Question about HP Photosmart C5280 Printer
Paper Jam I have an HP All-in-One C5280. The printer works great but every time I print It says paper jam, but there is not a paper jam. If I hit OK without doing annything else it will start printing. This doesnt stop me from printing but it is very annoying. Have you heard of this problem before?
  • 3 Answers
Well i tried everything and i think i found the solution. I have the same problem when i spotted something when i was reading the manual. I am sure that you have the printer connected to a extention that takes 1 wall outlet and gives you more. This leads to the paper jam problem because the printer takes less power from the one needed and shows error so if you put the cable to a direct wall outlet voila the problem is solved enjoy!!!!!
I hope this helps you it helped me :P
Posted on Jul 07, 2008
  • 2,712 Answers
Just check the rollers for debris or any tiny piece of paper. Sometimes using refilled cartridges also can cause this error. Should that not work, you could try a hard reset: unplug printer from pc and mains. wait about 10-15 minutes and while holding down the power button, connect to mains and tho pc. Hopefully that should work.
Posted on May 11, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
How to fix a carriage jam/
Jan 24, 2016 | HP Photosmart C5280 Printer
HP Officejet Pro L7800. Had paper jam, but opened
mine was 2 there was paper stuck in the little white gears
Nov 02, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
We had a paper jam in our HP Photosmart C5280 Al-in-One printer. Error message in window reads: Carriage jam! Open door, clear carriage jam, and then pres OK to continue We opened door and even...
after closing the cover and removing the jammed papaer does it still says "paper or carriage jam"????
if it still prompts you that theres a jam and you've already removed it, try to turn off the printer, disconnect from its connections (pc and ivr or ups or wherever its connected) wait for like 5-10 sec then connect it again...
hope this resolves ur prob...
ive experience it to with my hp j3500 all in one... a paper jam, this is what i did and i think it worked for me... hope it do to your printer.. ciao!
Sep 10, 2009 | HP Photosmart C5280 Printer
Paper jamed
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
Continuous PAper jam error-message!!!
Sounds like a small piece of the jammed paper is stuck inside on a paper path switch OR in pulling out the jam you've dislocated a switch actuator so it is not working correctly. Careful checking of the paper path components should find it. Probably a slot in one of the guides is hiding it.
Jul 22, 2009 | HP Photosmart C5280 Printer
Hp C5280 Paper Jam error - no paper + component fell apart
I am having a similar problem. An33651759-359a-4c42-a15c-e9b8d80fcfba.jpgyone know where this piece belongs? It came out when I cleared my millionth paper jam!
Sep 09, 2008 | HP Photosmart C5280 Printer
Paper jam in HP 4255 office jet all in one printer
the paper path may have some jam. It may have some solid particle or paper that's causing disturbance.
If not the paper moving mechanism is having problem.
Better get your printer serviced.....
Jul 17, 2008 | HP OfficeJet 4215 All-In-One InkJet...
HP Photosmart C5280 Printer Logo
318 people viewed this question
Ben Johnson
