Question about Panasonic TH-42PX25U/P 42 in. Plasma HDTV
When I try to access my DVD player I only recieve a 2 inch picture at the top of the screen,the rest of the screen is black. It's not the DVD player or the actual DVD - I went and bought a new player and the same issue occured but it worked when I attached it to another TV.
    Problem Solver:
  • 9 Answers
Hello Guys,
The only way to fix this unit is to do a software upgrade. Panasonic no longer sells the Jig for the update. I will fix it for you. I will tell you what board to ship to me and i will upgrade it for you. Just call me at 347-831-6372. I have over 30 Years experience in repairing TV. Worked for Circuit City as a Head Tech for over 8 years. Worked for Radio & TV labs for over 10 Years. Visit us at http://www.circuitsquad.com (347-831-6372)
Posted on Jun 08, 2012
lukster
  • 217 Answers
SOURCE: picture problem, half screen blank
On a plasma there are 2 buffer boards, upper and lower, it all depends which half of the screen is on as to which buffer to replace, the buffer boards are located usually on the left hand side if you have the back off the unit. You maybe able to reseat the ribbon cables and get the video back up
Posted on Feb 17, 2007
SOURCE: Panasonic TH-42PD25
This is a known problem. Panasonic sells a jig to correct it. I had the same problem and bought the jig for $60. It plugs into a special port in the back of the tv behind a little door. You can read all about it here: http://www.avsforum.com/avs-vb/showthrea... if you want, contact me by replying and I can mail you the jig temporarily for $10 plus S&H. You'll save money and it worked for me, i just need it back.
Posted on Sep 10, 2007
SOURCE: looking for replacement for damaged Panasonic LCD TV screen
looking for a replacement screen for westinghouse LTV-40w1 HDC. need to know the price and how long it takes to ship one to poplar montana 59213.
Posted on May 05, 2009
  • 9 Answers
SOURCE: Panasonic TH-42PX60U PLasma - 1/2 screen blacked out
If the screen split is exactly 50/50 top/bottom You are not getting SU or Scan Upper drive.
These are lovely set to work on.
Most likely is SU board itself - Not repairable just to be replaced.
Sorry I work in the UK so I can only guide that the UK part is around £30
SU may have been damaged by failure if the PDP (Plasma Display Panel) but is 9 years only had 2 screens damage the SU board.
There are several setups to do after fitting a PDP. If you don't have the service data - Do not risk it, Reduced life of the Panel and a safety risk.
Posted on Aug 14, 2009
SOURCE: Panasonic 50'' Plasma TV TH-42PX75U - Cannot Control Back Level
Repair it
Posted on Aug 17, 2009
Dvd player moves in and our about 1-2 inches, i heard u have to do some work to the DVD player itself. Are there hidding screws that i am not seeing other then the 2 black ones at the top , the 4 silver...
Look inside the dvd player tray up and or behind the flap you will most likely find something inside there that a young child tried to "feed it" with the help of a flashlight and some small needle noise pliers remove the offending object. No need for unscrewing most likely depending on how much damage was done, with luck very little.
Aug 24, 2010 | Disney DTD1363-CAR 13" TV/DVD
Panasonic DMR-EZ48VEB When i play a vhs tape the picture is fine ,but as soon as i try to record the picture onto a disc a black line about 1 1/2 inch appears across the bottom of the screen??? HELP
are you recording from a bought movie? some recorders have a feature that prevents copyright infringement. some will have the picture dim and red.
Dec 17, 2009 | Panasonic Televison & Video
Ewd2202 dvd/vcr combo when i put a vcr tape i can
the video heads are probably dirty.there is a steel drum 1/2 inch thick that you can see if you look thru the front lid where the tape loads.the video heads are little black spec looking things on the bottom of the drum.the easiest way to clean the drum for a novice is to put isopropyl alcohol on a piece of 2 inch square paper.hold the paper very lightly against the drum with your right index finger.turn the drum from the top,anti clockwise.you will see some black stuff on the paper.do the same with a piece of dry paper.otherwise the tape will stick to the drum if still wet.DO NOT use a q tip,as it will get caught in the heads and break them.
sometimes,just running a new blank tape for 15minutes will dislodge the particles and the picture will re appear.if you have recently rented a movie,and saw lines running across the screen,and noise from inside the machine,it is damaged tape going across the heads and drum and it can wipe out the picture just like that.run a blank tape first and then clean the drum if you have to.
Jul 07, 2009 | Emerson EWD2202 DVD Player/VCR
When connecting dvd to hitachi 42hdm12a, screen said something was corrupted. Now, can't get picture. HDMI searching but won't get picture. help
1.Press [stop]button on DVD player to Stop DVD Playback
2.Press the [resolution] button on the DVD player.
3.change resolution to 480p
if you get a picture in 480P, continue your setup of the DVD player
If you still have no picture perform the next steps (stop at the step if you recieve a picture):
4. verify the video input of the DVD player to the TV and reselct it on the TV
5. use Video cable to verify the DVD player is still working
6 disconnect/reconnect HDMI cable to TV
7. power off/on the TV
8. power off/on the DVD player
7.
5. turn off TV then Tunr
Jun 24, 2009 | Hitachi 42HDM12 42 in. Plasma Television
Projection tv has 2 pictures split with 8 inches of black
IN THE MENU GO TO COLOR CONVERSION OPTIONS AND TRY THAT ,,ALSO TRY NEW CONNECTERS
Apr 24, 2009 | Panasonic PT-52LCX65 44" HDTV
Screen does not show picture, distorted image
If you go to 1800customersupport.com it has some good info. Alco Electronics is the maker.
Oct 04, 2008 | TruTech PVS12701 Portable DVD Player
HS500, white/light at top of screen
I believe input 5 is hd input wich is different from the others
you may want to try hooking the sat to any component input to find out if there is any difference
Jul 19, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV won't stay on and DVD's are stuck inside
you moust goyng to the service center becouse is one little problem the soft
Jul 24, 2007 | Philips 20DV6942 20 in. TV/DVD Combo
Pulsing screen
Are you getting this on all video outputs from the DVD? the yellow analog out + the red/blue/green + the S video? Did you try connecting a different source? a digital cable TV tuner, or another DVD player? sometimes DVD players get screwed on some outputs, while the rest stay fine. I have a DVD that has an analog video out that shows an only black and white picture, while the red/blue/green works fine. Good luck
Apr 21, 2006 | Yamaha DVXS60 System
Panasonic TH-42PX25U/P 42 in. Plasma HDTV Logo
44 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
