Question about RightWay 400 Car GPS Receiver
I have a rightway 400 and the problem i am having is the unit turns off randomly .some times i can get to the main screen and when i tape an application the unit turns off.I am plugging it into the charger and i get the red light but lately the blue light is flickering. the unit also wont hold a charge anymore. I think the battery needs to be replaced but would that cause the power problem too ? Dave
Oce tds 400 random black lines on demo print
Check the developer and clean the charge corona and the transfer /separator corona assy.Clean the PH unit lens.
Jan 29, 2013 | OCE Office Equipment & Supplies
Please help
From the Rightway rw550jr User manual:
This option is only visible when Show More Settings is selected from the Settings menu. Use this option to access the licensing information of your CoPilot software. The licensing settings allow you to activate/deactivate license regions. (Currently only North American Data is available.)
You may want to contact RightWay GPS Support for assistance.
Nov 09, 2011 | RightWay Spotter Dale Jr Edition Car GPS...
It is locked and I can't unlock it
had same issues. called their tech support. asking $75 to fix it.
luckly I found my reciept and cover under year warranty.
month later it happend again.
call them again. " Oh your warranty just expired. we can offer you same exact unit exchange for $35+$8s/h>>>
toss them in garbage. bought Garmin.
Oct 22, 2010 | RightWay 400 Car GPS Receiver
My rightway gps just randomly locked how don i unlock
I have the same problem, the manufacturer said I cannot fix it myself, I have to send it to them. No explanation on how or why it happened
Feb 01, 2010 | GPS
Canon IR 400
i have canon ir405 cpier it dispays error code E243 please help me sir
Jun 01, 2009 | Office Equipment & Supplies
Set library mode or Random mode Magstar 3570 AS/400
Apr 20, 2009 | IBM Magstar 3570 Magstar Tape Drive
Philips CCB130AT02
Likely the tape sensor switch is faulty. Normally it is located on beneath the mechanism towards the front where the tape goes in. It is a micro-switch that is actually soldered to the main PCB. You have to remove the main board and desolder the switch. You might want to try replacing the switch since with over usage (tape in/out countless times) it may have worn out.
Note that VCR servos are such that if an event in the mechanism does not occur within a given frame of time the unit will shut down.
Jan 21, 2008 | Philips CCB130AT 13 in. Combo
RightWay 400 Car GPS Receiver Logo
134 people viewed this question
Top RightWay GPS Experts
Andrew Taylor
Andrew Taylor
Ammar Masannat
Ammar Masannat
Level 1 Expert
Gary Tiedeman
Gary Tiedeman
Are you a RightWay GPS Expert? Answer questions, earn points and help others
