Question about Hitachi 57F59 57" HDTV
We have a Hitachi 57F59J, it is making a loud popping sound and the screen flickers, we took the back off. Sparks are coming from the right side, on one of the three boards. Can you tell us what this is, if it is fixable, and if it is safe when plugged in?
  • Hitachi Master
  • 8,457 Answers
Don't plug it in anymore,it will cause more damage.The DM power supply board is dying.It poping capacitors like popcorns.Hire a tv tech. for this job,must trouble and repair.To find out why it killing capacitors this qiuck.
Posted on Sep 04, 2010
  • Chi Chu Sep 04, 2010
    DM power supply board kill capacitors all the time.Not this quick.That why must hire a tv tech to trouble shoot why,to repair it right.Simple replaced capacitors won't help.
Loud popping noise tv
EHT arcing takes place. Never switch the TV on, until this fault has been rectified. Doing so, will make too many other faults to occur. Contact any service technician.
May 23, 2013 | JVC AV-35750 35" TV
Hitachi rear projection model 57f59a makes loud popping sound from time to time
Yes and it is common---the set uses 3 picture tubes and where the high voltage (well over 10,000 volts) goes into the side of each tube via a spark plug type wire (with good reason) they completely seal the rubber clip that inserts the wire into the side of the tube.
You are describing almost perfectly when one of the tubes arcs around the anode (what the opening is called--2nd Anode to be precise)
Two things are going to happen--when it pops it can instantly burn the coating off of the offending tube's screen resulting in a burn mark--usually dead center and if red tube arcs the mark will be yellow(only red and visable in that area of the screen.
This damage is permanent once it happens-----Second is that it will arc hard enough to blow some other part out in the set.
let me know if questions.
Mar 19, 2012 | Televison & Video
Screen blinks and then goes out. tap on side and causes flickers
sure sounds like loose solder joints, look for them in the deflection circuit, just find the hard plastic encapsulated body with the thick red wire sticking out of it thats where usually the loose solder joints develop.
Sep 09, 2009 | Hitachi 50UX57B 50" Rear Projection...
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Frigidaire fridge door makes a loud popping sound
You need to take the door off the hinges and remove the lower hinge plate from the bottom of the door. This is where I found my popping problem. The black bushing with the 3 bumps and dips on it is loose in the plate going into the door. I took black eletrical tape and rapped it around the part that goes into the plate to tighten the bushing up so it wouldn't turn anymore. ( This was a temp fix to see if the popping would go away) 3 Weeks later and still working. If the sound comes back I will put some double sided sticky back foam on it. Both doors were doing this on my fridge, and now its as quite as a mouse. I hope this fix works for you.
Dec 29, 2008 | Electrolux Frigidaire Professional Series...
Wolf Microwave -- Loud Pop and Sparks
Is it safe to use your microwave if it pops like this all the time randomly... And sometimes lights up in the back like a spark or something???
Nov 19, 2008 | Microwave Ovens
Tv making popping sound
Turn down the volume and see if you still hear it,a loud pop or snap could be high voltage call your servicer in your area ASAP
while its under warranty and have him check the high voltage circuits for a intermittenting pop or snap.And have the model # ready!! Good Luck!
Dec 08, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Problems with my 50 inch hitachi ultravision projection screen tv
the best thing 2 do is buy a new one and get guarnteed with it again
if u try 2 fix it it not 50% working
if u got guarnteed then take it back (or phone them to come)
Nov 07, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
32 RCA makes popping sounds
It needs a new FLY BACK transformer. That is what you are looking at. The origionals are not made for the set any longer but insist on having a generic on installed by a local TV shop. I just put one into a RCA 31" and it works nice. Don't throw away the TV. Get it fixed. MAKE SURE YOU INSIST THEY USE THE GENERIC ONE! THEY DO WORK!
Sep 15, 2007 | RCA E13320 13" TV
Tv problem
It sounds like you have High Voltage arc, coming from back of set. Was there ever Horzontal lines in picture when this happen. Or did your picture ever get dark and miss some color? If any of this happen then it could be coming from High Voltage Transformer, and anodes leads coming from trans.I would say clean spark gap anode leads and make sure all are seated properly(tighten). It would help if you could have the back open and notice when the set does this to see if you see sparks and were from. Hope this helps. Remember be carefull around any Voltage.
Sep 06, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 57F59 57" HDTV Logo
218 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
