as I say, this is due to lack of use, So if this is the case and to get your receiving, turn the volume control up & down fully for a few minutes and while doing so your radio might receive a transmission that will be loud, quiet, loud, quiet, etc., as you play with the knob.
Keep doing so until all crackling has disapeared.
Do this often as possible when firing up your radio for the day, the more use these controls get, the better.
I hope this has answered your query.
Cheers,
Peter
May 29, 2012 | Yaesu FT-736R
Mysterious car noise
Check the oil first, if it is low it will cause a host of noises in the engine.
It sounds like that may be the problem you have
Nov 22, 2008 | 2005 Honda Civic
My speakers have almost constant crackling noises
Hello, there is no chance that you can fix this problem by replacing speaker wires. Resoldering the output stages as well as area around the microprocesor could be the efficient solution. If you need more info please advice.
Apr 12, 2007 | Sony DAV-BC150 System
Onkyo TX-SR806 Receiver Logo
251 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
