Question about Delta Faucet Delta 172-SSWF Waterfall Single Handle Kitchen Faucet with Matching Side Sp...
Hard to turn spout side to side - Delta Faucet Delta 172-SSWF Waterfall Single Handle Kitchen Faucet with Matching Side Sp...
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
Remove the spout and apply a thin coating of plumber's waterproof silicone lubricant to the O-rings on the spouts mounting post. If the spout is still difficult to turn, replace the O-rings. Here is the link to the delta waterfall parts breakdown.
Posted on Sep 06, 2010
How do l fix our leaky kitchen faucet
If its leaking from the base of the spout where its attached to the body, its most likely the O rings that need replacing. The spout body could also be leaking as the metal is quite thin and can develop pin holes under the bottom face of the spout. To determine it that's the problem, turn the water on, place your hand under the spout body, you should not get any water spray, if you do (its usually a fine mist so its hard to see, but you will feel it) the spout is bad, replace it.
Jul 27, 2014 | Belle Foret Kitchen Kitchen Faucet With...
Our American Standard kitchen faucet has become hard to swing from one side of the sink to the other. What could be causing this? Is there a bad part?
Hi! If there are no leaks from around the spout, you can remove the spout and apply silicone lube to the spout o-rings and resemble. If it is still hard to move ,replace the o-rings.
Jul 15, 2011 | American Standard 4205.001.021 Reliant+...
How to replace my Dlta Pull Down Diverter Tub Spout Part # RP17454 The spout comes out of the wall and I dont want to have to tear the whole wall out to get to the plumbing if possible. I am am somewhat...
these are screwed on. you might need a wrench to remove if it is hard to turn. you will need to turn counter clockwise to remove it.
when installing the new one (same model) do not over tighten! do not use a wrench, using your hands only turn clockwise until it is snug and pointing straight down. a little teflon tape is recomended.
sometimes the old "nipple" will come out with the old spout, just remove it from the old spout and re-use on the new one. use a little silicone around the spout against the wall, on the top and sides only, do not go all the way around it. this will let any moisture that gets behind it to drain out.
Aug 09, 2010 | Delta Faucet Delta RP17453 Pull-Down...
I am leaking at the base of the spout. if you put any kind of pressure on it to move it from side to side it leaks. this is a two handle kitchen meon faucet
At the base of the spout it should have an o ring on the spout does it have a nut or cap on the spout that will unscrew to gain access to it. turn water off first.
If it is loose you could try tighting it , but most of the time it would be th e or ring.
May 15, 2010 | Moen 7910 Chateau Two-Handle Kitchen...
Tub spout is calcified onto pipe and will not twist. i don't want to ruin pipes , how do i get it off?
First make sure you have a thread type spout. Look on the underside of spout for a set screw. If one is not found then you have a threaded spout. If you have set screws then it is a friction spout loosen set screw and twist/pull spout. A couple things you can try to loosen the calcium build up. Use a calcium buildup cleaner (may or may not be able to reach area) you can also try rapping on spout with rubber mallet calcium is hard and this might break it up (cause fractures in the calcium) then take a no mark wrench (simuliar to what you take oil filters off with) and turn spout counter clockwise. It may be hard but it should come off. If the spout pipe is galvanized it may come off inside the wall before it comes off of the spout. No worries just keep turning until off. Once off you can work on the spout end then reinstall. Make sure when you reinstall you place teflon on the thread ends. Hope this helps, thanks for using FIXYA. Good luck and have a great day. Jeff
Apr 07, 2010 | Price Pfister 01-311 Shower Head, Tub...
Any tricks to lifting the spout off the base? I slid the collar up and removed the plastic retainer, but don't seem to be able to life the spout.
Run the hot water for a few minutes this will expand the spout and help loosen the seals. You may have to pull hard but it will come off. Use alittle silicone grease on the o-ring when reinstalling.
Jan 16, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
I have a Delta Waterfall 172 SSWF faucet in my kitchen. I need to replace the water spout - I have the replacement spout. It appears there is a plastic retainer ring that holds the spout in place but I'm...
Normally you just turn that ring, counter clockwise. If too hard to turn, I usually put a rag over it, to avoid scratching, and use a pair of channel lock pliers, and squeeze just hard enough not to slip.
Jan 15, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
No water from water spout
See if there is a sediment screen at the inlet to the filter from the faucet and see if it's obstructed or clogged. Obviously, make sure you are using the correct filter cartridge and that the filter discharge is also clean.
Mar 22, 2009 | Hotpoint HSS25GFP Side by Side...
Unable to pull spout to replace O'Ring in Kohler Faucet F10416
They just pull out, sometimes things get stuck and I cant get them lose as a plumber and you just have to buy a new one...dont feel bad
Jan 31, 2009 | Kohler K-10416-BN Fort½ Single Control...
Delta Faucet Delta 172-SSWF Waterfall Single Handle Kitchen Faucet with Matching Side Sp... Logo
1,026 people viewed this question
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
