Question about Mitsubishi VS-60607 TV
Screen role red and green wavie lines.
Mitsubishi VS-60607 Screen role red and green wavie lines. Sound is ok.
Sometimes role stops with a group of lines across middle of screen.
  • dctc1 May 18, 2008
    I replaced both convergence IC's. It works fine For about 3 minutes. Then starts to roll.
    I UNPLUG IT FOR 10 MIN. PLUG IT IN 3 MIN. IT STARTS ROLLING AGAIN.
  • 2,336 Answers
Check this link and see if your TV is doing the same. It looks more like dry or leaky capacitors.
Posted on May 18, 2008
  • Jaime Hernandez May 18, 2008
    You can download the servie manual from this website. Make sure you download all the 10 files.
    Brigadier General:
  • 6,966 Answers
with the indulgence of the others...
Initially have you checked your signal source? Pls try another source such as a DVD or a VCR.
Additionally, ave you likewise check the resistors near the convergence ICs and/or the capacitors as IrishDruid has initially posted?
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Genius:
  • 2,035 Answers
Mitsubishi uses a proprietary 7-segment color wheel with true red, green and blue segments (two of each color) and a special neutral gray 7th segment, which enhances the ability to reproduce dark details in the image.
The Mitsubishi ALPHA Series LCoS TV has no color wheel.
It uses a 3-chip light engine design, with one chip dedicated to red, blue and green.
Please unplug the power cable fro the tv and wait for 10 mintues and if the issue exits please use numbers:
AUTOMATED REFERRAL: (800) 332-2119 PARTS: (800) 553-7238 WARRANTY: (800) 888-8245 FAX: WEB SITE: http://www.mitsubishi-tv.com FTP SITE: E-MAIL ADDRESS: ADDRESS: Mitsubishi Digital Electronics
9351 Jeronimo Road
Irvine, California 92618 COMPANY INFORMATION: Division of the Mitsubishi company that manufactures various electronics such as TV's, DVD drives, VCR's, speakers, etc...
good luck.............
    President:
  • 2,712 Answers
Hello dctc1,
Looks like there is a problem with the convergence IC's. You will have to replace both of them. I would also look for busted capacitors around the IC's.
However, if you are not familiar with TV repairs, I would advise against opening up the set. Best get a service man to come and diagnose/repair the set.
Hope that helps!
Please dont forget to rate or "Accept" the solution if it helped you in any way, or leas you to a fix.
Thank you for using FixYa!
IrishDruid
  • Swilin Sampson
    Swilin Sampson May 19, 2008
    HAVE YOU CHECKED FOR BUSTED CAPACITORS AROUND THE IC's?
Mitsubishi vs-60607 60" screen is
when picture is getting smaller in size or goes away or moves towards one side then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 22, 2011 | Mitsubishi VS-60607 TV
My picture is wavy, I have a mitubishi big screen model # vs-60607
sounds almost like bad caps okay this is where i would start is thier an option on the set to alighn convergence try that also okay may be bad module also okay its worth fixxing okay call tv shop
May 17, 2009 | Mitsubishi VS-60607 TV
Lines across the screen
we just picked upi a VS-60607 60 inch projectoin tv,  There are several issues with this television.  when powered on the colors are allconstrued and teh image is often chopped and warped, we hooked upi the cable yet there are only two local channels recieved and the power will turn off randomly every severl minutes.   Any thooughts?
Jul 07, 2008 | Mitsubishi VS-60607 TV
No picture
Sound like you lost Vertical Deflection.  Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s.    Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845.  Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V.  Data sheet located at http://pdf1.alldatasheet.com/datasheet-pdf/view/40357/SANYO/LA7845.html
Jun 22, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Vs-60607 brightness problems
This sounds like it is a problem with the tv. Mitsubishi does have a problem with filter caps in thier regulator circuits. A repair tech will have to fix it.
Mar 06, 2008 | Mitsubishi VS-60707 60" Rear Projection...
VS- 60705 Red,green,& blue lines all over screen.
sounds like your screen controls are too high? thay are behind the front cover 6 contols 3 for focus and 3 are screen the screen controls.
Apr 12, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Black screen with green smiley face
If your tv has a picture tube,your problem is in it. If you have only one line now,the vertical circuit is not working. You could have jarred something loose around the picture tube.Maybe a yoke lead ???
Jan 13, 2007 | Mitsubishi VS-60607 TV
Mitsubishi VS-60607 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
