Question about Asko 24 in. 1805 Built-in Dishwasher
Need replacement control selector pad mounted on top of door Asko 1805 fully integrated
  • Asko Master
  • 2,605 Answers
Hello, Welcome to FixYa.
The part you`re looking for on the Asko 1805, as I understand your description ( please correct me if I misunderstood )...
the overlay/decor insert across the top of the control panel is Asko part # 80-708-88 (then a -0 for white or -33 for black depending on the color the last digit?digits change).
Check "repairclinic.com" part number 764259, retail for approx. $80.
Hope that answer`s your question. Let me know if I can assist you further.
Thank you for choosing FixYa today.
Please take a moment to rate the information I provided for you and a testimony if you fell it`s warranted.
Good luck.
Regards,
Macmarkus :)
Posted on Sep 04, 2010
Testimonial: "Very helpful in identifying parts for replacemnt with part numbers. Quick response."
My dishwasher does not turn on I tested power to switch and it is good no lights on control module, no power to light
Find the tech sheet and locate the thermal cut-out, all units have one, some are mounted on the actual control board chassis and will blank the controls
Apr 26, 2016 | Asko 24 in. 1805 Built-in Dishwasher
The soap dispenser on my ASKO Model 1805 Dishwasher broke, we got a replacement part from ASKO but can't figure out how to get the old one off to replace it?
Remove the outer door panel, the screws around the edge hold it on. The soap cup will depending on serial break be held down with metal flanges or small screws. Bend the flange or remove the screws and push the soap dispenser out.
Appliance & Refrigerator Repair
Mar 23, 2011 | Dishwashers
The start switch (right side) not power switch (left side) broke....(below the overlay). I need to replace the switch and overlay. What part(s) do I need to fix the switch. I now have overlay part...
Hello again,
I'm glad I was able to help you earlier with the overlay, unfortunately I'm not sure I can go 2 for 2 because the start switch issue is going to be a little more involved.
The issue is the start switch is actually integrated into the main control assembly,
example...
...hence you may need to replace the entire assembly and...this is the unfortunate part...it is no longer available at most part vendors since Asko no longer manufactures it.
If need be I'd recommend calling Asko USA at 1-800-898-1879 and see if perhaps they can direct you on a location, or you can look at "repairclinic.com" under # 1472725.
I say may because the control itself has possibly fallen away from the white upper plastic case which houses it, ( refer to the image ) thus the switch is not actually being pushed.
Either way will require you to open up the console to inspect it or replace the control if that isn't the issue and the start button simply no longer responds to the command when pushed.
In any event I attached the pdf pages of the parts illustration I have on pc, they may in fact be too small once sent though.
The part number by Asko originally is # 80 706 99-04.
Hope you find this info useful, let me know if i can assist you further of course, I will see what I can do.
Good luck.
Regards,
Macmarkus :)
Sep 04, 2010 | Asko 24 in. 1805 Built-in Dishwasher
Start switch is gone and strip across top of door needs replaced
The part`s you`re looking for, the power switch/on-off switch is Asko original part number 80-575-47. Check "repairclinic.com" part number 763255, retails for approx. $20.
The overlay/decor insert across the top of the control panel is Asko part # 80-708-88 (- 0 for white or -33 depending on the color ). Check "repairclinic.com" part number 764259, retail for approx. $80.
Thank you for choosing FixYa today. Please take a moment to rate the answer I provided for you and a testimony if you fell it`s warranted.
Good luck.
macmarkus :)
Jul 14, 2010 | Asko 24 in. 1805 Built-in Dishwasher
Asko 1805 - inside light is on, none of the operation (front panel) lights turn on
Quite simple after all. If the main power button on the top left hand side of the door is pressed in (on). Whenever the door is openned their is a light in the DW which comes on like the fridge or oven.
Keeping the power button off turns the light off. For us this is good as we usually only close the door fully (catch catches) when we run the machine.This way we are not wasting electricity.
Nov 14, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Asko 1805 dishwasher detergent door does not despense the detergent during the wash cycle. At the conclusion of the dishwasher cycle the door is still closed. How do you repair?
First make sure that nothing is blocking it.. when you load the dishwasher...next make sure your dishwasher cycle is NOT on rince and hold ( water spraying on a plate symbol) as this cycle will not open the despence door..
last you can remove the screws in the door check the vax motor and or check if you are getting power to the despencer ( no power replace control)
power to vax motor replace despencer motor
Hope it helps if Not let me know more about you problem..I can help
Sep 05, 2009 | Asko 24 in. 1805 Built-in Dishwasher
ASko D3250 fully integrated - hotsteam/water swelling joinery
check the area of leak sounds like seals gone on dishwasher see if seal can be put back into groove posistion
Aug 03, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Detergent door will not close on Asko model 1805 dishwasher
Here you must change complete detergent box. Or the electronic gives consantly power to trigger. Most likely one of these two.
Jul 18, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Asko 1805 ALL lights flashing and no water coming out
High water level is often in the pan under the dishwasher.
  1. Unplug or turn off breaker.
  2. Remove kick panel.
  3. Remove water from pan.
  4. plugin/turn on breaker.
  5. watch for leaks.
May 30, 2008 | Asko 24 in. 1885 Built-in Dishwasher
Asko 24 in. 1805 Built-in Dishwasher Logo
392 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
