Question about Refrigerators
Wbn39mw fridge freezer has defrosted, also now the fridge is not cold. turned it off and cleaned around compressor after it had cooled. turned back on and it started tio work properly, but by end of the day defrosted again. sounds like it is trying to start the compressor but will not kick in
  • Refrigerators Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 04, 2010
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Apr 21, 2016 | Frost Refrigerators
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
I have a Artic Air White Reach In Freezer. It is not blowing cold air from he top where the cold air comes in. Freezer was at 60 degrees F. I turned the defrost switch to make sure it wasn't in...
Is the freezer itself getting cold.To blow cold air.the freezer should get cold/friezed.the cold air blows from freezer to fridge side.first the freezer side gets cold, then when the freezer side gets enough cool to its set cooling temperature, at that time the defrost cycle starts.In defrost cycle the fan in the freezer starts running and the cool air from freezer starts going to fridge side.There is a ventilation passage between fridge and freezer from where this cool air passes.---------------- If in your case, the freezer is getting proper cold, but its not blowing cold air from freezer to fridge, then possibility is that, there is a blockage in ventilations.But if ventilation its clear, then its defrost problem.First try manual defrost reset procedure. The procedure is as follows: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. ------------------------- BUT if in your case, the freezer section itself is not getting cold, then the problem is compressor related.The compressor is the part which cools the freezer frost.In the compressor, there is a refrigerant to cool the freezer.If the compressor gets weak or the refrigerant gets low, then it will not cool the freezer, if the freezer is not cool then it will blow warm air from freezer to fridge, in defrost cycle.In that case, the compressor is faulty and its the cause of problem.------------ So you will have to first check , that is your freezer getting cold or not.as per that you can start the troubleshooting.------------------
You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 01, 2011 | Arctic Air Freezers
Freezer is not getting cold not sure if it is stuck in defrost mode
Freezer not getting cold, then defrost problem is rare, it can be compressor issue.If freezer getting cold but fridge not getting cold, then yes it can be defrost problem. The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.---------- But in your problem, you mentioned, in that freezer section is not stating cooling.So the compressor can be the issue.But still try reset procedure and see, if that is helping. Try manual defrost reset procedure: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If still the same problem, then the compressor has to be inspected.
you can get the required parts from online sites like:---
www.repairclinic.com or from searspartsdirect online site.---------This will help.Thanks.Helpmech.
Apr 25, 2011 | Refrigerators
Ge freezer works fine but the fridge wont cool.you
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Refrigerators
The freezer is not cold enough - ice-cream is soggy! despite putting it on coldest; and the red warning light is permanently on. And I can't find the booklet. Help!
If the coils are frozen up already,putting the setting to coldest is the worst thing to do.Even though inconvenient,try unplugging for substantial amount of time (3 or 4 hours) to allow the coils to defrost.Be prepared for water leakage during this time.If this seems to work , chances are the defrost timer or defrost heating element are bad and the problem will recur after a week or two.
Jan 17, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator/freezer gets warm intermittently
sounds like your thermostat is faulty
the thermostat reads the temperature of the cabinet and controls the temperature
the 1 thing to check on the uprights is the evaporator is in the freezer and that makes the cool then there is a fan that blows the air around the fridge and freezer to freeze things
now there is a cycle that hapens to cycle usualy every 12 hours and that is the defrost cycle
this cycle turns off the compressor and fan turns on an defrost element on the evaporator and heats up the coils to get rid of the ice
the ice turns to water and runs through a drain to a evaporator tray and when the cycle is finished the fridge stars up again and goes into the cooling state again
when the thermostat decides that the fridge is cold enough it turns of the compressor and so on it goes through the cycles as required
if the drai is blocked or the defrost system is not working the evaporator will get choked with ice and the fan will not beable to let air through to cool things off
Jan 25, 2008 | Refrigerators
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
