Question about Whirlpool Heating & Cooling
My whirlpool acq128xp0 runs great one day, then barely starts the second day, It doesnt have the air volume or cooling it use too. Just started this year. Mike
  • 24 Answers
Mike, when you stated it barely starts, to what are you referring? The compressor (condenser) section has an issue when starting or the indoor fan is hard to start?
If the fan does run, and the condenser unit outside is operating and you are getting lower than usual air flow (compared to previously), you may have a dirty filter, or you may have other obstructions at the evap coil inside the furnace or air handler. It could also be the unit is freezing up and ice on the evap coil is cutting down the air flow. Chances are if the coil is freezing over, you will have two issue that cause this:
Air flow issues (dirty coil, clogged air filter, or other obstructions across the evap coil, such as a plastic bag or pet hair, dust, ect.) which will also cause the coil to freeze over.
The other issue that would cause the low air flow is ice that is a result of low refrigerant.
If the system ran fine in the past, I will rule out it may be inproperly sized. Have you recently had a fan motor replaced on the indoor unit. If so, and they under sized the fan motor, then it could be the fan is not drawing, or blowing enough air across the evaporator coil and this will cause it to freeze over.
Look for ice on the suction line (piping) which is the bigger of the two lines coming from the outside unit (condensing unit). It is also the line that has the insulation covering it. If it has ice on it, then freezing is occuring on the evaporator. If so, then airflow issues, or refrigerant levels are usually the main culprits.
The two lines (suction and liquid) running between your indoor and outdoor unit should feel the following way to the touch of your hand:
Suction should be cold and possibly sweating if exposed (in places where no insulation is present).
Liquid line (smaller line) should be warm to the touch, but not too hot, or too cool. Should feel close to the outside ambient temperature if felt by hand.
Look these issues over and let me know.
Scott
Posted on Sep 04, 2010
  • adkmgc Sep 04, 2010
    Scott
    The air conditioner is a window model. Yhe fan some times can be adjusted to differnt speeds, but you hardly notice the difference in air speed. Compressor seems to click on and off all right.
    Thanks for the suggestions and I'll check them out too.
    Michael
  • consolejocky Sep 16, 2010
    I am not an expert but I have two of the remote controlled 8000 units and one of the 12000 units like this one.
    In my case, on the unit like yours, the fan motor also randomly made a muffled squeeling noise. It turned out that the fan motor’s lubrication had stopped doing its job. All I had to do was clean up and re-lube the motor’s bearings.
    I have found that the remote controlled Whirlpool units that used this type of electronics sometime had a problem with cold solder joints on the motor control board. This is the board that has the relays that control the fan speed and compressor. Check for cold solder joints on all connections that have large diameter wire. These connections apparently did not get hot enough to properly flow the solder on the large diameter wire.
I have a Whirlpool fridge with top freezer.
Almost certainly iced up. Fully defrost and start again. Make sure the condenser is clear and clean
May 15, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
My 5 year old whirlpool sidekick refrigerator was freezing everything and now is barely cold.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 15, 2011 | Whirlpool Refrigerators
I have Whirlpool model #ACQ128XP0, there is NO power at all to it, breaker is not blown, fan will work in the same outlet, so it is not the electrical outlet, i turned it on the other day, and it made the...
I am not an expert but I have two of the remote controlled 8000 BTU units and one of the 12000 BTU units like this one.
Aug 21, 2010 | Whirlpool Heating & Cooling
I HAVE A 1997 BLAZER THAT RUNS FINE BELOW 80 DEGREES,BUT WHEN IT IS A HOT DAY MORE THAN 80 THE FUEL PRESSURE DECREASES TO 30 PSI AND DOESNT RUN.JUST WONDERING IF IT IS THE PRESSUE REGULATOR OR THE PUMP ....
It could also be caused by the fuel pump relay. They're cheap and I would start there. There could also be a heat sensitive sensor. Did you scan the computer for codes? If you have a air compressor you could try cooling parts down (excluding the fuel pump but if everything else checks out you know the pump might be going bad) with a gentle blast of air until you find the problem.
Sep 20, 2009 | 1997 Chevrolet Blazer
Not cooling or cold
The REFRIGERATOR WAS MOVED TO ANOTHER SITE. AND IT HAS NOT GOTTEN COLD SINCE MOVE, PLUB UP 2 DAYS AGO. iT WAS UNPLUG AND CLEAN 2 DAYS BEFORE MOVE. COULD IT NEED ANTI-FREEZE?
Aug 25, 2008 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool Side by Side Refrigerator is turning on and off not getting cold at all. Freezer section barely cool and the vents during the times its on barely puts out air
it sounds like a bad:
  • start switch (on the side of the compressor) or
compressor itself
  • the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Jul 18, 2008 | Whirlpool Refrigerators
Whirlpool Refrigerator - Model# ED22LF
Tom, I would start with the overload and relay that is on the compressor, If it is white it's a good possibility that it has failed. The fact that both sides are not cooling leaves me to believe the compressor is not operating. Take the overload and relay off. If they are both contained in a white cover shake it. If it rattles, I believe that is your problem. Let me know what you find...Catriver.
Jun 28, 2008 | Whirlpool EL02CCXP 19" Cold Pals Compact...
Heating & Cooling Logo
160 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
