Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My washer keeps displaying a code of f 51 what is the problem
    President:
  • 1,932 Answers
Basically, the F51 error is a rotor position sensor error.
Thank You
Posted on Sep 04, 2010
3 Suggested Answers
  • 18 Answers
SOURCE: code 51
If your unit has a serial number of CU13----- or less, you will need to have part # W10130544 installed by a servicer.
Posted on May 10, 2008
  • 62 Answers
SOURCE: I keep getting an F 51 error code on my washer?
if not under warr. You must replace sensor on bottom of tub along with the wiring harness. This is a common problem with these.
Posted on Oct 22, 2008
What does error code 51 mean?
I found this on the internet. May be of some help.
The F-51 error code on this washer indicates that the machine control board in the console detects a motor RPS (Rotor Position Sensor -- tachometer) failure. This can be caused by a number of different problems. You could have a bad RPS sensor, a failed motor, a wire harness connection problem or an item stuck between the spin basket and the outer tub that is interfering with spin basket rotation. A water filling problem could also cause this code to be displayed since the basket would have excessive friction if water is not entering the machine properly. With the washer off, spin the basket to see if it rotates freely. If you detect resistance or suspect that an item is stuck between the basket and the outer tub, you will likely need to remove the basket and check this area. The procedure for removing the basket is shown in the first image below. Remove the basket and check for foreign objects or debris.
If the basket spins freely, make sure that your water supply cut-off valves are fully open. Shut off the water supply and remove the hoses from the connections on the back of the washer. Place the ends of the hoses in a bucket and briefly turn on the water supply to check the flow and water pressure coming from the end of the hoses. Check the inlet water valve screens for deposits or debris that could interfere with the water fill. The motor will begin to spin the basket before the washer completes the filling function. If the filling is slow, it could cause the F-51 code.
If the water supply is okay, you could have a wire harness connection problem, failed RPS sensor or a number of other failures. If you are technically advanced and have a volt/ohm meter, you can use the technical information provided in the third image to try and diagnose your likely failure. NOTE: This information is intended for technicians. Follow electrical safety guidelines when using this information.
Unplug the washer
to disconnect electrical power before accessing internal components. Internal metal edges in the washer can be sharp. Protective gloves are recommended.
I recommend that you
unplug the washer
and access the control board first. Check the wire harness connections on the P10 and P5 plugs first. Measure the resistance through the motor and the RPS sensor as shown below. This may point you in the direction of your failure.
This is often a difficult failure to diagnose and repair in an Oasis washer. If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician.
Jun 07, 2015 | Kenmore Washing Machines
F 51 code
my hhot point washing machine door won't open and is displaying F5 and door block
Nov 20, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
F-51 code
Motor RPS Failure--F then 51 flashes when there is a motor rotor position sensor(RPS) senses rotation after stop command.F-51 ERROR CODE IS DEALING WITH THE SPIN CYCLE. THE CONTROL DOES NOT DETECT IT SPINNING.THE RPS SENSOR ON THE BOTTOM OF THE UNIT NEEDS TO BE TAKEN OFF AND PUT BACK ON ABOUT 10 TIMES. SOUNDS WEIRD BUT USUALLY FIXES IT.But if that does not help then it needs to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Sep 01, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Washer fills up and then displays an "F" then 51?
May be the pressure starter is faulty kindly replace the pressure starter the problem will be solved
May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F-51 code
Contact Whirlpool as they will now fix this on a special repair program--RPS sensor and wire harness replacement
Feb 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Oct 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio HE washing machine displays error code F51. What is it and hw to I fix it?
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Jul 27, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Error message
F51 error code is beacause the computer board did not receive input from the motor on the bottom. Unplug the washer, pull the machine forward and tilt the machine back. On the bottom you will see a large white wheel with a silver allen screw in the middle I think it is a 6mm allen wrech that takes it off. Once you remove the screw and drop the white wheel, there will be a large coil of wires with 4 5/16 screws holding it on, remove these scres and drop the coils. On the right hand side you will see a connector with three wires , unplug it. Use sand paper or a scraping tool to clean all 3 male sides of the connectors. Reverse process to re-assemble.
May 15, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Code 51
Saw this in other area of blog (see below). I had same problem and Whirlpool service replaced RPS control board...fixed problem. Best Solution posted on Oct 20, 2007 2%20stars.png
446a518.jpg By wizard_s.gif eagle338
Rank: Wiz
Rating: 75%, 482 votes
there is a motor rotor position sensor(RPS) failure.
Refer page 10 of the manual below
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567036.pdf
If you still cant fix it come back here..and ask i will help you out..
And please dont forget to rate if its solved..
Aug 19, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
105 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
