Question about Dell XPS M1330 Notebook
My son has a xps 1330 with error messages 0F00*137B and 0f00*075D and what happened is it got shut off while updating. no help from dell since warranty expire. wont let him go in safe mode any suggestions?
    Problem Solver:
  • 19 Answers
Sounds like a simply corrupt OS issue, but I might be wrong.
1) Pull the battery, and unplug the laptop.
2) Pull the Hard Drive out and back up any personal data (you're going to restore the laptop to the factory settings, unless you already wiped the HPA partition -don't know what that is? It's probably still there, so continue on with the next steps)...Best solution for backing up data is plug the laptop hard drive into an external hard drive enclosure and then plug it into a 2nd machine with enough room for your personal data to copy off the hard drive).
3) Hold down the power button 30 seconds, then hold down the "ctrl" and "f10" another 30 seconds (this resets anything funky usually in the bios)
4) Plug in the battery and power.
NOW...
5) TRY to boot the laptop and IMMEDIATELY begin tapping the "f11" screen. If you don't have a memory problem (bad RAM) then you SHOULD get a restore menu. Follow the guides, and restore the laptop to the original as-shipped (usually) setup. BE WARNED, if you didn't back up your personal data and programs, and you do NOT have any kind of custom image in the HPA or separate partition that existed BEFORE the factory image or custom image was made, this restore process will make your personal files impossible to recover (even forensic people would have a hard time getting them back)!!!!
so back up your data by pulling the HD out and then try the above.
an alternate solution is also to download to another computer a linux live CD, burn it and then boot the laptop (you can boot it from the CD while the HD is out and copying data to your backup). No problems booting from the Live CD? Great! It's an OS problem, and the restoring to factory settings from the Dell image should fix everything.
If you want to try the Live CD, check out Ubuntu 9 or 10 or CrunchBang Linux 9. Also DSL (Damn Small Linux) and Puppy linux can run froma CD (or USB stick).
Post results here.
good luck!
Posted on Sep 04, 2010
Where can i find the motherboard on a del xps 1330
Consult the Dell branch for a new motherboard, but it will set you back with the same price of a new laptop. The Bios battery is the round shaped battery with the holder or simply by the connecting wire such as this12_14_2011_8_19_08_pm.jpg
Dec 14, 2011 | Dell XPS M1330 1330
Hi, I have a Dell XPS Model PP25L. Whilst using it this morning it suddenly shut down and wont restart. Have tried with and without the battery and with a different power supply. Local computer shop says...
Hi Tdenton, it must be a problem with the motherboard and the power supply connection. You can have the motherboard replaced by a dell expert technician and you can also check the manual on how to replace the motherboard from this link change motherboard. Hope this can help.
Apr 14, 2011 | Dell XPS M1330, M 1330, PP25L Series...
My dell laptop m 1330 with window 7 does not detect my battery
In that case the battery has failed.This has happened a lot earlier than it should - you must replace it. If it's still in the warranty they have to replace it for free.
Sep 03, 2010 | Dell XPS M1330 Notebook
Fix error code 146 dell xps 1330
Error 146 pertains to hard drive error. If there is still a chance to back up your files do so as this kind of error indicates a faulty
hard drive.
Aug 16, 2010 | Dell XPS 420 (dxcwqj1_2) Intel Core2 Duo...
Dell xps 1330 is not getting booted, when run the diagnostics got Error 2000-0146. After restart with repair got blue screen with error STOP: c000135, Please help me to resolve this issue.
Resolution is simple enough. 2000-0146 is a read-write failure of the hard disk drive. You will need to replace the drive and reinstall Windows and your drivers. You can get a Replacement HDD here is the system is no longer in warranty:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136458
Sep 30, 2009 | Dell XPS M1330 Notebook
Whenever i try to open my creative audio drivers (DELL XPS 1330)
well there's your problem right there........windows vista HOME!! it has soo many issues with it!!!
it sounds like it dosen't detect the hardware there are you sure that's what the laptop is using as its sound and are you sure its not conflicting with any other hardware?? if yes then i would try re-installing the software that came with it....it may just have lost some files or could have been corrupted..and it should spring back to life
and please get rid of that home edition!!
before you have alot more problems!!
hope this helps,ben
Aug 13, 2009 | Dell XPS M1330 Notebook
Dell xps m 1330 starts fine but goes ...
Boot into Safe Mode and change the video resolution to the lowest resolution supported. Reboot the machine normally. The problem should have disappeared. From here you can readjust your display resolution to any higher resolution supported by the system if you wish.
Apr 01, 2009 | Dell XPS M1330 Notebook
I have a dell xps 1330 and the touch pad stopped working abruptly. Now there is an icon that looks like a note pad and pen to the center left of the display. What did I do, and how can I get the touchpad...
had a similar problem on a laptop i was working on - the touchpad quit immediately after an update.
try using an external USB mouse and then reinstall the driver for it - that's what fixed it for me.
Jan 15, 2009 | Dell Inspiron 6400 Notebook
Dell touchpad needs resetting every boot up
You can try to update or reinstall the touchpad driver. Click this and run the file. Restart when prompted. Try adjusting it again and see if the settings are retained.
Nov 02, 2008 | Dell Inspiron 6400 Notebook
XPS 1330 cracked screen
MONITOR DEPOT, INC 5359 WEST RICHEY ROAD
HOUSTON, TX 77066
Mar 09, 2008 | Computers & Internet
Dell XPS M1330 Notebook Logo
356 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
